2. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
Siuwongau Oct 15, 2012 11:18 PM (in response to Mylenium)How to upload the install logs to you?
3. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
Arpit Kapoor Oct 16, 2012 3:50 AM (in response to Siuwongau)"Installer Failed to initialize" is a generic error and we need to figure out what is causing the trouble. Most of the time, its an issue with the download that it was not successful or downloaded properly. So, in such cases, download the software again and make sure to compare the file size of the downloaded file with the file on the server. Lets check that in this case as well and make sure the download is complete.
If the file size is correct, As Mylenium said, we need the install.log file.
Navigate to the log files in one of the following folders:
• Windows 32 bit (XP, Vista, 7): \Program Files\Common Files\Adobe\Installers\
• Windows 64 bit (XP, Vista, 7): \Program Files(x86)\Common Files\Adobe\Installers
• Mac OS: /Library/Logs/Adobe/Installers/
The log filename includes the product name and install date, followed by ".log.gz." The extension .gz indicates a compressed format.
Use a decompression utility such as Winzip or StuffIt to decompress the .gz file. Once uncompressed, the log file is a plain text file.
Open the .log file using WordPad (Windows) or TextEdit (Mac OS).
Note: By default, log files open in Console on Mac OS. Select all of the text by pressing Command+A, and then copy and paste it into a text editor before continuing.
Scroll to the bottom of the log. Look in the --- Summary --- section for lines that start with ERROR: or FATAL and indicate a failure during the installation process.
Copy and Paste that SUMMARY section in here so that we can check the errors. You might also analyze the logs yourself. http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html
4. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
Siuwongau Oct 16, 2012 8:36 PM (in response to Arpit Kapoor)Would you please analyze the logs for me? Thanks. - 0 fatal error(s), 33 error(s), 0 warning(s) ----------- Payload: {08EF22BC-43B2-4B4E-BA12-52B18F418F38} Adobe Photoshop CS5.1 Core 12.1.0.0 ----------- ERROR: DF037: Unable to delete directory "C:\Users\Elaine Kong\AppData\Roaming\Adobe\Adobe Photoshop CS5.1". Error 145 The directory is not empty.(Seq 3506) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 3506) ----------- Payload: {D8CCCF4C-C227-427C-B4BE-736657D2AB7E} Adobe Flash Catalyst CS5.5 1.5.0.0 ----------- ERROR: DF037: Unable to delete directory "C:\Users\Elaine Kong\AppData\Roaming\Macromedia\Flash Player\#Security\FlashPlayerTrust". Error 145 The directory is not empty.(Seq 16) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 16) ERROR: DF037: Unable to delete directory "C:\Users\Elaine Kong\AppData\Roaming\Macromedia\Flash Player\#Security". Error 145 The directory is not empty.(Seq 17) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 17) ----------- Payload: {6548A7DA-770A-4BCD-A6ED-719CC7B6FD1B} Adobe Media Encoder CS5.5 X64 5.5.0.0 ----------- ERROR: DF037: Unable to delete directory "C:\Users\Elaine Kong\AppData\Roaming\Adobe\Adobe Media Encoder". Error 145 The directory is not empty.(Seq 6) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 6) ERROR: DF037: Unable to delete directory "C:\Program Files\Adobe". Error 145 The directory is not empty.(Seq 1130) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 1130) ----------- Payload: {5FA850A4-02D6-1016-89BE-9DA43E267FC4} Adobe InDesign CS5.5 Application Feature Set Files 7.5.0.0 ----------- ERROR: DF037: Unable to delete directory "C:\Users\Elaine Kong\AppData\Roaming\Adobe\InDesign". Error 145 The directory is not empty.(Seq 12) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 12) ----------- Payload: {0094FC04-A548-4D8F-87C1-140431F76C2E} Adobe ExtendScript Toolkit CS5.5 3.6.0.0 ----------- ERROR: DF037: Unable to delete directory "C:\Users\Elaine Kong\AppData\Roaming\Adobe\ExtendScript Toolkit". Error 145 The directory is not empty.(Seq 393) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 393) ----------- Payload: {71BC8278-815D-4F8C-8FA5-C6F782C73892} Adobe CSXS Infrastructure CS5.5 2.5.0.0 ----------- ERROR: DF037: Unable to delete directory "C:\Users\Elaine Kong\AppData\Roaming\Adobe\CS5.5ServiceManager". Error 145 The directory is not empty.