1. Re: Organiser problem
99jon Dec 10, 2013 1:18 AM (in response to Dave stephen)Try finding the Organizer application by following the path below (on windows) and then right-click on it (see image)and choose send to desktop.
C:\Program Files (x86)\Adobe\Elements 12 Organizer
Right-click on your new desktop icon and choose “Run As Administrator” which oten improves stability.
Click image to enlarge
2. Re: Organiser problem
andaleebfatima1 Dec 11, 2013 2:24 AM (in response to Dave stephen)Hi,
Which OS are you on?
Andaleeb
3. Re: Organiser problem
Dave stephen Dec 11, 2013 12:07 PM (in response to andaleebfatima1)Hi
im running windows 7 32bit
4. Re: Organiser problem
Dave stephen Dec 11, 2013 12:15 PM (in response to 99jon)Hi
Many thanks for your help but iTried going through the way you said but its still does the same thing, I am almost at the stage of giving up.
5. Re: Organiser problem
nealeh Dec 11, 2013 2:21 PM (in response to Dave stephen)You might be best to go to http://helpx.adobe.com/contact.html?product=photoshop-elements&topic=downloading-installin g-and-setting-up. Click the 'I still need help' button at the bottom and use the 'Chat with an Agent' option. They're best suited to help you with installation problems. If you've only bought the product recently, and depending on where you got it from, you could be able to get a full refund if you decide it's not the product for you.
Cheers,
Neale
Insanity is hereditary, you get it from your childrenIf this post or another user's post resolves the original issue, please mark the posts as correct and/or helpful accordingly. This helps other users with similar trouble get answers to their questions quicker. Thanks.
6. Re: Organiser problem
andaleebfatima1 Dec 11, 2013 11:08 PM (in response to Dave stephen)Hi Dave,
Can you please try these-
From Task Manager, kill ElementsAutoAnalyzer.exe and any other Adobe related exe running
Goto %appdata%\Adobe\Elements Organizer\12.0\Organizer and delete the files - psa.prf and status.dat
Now go to - C:\Program Files\Adobe\Elements 12 Organizer and right click PhotoshopElementsOrganizer.exe > choose Run as Admin.
Once EO launches, click Edit > Pref > Media Analysis > and turn off all options there
See if doing so helps stop the crash.
Andaleeb
