10 Replies Latest reply: Dec 11, 2013 8:29 AM by Test Screen Name RSS
    Convert text file into pdf with hebrew charcters
    Hezi Community Member
      I am want to convert Text files into Pdf.
      In my origin file, I can get Hebrew Charcters as well.
      I used this line for the basefont: "\r\n<</Type/Font/Subtype/Type1/BaseFontt/Courier/Encoding/WinAnsiEncoding>>\r\nendobj\r\ n"
      I understood my Encoding is not suitable for the Hebrew charcters.
      To what do I need to change this line?
      Hezi
        • 1. Re: Convert text file into pdf with hebrew charcters
          lrosenth Adobe Employee
          Given that WinAnsiEncoding does NOT support Hebrew – that won't work.
          You will need to do a full embed of the font and use either a custom encoding or CIDFont.
          Details in ISO 32000-1:2008
          • 2. Re: Convert text file into pdf with hebrew charcters
            Can you post me an example how to embeded Hebrew font?
            • 3. Re: Convert text file into pdf with hebrew charcters
              Test Screen Name CommunityMVP
              I recommend you read and reread 32000-1 until an example is superfluous. I do not post examples as policy because it may lead to trying to implement before a full understanding.
              If you have any issues with the detail or understanding of 32000-1, we can try to help with that.
              • 4. Re: Convert text file into pdf with hebrew charcters
                Well, I reread it.
                I understand I can not use winansi. and I have to embed winsows-1255 or iso-8859-8.
                But I can not understand How to embed the encoding in my code?
                Help needed
                Hezi
                • 5. Re: Convert text file into pdf with hebrew charcters
                  Well, you can't use Windows-1255 or ISO 8859-8 either.  You will need to create a custom encoding  along with your embed.
                  Implementation details are very tied to available technology that you may have.  Are you running on an OS platform that has APIs for getting/managing fonts?  If not, can you use open source solutions that would help you here?
                  • 6. Re: Convert text file into pdf with hebrew charcters
                    I am running on Windows Server 2008.
                    Yes, I  can use an open source solution, that woukd be very helpful
                    With Regards,
                    Hezi
                    • 7. Re: Convert text file into pdf with hebrew charcters
                      Then why not just use one of the myriads of existing open source solutions/libraries for PDF generation that already do font embedding (and much more) for you??
                      • 8. Re: Convert text file into pdf with hebrew charcters
                        I did not find that convert from test file to pdf with Hebrew font support.
                        do you have a link for a solution?
                        How can I get a font in my code?
                        • 9. Re: Convert text file into pdf with hebrew charcters
                          With respect, I don't think you can have looked very hard for a solution if you cannot find one which does this. However the focus of this group is writing your own code, so....
                          The Encoding is almost the smallest part of the problem, but the approach is as follows.
                          Assuming you are NOT using a CID font, the Encoding is an array of names which you generate with Differences etc. The names are standardised, and listed in the "Adobe Glyph List". I assume you have the Unicode values for Hebrew; you can convert the Unicode values to names using the list.
                          These names must match the encoding actually used in the font.  You must embed the font for non-Latin characters (except CJKV). You CANNOT use a non-embedded font. You CANNOT just apply a Hebrew encoding to a standard font like Helvetica. Type 1 fonts are simplest if you can source 1, you should find the encoding if you open it in a text editor (but do NOT save any edits it will break the font).
                          • 10. Re: Convert text file into pdf with hebrew charcters
                            I have another note which may be useful to you. There are things in PDF that seem simple, such as setting simple text in a non-embedded font using WinANSI encoding. Implementers often make the mistake of assuming that varying this will be almost as simple. In fact, there are many points where an imlementation increases in complexity by an order of magnitude or two. There are a number of key points of that with fonts. These include: first level:
                            - using non-embedded CJKV fonts
                            - using embedded Latin1 fonts available in type 1
                            Second level:
                            - using other font formats to embed
                            - using non-Latin single byte fonts
                            Third level:
                            - Using multibyte fonts
                            - Providing language independent Unicode support
                            These stretch something an experienced programmer could throw together in a day into something that will take many months of detailed research.
                            I point this out for you to evaluate the relative costs of implementation versus finding an existing solution