(Seq 8) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 8) ----------- Payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 ----------- ERROR: DF037: Unable to delete directory "C:\ProgramData\Adobe\CameraRaw\LensProfiles\1.0\Nikon". Error 145 The directory is not empty.(Seq 241) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 241) ERROR: DF037: Unable to delete directory "C:\ProgramData\Adobe\CameraRaw\LensProfiles\1.0". Error 145 The directory is not empty.(Seq 288) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 288) ERROR: DF037: Unable to delete directory "C:\ProgramData\Adobe\CameraRaw\LensProfiles". Error 145 The directory is not empty.(Seq 289) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 289) ERROR: DF037: Unable to delete directory "C:\ProgramData\Adobe\CameraRaw\CameraProfiles\Camera". Error 145 The directory is not empty.(Seq 712) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 712) ERROR: DF037: Unable to delete directory "C:\ProgramData\Adobe\CameraRaw\CameraProfiles\Adobe Standard". Error 145 The directory is not empty.(Seq 954) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 954) ERROR: DF037: Unable to delete directory "C:\ProgramData\Adobe\CameraRaw\CameraProfiles". Error 145 The directory is not empty.(Seq 955) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 955) ERROR: DF037: Unable to delete directory "C:\ProgramData\Adobe\CameraRaw". Error 145 The directory is not empty.(Seq 956) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 956) ERROR: DW049: Payload {32841ECE-EC28-42CD-A4DD-6CE832A7EA8D} has an action "remove" but no resultState ERROR: DW049: Payload {A189C479-C7CD-4E08-8CCF-D999B68C0C71} has an action "remove" but no resultState ERROR: DW049: Payload {FD58D99B-9927-4226-8E00-959A4F76BD89} has an action "remove" but no resultState Please search the above error/warning string(s) to find when the error occurred. These errors resulted in installer Exit Code mentioned below. ------------------------------------------------------------------------------------- Exit Code: 0 - No error. *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* END - Installer Session *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
5. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
Siuwongau Oct 23, 2012 6:50 PM (in response to Siuwongau)After disabling UAC, doing selecting start up and enabling the root user in Window 7 64-bit, the installation can be proceed.
Now the problem is resovled. Thank you Adobe Technical Support, Shenoy S!!!
6. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
Creative Skull Oct 30, 2012 4:17 PM (in response to Siuwongau)Hi,
Please try these Steps and let me know can you install it.
1. Disabling UAC.
2. Disable the Startup Items and Services.
3. Enabling the hidden Admin user in Window 7 64-bit.
Run the installer again in the Hidden Admin in Windows 7.
Sanjay M Suman
Adobe technical Support
7. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
Siuwongau Oct 30, 2012 7:24 PM (in response to Creative Skull)The problem was sovled and installation was completed.
Anyway, thanks for your information.
8. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
SamanthamChavez Jan 9, 2013 6:42 AM (in response to Siuwongau)Help got the same error on windows 8 brand new laptop and i need this software for work
1/8/2013 17:46:30 [INFO] BS-ASUInstaller - Build Version - 1.5.115.0
1/8/2013 17:46:30 [INFO] BS-ASUInstaller - Logging Level verbosity Set to 4
1/8/2013 17:46:30 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\resources\setup.xml
1/8/2013 17:46:30 [INFO] PIM - XML is valid
1/8/2013 17:46:30 [INFO] BS-ASUInstaller - Found 3 packages in setup manifest
1/8/2013 17:46:30 [INFO] BS-ASUInstaller - BEGIN pim_getInstallStatusAtPath...
1/8/2013 17:46:30 [INFO] BS-ASUInstaller - PIM CF PATH :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\
1/8/2013 17:46:30 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/8/2013 17:46:30 [INFO] PIM - Current db schema version on machine 1.
1/8/2013 17:46:30 [INFO] PIM - Current db schema version to install 1.
