i've test a simple search with cfgrid but don't know why when i dump the arguments from my cfc and it shows null instead of empty string.
To testing, i added cfdebug at the end and see some error:
Element not found: ANo
'gridRender' is undefined.
Please look at my code below and let me know what did i have wrong. -Thanks
<!---form.cfm--->
<cfform action="process.cfm" method="post">
<cfinput type="text" name="ANo" id="ANo" value="">
<input class="button" type="submit" name="submit" value="Search" />
</cfform>
<!---process.cfm--->
<cfparam name="variables.row_per_page_default" default="15">
<cfparam name="variables.row_per_page_list" default="15,30,50,75,100">
<cfparam name="form.ANo" default="" />
<cfform name="gridform" >
<cfgrid
name="grdAresults"
format="HTML"
title="Search Result"
collapsible="false"
selectMode=" Single"
pagesize="15"
bindOnLoad="true"
stripeRowColor ="silver"
stripeRows="yes" width="900"
bind="cfc:cfc.searchA.SearchA({cfgridpage},{cfgridpagesize},{cfgridsortcolumn},{cfgridsortdirection},
{ANo})"
<cfgridcolumn dataalign="center" width="100" name="aNo_var" header="A Number" href="index.cfm?action=editCR" hrefkey="id" target="_blank" />
</cfgrid>
</cfform>
<cfset ajaxOnLoad("gridRender")>
<!---cfc--->
<cfcomponent displayname="search" output="no" hint="search a number">
<cffunction name="SearchA" returntype="struct" access="remote">
<cfargument name="page" required="true" />
<cfargument name="pageSize" required="true" />
<cfargument name="gridsortcolumn" required="true" />
<cfargument name="gridsortdirection" required="true" />
<cfargument name="ANo" required="yes" type="any" />
<cfdump var="#arguments#"><cfabort>
<cfquery name="qSearchA" datasource="#dsn#">
select * from mytblb
where 0=0
<cfif arguments.ANo neq "">
ANo_var = <cfqueryparam value="#arguments.ANo#" cfsqltype="cf_sql_varchar" />
</cfif>
</cfquery>
<cfreturn queryconvertforgrid(qSearchA, page, pagesize)>
</cfquery>
</cfcomponent>
i don't see html from cfgrid format, all i see is xml, applet, flash. I mannulay entery HTML in, do you know why is HTML is not on the list?
I assume you want to filter by the Ano value?
Try
{gridform:ANo}
But a better way would be
Javascript function
var ANo_value = "";
function get_ANo(){
ANo_value = ColdFusion.getElementValue(ANo);
return ANo_value
cfgrid
bind="cfc:cfc.searchA.SearchA({cfgridpage},{cfgridpagesize},{cfgridso rtcolumn},{cfgridsortdirection},
{get_ANo})"
regards
Ken
thank you
I forgot to include the following for the javascript version.
On the form field
Include an onKeyUp event
<cfinput type="text" name="ANo" id="ANo" value="" onKeyUp="get_ANo()">
This will then filter the grid with each character entered.
Ken
did not work, error: Element not found: get_ANo
Sorry, my mistake. I assume your using the javascript version?
Then
get_ANo())"
If your trying to bind through the cf form field then I don't know as I don't do it that way.
Ken
