Show 2 replies
1. Re: Trouble Creating a New Directory to Import into
Victoria_Bampton Dec 12, 2013 5:19 AM (in response to Nevada Shooter)Instead of creating a new folder using right-click, select the parent folder and then check "Into Subfolder" above and enter your new folder name there.
2. Re: Trouble Creating a New Directory to Import into
Nevada Shooter Dec 12, 2013 8:36 AM (in response to Nevada Shooter)Thanks that works. I found that even though the new directory did not show in the Import list of directories when I created it usind the right-click method as I did in LR4, LR5 is in fact creating it and will import to it. Another odd thing is when I create the directory using the right-click, Windows Explorer method, the directory list in the Import module flickers like it is adding the new directory. However, the new directory cannot be seen.