1/8/2013 17:46:30 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/8/2013 17:46:30 [INFO] PIM - PIM Database is Up To Date.
1/8/2013 17:46:30 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\core\PDApp.pimx
1/8/2013 17:46:30 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\UWA\UWA.pimx
1/8/2013 17:46:30 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\DWA\DWA.pimx
1/8/2013 17:46:30 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\LWA\LWA.pimx
1/8/2013 17:46:30 [INFO] BS-ASUInstaller - END pim_needsInstallRepairOrUpgradeAtPath...
1/8/2013 17:46:30 [INFO] PIM - PIMSqlite closeDB status 0
1/8/2013 17:46:30 [INFO] BS-ASUInstaller - Success in check install status, status is at path :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\
1/8/2013 17:46:30 [INFO] BS-ASUInstaller - Latest Version of Adobe Application Manager is present on the machine, no need to install
1/8/2013 22:08:51 [INFO] Setup - Build Version - 2.0.242.0
1/8/2013 22:08:51 [INFO] Setup - Logging Level verbosity Set to 4
1/8/2013 22:08:51 [INFO] Setup - Start Adobe Setup
1/8/2013 22:08:51 [INFO] Setup - TimeLog: Bootstrapper Start
1/8/2013 22:08:51 [INFO] Setup - TimeLog: Start initial checks
1/8/2013 22:08:53 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/8/2013 22:08:53 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/8/2013 22:08:53 [INFO] PIM - XML is valid
1/8/2013 22:08:53 [WARN] PIM - Failed to find Node
1/8/2013 22:08:53 [INFO] Setup - Found 3 packages in setup manifest
1/8/2013 22:08:55 [INFO] PIM - Build Version - 2.0.242.0
1/8/2013 22:08:55 [INFO] PIM - Logging Level verbosity Set to 4
1/8/2013 22:08:56 [INFO] Utilities - Folder does not exist
1/8/2013 22:08:56 [INFO] PIM - Build Version - 2.0.242.0
1/8/2013 22:08:56 [INFO] PIM - Logging Level verbosity Set to 4
1/8/2013 22:08:56 [INFO] PIM - CREATE PIM Instance ...
1/8/2013 22:08:56 [INFO] Utilities - File does not exist
1/8/2013 22:08:56 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/8/2013 22:08:58 [INFO] PIM - SUCCESS Created Tables.
1/8/2013 22:08:58 [INFO] PIM - PIM Database is Up To Date.
1/8/2013 22:08:58 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/8/2013 22:08:58 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/8/2013 22:08:58 [INFO] PIM - Current db schema version on machine 1.
1/8/2013 22:08:58 [INFO] PIM - Current db schema version to install 1.
1/8/2013 22:08:58 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/8/2013 22:08:58 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:08:59 [INFO] PIM - XML is valid
1/8/2013 22:08:59 [WARN] PIM - Failed to find Node
1/8/2013 22:08:59 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/8/2013 22:08:59 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/8/2013 22:08:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/8/2013 22:08:59 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/8/2013 22:08:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/8/2013 22:08:59 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/8/2013 22:08:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/8/2013 22:08:59 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/8/2013 22:09:00 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/8/2013 22:09:00 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/8/2013 22:09:00 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/8/2013 22:09:00 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/8/2013 22:09:00 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/8/2013 22:09:00 [INFO] Setup - TimeLog: End initial checks
1/8/2013 22:09:00 [INFO] Setup - TimeLog: Begin Installing
1/8/2013 22:09:00 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:09:00 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:09:00 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:09:00 [INFO] PIM - XML is valid
1/8/2013 22:09:00 [WARN] PIM - Failed to find Node
1/8/2013 22:09:00 [ERROR] PIM - Package folder does not exist on the system.
1/8/2013 22:09:00 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/8/2013 22:09:00 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
Return Value of pim_installPackage = -1
1/8/2013 22:09:00 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/8/2013 22:11:38 [INFO] PIM - PIMSqlite closeDB status 0
1/8/2013 22:11:38 [INFO] PIM - FREE PIM Instance ...
