Hi there, I'm working with Master Templates in InDesign and I'm trying to have each page that is assigned a specific Master Template inherit not just the elements in the printable area of the doc, but also element's outside the "page." I'm storing some frequently-used elements in the white space around the page and it would be much easier to have this simply be part of the master. However, it seems that the master only affects the printable page area. Does anyone know how to override this so that pages can inherit elements outside the printable area?
THe white space around the page is called the Pasteboard, and pastebaords are uninque to each page in ID.
If you want an object from a master spread to also appear on a document spread at least some portion of it must be inside the largest of the page boundary or any defined bleed or slug allowance.
