Hello,
I am running Flash Media Server on my dedicated CentOS host, and finally connected a single RTMP stream fine and am able to embed and play back the stream, but I am getting constant buffering pauses (approx every 5 secs) and audio/video out of sync by at least 5 seconds. My CPU with Flash Live Encoder is a powerhorse, never over 25% processor or ram usage while streaming, and my upload internet speed is averaging 6-8 mbps which should be more than adequate. I fear the issue is server side, however port 1935 is open and in use, not firewalled on CPU nor the host.
Any suggestions would be great.
What is the player on the web page? Did you build your own Flash SWF to play the video, or are you using an off-the-shelf player like JW Player? Can you send a link to a sample stream?
Hello,
Thanks for the reply, I am using embed code generated with Flash Media Playback, as follows:
<object width="640" height="480"> <param name="movie" value="http://fpdownload.adobe.com/strobe/FlashMediaPlayback.swf"></param><param name="flashvars" value="src=rtmpt%3A%2F%2F50.62.40.55%3A1935%2Flive%2Fchristmastime&poster=http%3A%2F%2Fsquarestream.ca%2Fpics%2Fframe.jpg&autoPlay=true&streamType=live&optimizeInitialIndex=false"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://fpdownload.adobe.com/strobe/FlashMediaPlayback.swf" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="480" flashvars="src=rtmpt%3A%2F%2F50.62.40.55%3A1935%2Flive%2Fchristmastime&poster=http%3A%2F%2Fsquarestream.ca%2Fpics%2Fframe.jpg&autoPlay=true&streamType=live&optimizeInitialIndex=false"></embed></object>