1/8/2013 22:11:38 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/8/2013 22:11:38 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/8/2013 22:11:38 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/8/2013 22:11:38 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/8/2013 22:11:38 [INFO] Setup - End Adobe Setup. Exit code: 1
1/8/2013 22:11:38 [INFO] Setup - Build Version - 2.0.242.0
1/8/2013 22:11:38 [INFO] Setup - Logging Level verbosity Set to 4
1/8/2013 22:11:38 [INFO] Setup - Start Adobe Setup
1/8/2013 22:11:38 [INFO] Setup - TimeLog: Bootstrapper Start
1/8/2013 22:11:38 [INFO] Setup - TimeLog: Start initial checks
1/8/2013 22:11:39 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/8/2013 22:11:39 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/8/2013 22:11:39 [INFO] PIM - XML is valid
1/8/2013 22:11:39 [WARN] PIM - Failed to find Node
1/8/2013 22:11:39 [INFO] Setup - Found 3 packages in setup manifest
1/8/2013 22:11:39 [INFO] PIM - Build Version - 2.0.242.0
1/8/2013 22:11:39 [INFO] PIM - Logging Level verbosity Set to 4
1/8/2013 22:11:39 [INFO] Utilities - Folder does not exist
1/8/2013 22:11:39 [INFO] PIM - CREATE PIM Instance ...
1/8/2013 22:11:39 [INFO] Utilities - File does not exist
1/8/2013 22:11:39 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/8/2013 22:11:39 [INFO] PIM - SUCCESS Created Tables.
1/8/2013 22:11:39 [INFO] PIM - PIM Database is Up To Date.
1/8/2013 22:11:39 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/8/2013 22:11:39 [INFO] PIM - Current db schema version on machine 1.
1/8/2013 22:11:39 [INFO] PIM - Current db schema version to install 1.
1/8/2013 22:11:39 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/8/2013 22:11:39 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:11:39 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/8/2013 22:11:39 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/8/2013 22:11:39 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/8/2013 22:11:39 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/8/2013 22:11:39 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/8/2013 22:11:39 [INFO] Setup - TimeLog: End initial checks
1/8/2013 22:11:39 [INFO] Setup - TimeLog: Begin Installing
1/8/2013 22:11:39 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:11:39 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:11:39 [ERROR] PIM - Package folder does not exist on the system.
1/8/2013 22:11:39 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/8/2013 22:11:39 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/8/2013 22:11:39 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/8/2013 22:11:45 [INFO] PIM - PIMSqlite closeDB status 0
1/8/2013 22:11:45 [INFO] PIM - FREE PIM Instance ...
1/8/2013 22:11:45 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/8/2013 22:11:45 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/8/2013 22:11:45 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/8/2013 22:11:45 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/8/2013 22:11:45 [INFO] Setup - End Adobe Setup. Exit code: 1
1/8/2013 22:12:48 [INFO] Setup - Build Version - 2.0.242.0
1/8/2013 22:12:48 [INFO] Setup - Logging Level verbosity Set to 4
1/8/2013 22:12:48 [INFO] Setup - Start Adobe Setup
1/8/2013 22:12:48 [INFO] Setup - TimeLog: Bootstrapper Start
1/8/2013 22:12:48 [INFO] Setup - TimeLog: Start initial checks
1/8/2013 22:12:49 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/8/2013 22:12:49 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/8/2013 22:12:49 [INFO] PIM - XML is valid
1/8/2013 22:12:49 [WARN] PIM - Failed to find Node
1/8/2013 22:12:49 [INFO] Setup - Found 3 packages in setup manifest
1/8/2013 22:12:50 [INFO] PIM - Build Version - 2.0.242.0
1/8/2013 22:12:50 [INFO] PIM - Logging Level verbosity Set to 4
1/8/2013 22:12:50 [INFO] Utilities - Folder does not exist
1/8/2013 22:12:50 [INFO] PIM - CREATE PIM Instance ...
1/8/2013 22:12:50 [INFO] Utilities - File does not exist
1/8/2013 22:12:50 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/8/2013 22:12:50 [INFO] PIM - SUCCESS Created Tables.
1/8/2013 22:12:50 [INFO] PIM - PIM Database is Up To Date.
1/8/2013 22:12:50 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/8/2013 22:12:50 [INFO] PIM - Current db schema version on machine 1.
