i have the search page and want to display the results on the the cfgrid. Both form and cfgrid are on the same page. When i first open the form.cfm page, i see all the results already display on the page. This is not right, i only want the results to display when i search something and hit on the submit button. Can you please help?
<!---my form.cfm--->
<cfparam name="variables.row_per_page_default" default="50">
<cfparam name="variables.row_per_page_list" default="15,30,50,75,100">
<cfform name="search" action="form.cfm" method="post" onsubmit ="ColdFusion.Grid.refresh('myGrid', false);">
<cfinput type="text" name="aNo_var" id="aNo_var">
<input class="button" type="submit" name="submit" value="Search" />
<!---diplay on the cfgrid--->
<cfgrid
format="html"
name="grid01"
width="700"
sort=true
bindOnLoad="true"
pagesize="#variables.row_per_page_default#"
bind="cfc:cfc.searchA.cf_city({cfgridpage},{cfgridpagesize},
{cfgridsortcolumn},{cfgridsortdirection},
{aNo_var})">
<cfgridcolumn name="aNo_var" width="100" display=true header="Name" />
</cfgrid>
</cfform>
<!--cfc--->
<cfcomponent displayname="searchA" output="no" hint="search a number">
<cffunction name ="SearchANo" access="remote" returnpe="struct">
<cfargument name ="page" required="true" />
<cfargument name = "pageSize" required="true" />
<cfargument name ="gridsortcolumn" required="true" />
<cfargument name ="gridsortdirection" required="true" />
<cfargument name="aNo_var" required="true" type="string" />
<cfset var myQuery = querynew("")>
<cfquery name="myQuery" datasource="#dsn#">
select * from mytbl
where 1=1
<cfif arguments.aNo_var neq "">
aNo_var = <cfqueryparam value="#arguments.aNo_var#" cfsqltype="cf_sql_varchar" maxlength="50" />
</cfif>
</cfquery>
<cfreturn queryconvertforgrid(myQuery, page, pagesize) />
</cffunction>
</cfcomponent>
<cfif isDefined("form.submit")>
<cfgrid>
</cfif>
Ken
thank you
