Is it possible to give spacing between the TOC entries within a skin?
Probably – how are your JavaScript programming skills? ;>)
It requires some tinkering with the CSS created in whthost.js. See
http://www.wvanweelden.eu/output_file/robohelp-9-and-earlier-webhelp/whthostjs
for an overview of what you can do in that file.
Kind regards,
Willam
Hi...thank you for the reply...but i am using Robohelp Version 10.0.0.287 in the trial mode. And i am unable to locate the whthost.js or the whtdhtml.htm files. Please can you help.
The files are in your output directory. Are you looking in your project's source?
Running it as a trial has nothing to do with it – it’s the same version as the licensed one. You’ll find that file in your output folder (the \!SSL!\WebHelp\ one)
Thanks a lot for your reply i found the file and also was able to increase the spacing between the TOC entries by changing the value of the var gsMargin in the whthost.js file.