1/8/2013 22:12:50 [INFO] PIM - Current db schema version to install 1.
1/8/2013 22:12:50 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/8/2013 22:12:50 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:12:50 [INFO] PIM - XML is valid
1/8/2013 22:12:50 [WARN] PIM - Failed to find Node
1/8/2013 22:12:50 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/8/2013 22:12:50 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/8/2013 22:12:50 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/8/2013 22:12:50 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/8/2013 22:12:50 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/8/2013 22:12:50 [INFO] Setup - TimeLog: End initial checks
1/8/2013 22:12:50 [INFO] Setup - TimeLog: Begin Installing
1/8/2013 22:12:50 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:12:50 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:12:50 [ERROR] PIM - Package folder does not exist on the system.
1/8/2013 22:12:50 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/8/2013 22:12:50 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/8/2013 22:12:50 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/8/2013 22:13:51 [INFO] PIM - PIMSqlite closeDB status 0
1/8/2013 22:13:51 [INFO] PIM - FREE PIM Instance ...
1/8/2013 22:13:51 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/8/2013 22:13:51 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/8/2013 22:13:51 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/8/2013 22:13:51 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/8/2013 22:13:51 [INFO] Setup - End Adobe Setup. Exit code: 1
1/8/2013 22:15:58 [INFO] Setup - Build Version - 2.0.242.0
1/8/2013 22:15:58 [INFO] Setup - Logging Level verbosity Set to 4
1/8/2013 22:15:58 [INFO] Setup - Start Adobe Setup
1/8/2013 22:15:58 [INFO] Setup - TimeLog: Bootstrapper Start
1/8/2013 22:15:58 [INFO] Setup - TimeLog: Start initial checks
1/8/2013 22:15:59 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/8/2013 22:15:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/8/2013 22:15:59 [INFO] PIM - XML is valid
1/8/2013 22:15:59 [WARN] PIM - Failed to find Node
1/8/2013 22:15:59 [INFO] Setup - Found 3 packages in setup manifest
1/8/2013 22:15:59 [WARN] Setup - Reboot is pending from earlier installation.
1/8/2013 22:15:59 [INFO] PIM - Build Version - 2.0.242.0
1/8/2013 22:15:59 [INFO] PIM - Logging Level verbosity Set to 4
1/8/2013 22:15:59 [INFO] Utilities - Folder does not exist
1/8/2013 22:15:59 [INFO] PIM - CREATE PIM Instance ...
1/8/2013 22:15:59 [INFO] Utilities - File does not exist
1/8/2013 22:15:59 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/8/2013 22:15:59 [INFO] PIM - SUCCESS Created Tables.
1/8/2013 22:15:59 [INFO] PIM - PIM Database is Up To Date.
1/8/2013 22:15:59 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/8/2013 22:15:59 [INFO] PIM - Current db schema version on machine 1.
1/8/2013 22:15:59 [INFO] PIM - Current db schema version to install 1.
1/8/2013 22:15:59 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/8/2013 22:15:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:15:59 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/8/2013 22:15:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/8/2013 22:15:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/8/2013 22:15:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/8/2013 22:15:59 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/8/2013 22:15:59 [INFO] Setup - TimeLog: End initial checks
1/8/2013 22:16:01 [INFO] Setup - TimeLog: Begin Installing
1/8/2013 22:16:01 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:16:01 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:16:01 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:16:01 [INFO] PIM - XML is valid
1/8/2013 22:16:01 [WARN] PIM - Failed to find Node
1/8/2013 22:16:01 [ERROR] PIM - Package folder does not exist on the system.
1/8/2013 22:16:01 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/8/2013 22:16:01 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/8/2013 22:16:01 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/8/2013 22:16:05 [INFO] PIM - PIMSqlite closeDB status 0
1/8/2013 22:16:05 [INFO] PIM - FREE PIM Instance ...
1/8/2013 22:16:05 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/8/2013 22:16:05 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/8/2013 22:16:05 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/8/2013 22:16:05 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/8/2013 22:16:05 [INFO] Setup - End Adobe Setup. Exit code: 1
1/8/2013 22:20:57 [INFO] Setup - Build Version - 2.0.242.0
1/8/2013 22:20:57 [INFO] Setup - Logging Level verbosity Set to 4
1/8/2013 22:20:57 [INFO] Setup - Start Adobe Setup
1/8/2013 22:20:57 [INFO] Setup - TimeLog: Bootstrapper Start
1/8/2013 22:20:57 [INFO] Setup - TimeLog: Start initial checks
1/8/2013 22:20:58 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/8/2013 22:20:58 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/8/2013 22:20:59 [INFO] PIM - XML is valid
1/8/2013 22:20:59 [WARN] PIM - Failed to find Node
1/8/2013 22:20:59 [INFO] Setup - Found 3 packages in setup manifest
1/8/2013 22:21:00 [INFO] PIM - Build Version - 2.0.242.0
1/8/2013 22:21:00 [INFO] PIM - Logging Level verbosity Set to 4
1/8/2013 22:21:00 [INFO] Utilities - Folder does not exist
1/8/2013 22:21:00 [INFO] PIM - CREATE PIM Instance ...
1/8/2013 22:21:00 [INFO] Utilities - File does not exist
1/8/2013 22:21:01 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/8/2013 22:21:01 [INFO] PIM - SUCCESS Created Tables.
1/8/2013 22:21:01 [INFO] PIM - PIM Database is Up To Date.
1/8/2013 22:21:01 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/8/2013 22:21:03 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/8/2013 22:21:03 [INFO] PIM - Current db schema version on machine 1.
1/8/2013 22:21:03 [INFO] PIM - Current db schema version to install 1.
1/8/2013 22:21:03 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/8/2013 22:21:03 [INFO] PIM - PIM Database is Up To Date.
1/8/2013 22:21:03 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:21:03 [INFO] PIM - XML is valid
1/8/2013 22:21:03 [WARN] PIM - Failed to find Node
1/8/2013 22:21:03 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/8/2013 22:21:03 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/8/2013 22:21:03 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/8/2013 22:21:03 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/8/2013 22:21:03 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/8/2013 22:21:03 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/8/2013 22:21:03 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/8/2013 22:21:04 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/8/2013 22:21:04 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/8/2013 22:21:04 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/8/2013 22:21:04 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/8/2013 22:21:04 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/8/2013 22:21:04 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/8/2013 22:21:04 [INFO] Setup - TimeLog: End initial checks
1/8/2013 22:21:04 [INFO] Setup - TimeLog: Begin Installing
1/8/2013 22:21:04 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:21:04 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:21:04 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:21:04 [INFO] PIM - XML is valid
1/8/2013 22:21:04 [WARN] PIM - Failed to find Node
1/8/2013 22:21:04 [ERROR] PIM - Package folder does not exist on the system.
1/8/2013 22:21:04 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/8/2013 22:21:04 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/8/2013 22:21:04 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/8/2013 22:21:28 [INFO] PIM - PIMSqlite closeDB status 0
1/8/2013 22:21:28 [INFO] PIM - FREE PIM Instance ...
1/8/2013 22:21:28 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/8/2013 22:21:28 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/8/2013 22:21:28 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/8/2013 22:21:28 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/8/2013 22:21:28 [INFO] Setup - End Adobe Setup. Exit code: 1
1/8/2013 22:22:01 [INFO] Setup - Build Version - 2.0.242.0
1/8/2013 22:22:01 [INFO] Setup - Logging Level verbosity Set to 4
1/8/2013 22:22:01 [INFO] Setup - Start Adobe Setup
1/8/2013 22:22:01 [INFO] Setup - TimeLog: Bootstrapper Start
1/8/2013 22:22:01 [INFO] Setup - TimeLog: Start initial checks
1/8/2013 22:22:02 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/8/2013 22:22:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/8/2013 22:22:02 [INFO] PIM - XML is valid
1/8/2013 22:22:02 [WARN] PIM - Failed to find Node
1/8/2013 22:22:02 [INFO] Setup - Found 3 packages in setup manifest
1/8/2013 22:22:02 [INFO] PIM - Build Version - 2.0.242.0
1/8/2013 22:22:02 [INFO] PIM - Logging Level verbosity Set to 4
1/8/2013 22:22:02 [INFO] Utilities - Folder does not exist
1/8/2013 22:22:02 [INFO] PIM - CREATE PIM Instance ...
1/8/2013 22:22:02 [INFO] Utilities - File does not exist
1/8/2013 22:22:02 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/8/2013 22:22:02 [INFO] PIM - SUCCESS Created Tables.
1/8/2013 22:22:02 [INFO] PIM - PIM Database is Up To Date.
1/8/2013 22:22:02 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/8/2013 22:22:02 [INFO] PIM - Current db schema version on machine 1.
1/8/2013 22:22:02 [INFO] PIM - Current db schema version to install 1.
1/8/2013 22:22:02 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/8/2013 22:22:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:22:02 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/8/2013 22:22:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/8/2013 22:22:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/8/2013 22:22:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/8/2013 22:22:02 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/8/2013 22:22:02 [INFO] Setup - TimeLog: End initial checks
1/8/2013 22:22:02 [INFO] Setup - TimeLog: Begin Installing
1/8/2013 22:22:02 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:22:02 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:22:02 [ERROR] PIM - Package folder does not exist on the system.
1/8/2013 22:22:02 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/8/2013 22:22:02 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/8/2013 22:22:02 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/8/2013 22:25:07 [INFO] PIM - PIMSqlite closeDB status 0
1/8/2013 22:25:07 [INFO] PIM - FREE PIM Instance ...
1/8/2013 22:25:07 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/8/2013 22:25:07 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/8/2013 22:25:07 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/8/2013 22:25:07 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/8/2013 22:25:07 [INFO] Setup - End Adobe Setup. Exit code: 1
1/8/2013 22:27:39 [INFO] Setup - Build Version - 2.0.242.0
1/8/2013 22:27:39 [INFO] Setup - Logging Level verbosity Set to 4
1/8/2013 22:27:39 [INFO] Setup - Start Adobe Setup
1/8/2013 22:27:39 [INFO] Setup - TimeLog: Bootstrapper Start
1/8/2013 22:27:39 [INFO] Setup - TimeLog: Start initial checks
1/8/2013 22:27:39 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/8/2013 22:27:39 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/8/2013 22:27:39 [INFO] PIM - XML is valid
1/8/2013 22:27:39 [WARN] PIM - Failed to find Node
1/8/2013 22:27:39 [INFO] Setup - Found 3 packages in setup manifest
1/8/2013 22:27:39 [INFO] PIM - Build Version - 2.0.242.0
1/8/2013 22:27:39 [INFO] PIM - Logging Level verbosity Set to 4
1/8/2013 22:27:39 [INFO] Utilities - Folder does not exist
1/8/2013 22:27:39 [INFO] PIM - CREATE PIM Instance ...
1/8/2013 22:27:39 [INFO] Utilities - File does not exist
1/8/2013 22:27:39 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/8/2013 22:27:40 [INFO] PIM - SUCCESS Created Tables.
1/8/2013 22:27:40 [INFO] PIM - PIM Database is Up To Date.
1/8/2013 22:27:40 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/8/2013 22:27:40 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/8/2013 22:27:40 [INFO] PIM - Current db schema version on machine 1.
1/8/2013 22:27:40 [INFO] PIM - Current db schema version to install 1.
1/8/2013 22:27:40 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/8/2013 22:27:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:27:40 [INFO] PIM - XML is valid
1/8/2013 22:27:40 [WARN] PIM - Failed to find Node
1/8/2013 22:27:40 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/8/2013 22:27:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/8/2013 22:27:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/8/2013 22:27:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/8/2013 22:27:40 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/8/2013 22:27:40 [INFO] Setup - TimeLog: End initial checks
1/8/2013 22:27:40 [INFO] Setup - TimeLog: Begin Installing
1/8/2013 22:27:40 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:27:40 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:27:40 [ERROR] PIM - Package folder does not exist on the system.
1/8/2013 22:27:40 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/8/2013 22:27:40 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/8/2013 22:27:40 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/8/2013 22:27:43 [INFO] PIM - PIMSqlite closeDB status 0
1/8/2013 22:27:43 [INFO] PIM - FREE PIM Instance ...
1/8/2013 22:27:43 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/8/2013 22:27:43 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/8/2013 22:27:43 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/8/2013 22:27:43 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/8/2013 22:27:43 [INFO] Setup - End Adobe Setup. Exit code: 1
1/8/2013 22:30:52 [INFO] Setup - Build Version - 2.0.242.0
1/8/2013 22:30:52 [INFO] Setup - Logging Level verbosity Set to 4
1/8/2013 22:30:52 [INFO] Setup - Start Adobe Setup
1/8/2013 22:30:52 [INFO] Setup - TimeLog: Bootstrapper Start
1/8/2013 22:30:52 [INFO] Setup - TimeLog: Start initial checks
1/8/2013 22:30:52 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/8/2013 22:30:52 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/8/2013 22:30:52 [INFO] PIM - XML is valid
1/8/2013 22:30:52 [WARN] PIM - Failed to find Node
1/8/2013 22:30:52 [INFO] Setup - Found 3 packages in setup manifest
1/8/2013 22:30:53 [INFO] PIM - Build Version - 2.0.242.0
1/8/2013 22:30:53 [INFO] PIM - Logging Level verbosity Set to 4
1/8/2013 22:30:53 [INFO] Utilities - Folder does not exist
1/8/2013 22:30:53 [INFO] PIM - CREATE PIM Instance ...
1/8/2013 22:30:53 [INFO] Utilities - File does not exist
1/8/2013 22:30:53 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/8/2013 22:30:53 [INFO] PIM - SUCCESS Created Tables.
1/8/2013 22:30:53 [INFO] PIM - PIM Database is Up To Date.
1/8/2013 22:30:53 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/8/2013 22:30:53 [INFO] PIM - Current db schema version on machine 1.
1/8/2013 22:30:53 [INFO] PIM - Current db schema version to install 1.
1/8/2013 22:30:53 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/8/2013 22:30:53 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:30:53 [INFO] PIM - XML is valid
1/8/2013 22:30:53 [WARN] PIM - Failed to find Node
1/8/2013 22:30:53 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/8/2013 22:30:53 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/8/2013 22:30:53 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/8/2013 22:30:53 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/8/2013 22:30:53 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/8/2013 22:30:53 [INFO] Setup - TimeLog: End initial checks
1/8/2013 22:30:53 [INFO] Setup - TimeLog: Begin Installing
1/8/2013 22:30:53 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:30:53 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 22:30:53 [ERROR] PIM - Package folder does not exist on the system.
1/8/2013 22:30:53 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/8/2013 22:30:53 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/8/2013 22:30:53 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/8/2013 22:30:55 [INFO] PIM - PIMSqlite closeDB status 0
1/8/2013 22:30:55 [INFO] PIM - FREE PIM Instance ...
1/8/2013 22:30:55 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/8/2013 22:30:55 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/8/2013 22:30:55 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/8/2013 22:30:55 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/8/2013 22:30:55 [INFO] Setup - End Adobe Setup. Exit code: 1
1/8/2013 23:59:25 [INFO] Setup - Build Version - 2.0.242.0
1/8/2013 23:59:25 [INFO] Setup - Logging Level verbosity Set to 4
1/8/2013 23:59:25 [INFO] Setup - Start Adobe Setup
1/8/2013 23:59:25 [INFO] Setup - TimeLog: Bootstrapper Start
1/8/2013 23:59:25 [INFO] Setup - TimeLog: Start initial checks
1/8/2013 23:59:25 [INFO] Setup - Dictionary Path: C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/8/2013 23:59:25 [INFO] PIM - Trying to access xml at path:C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\resources\setup.xml
1/8/2013 23:59:25 [INFO] PIM - XML is valid
1/8/2013 23:59:25 [WARN] PIM - Failed to find Node
1/8/2013 23:59:25 [INFO] Setup - Found 3 packages in setup manifest
1/8/2013 23:59:28 [INFO] PIM - Build Version - 2.0.242.0
1/8/2013 23:59:28 [INFO] PIM - Logging Level verbosity Set to 4
1/8/2013 23:59:28 [INFO] Utilities - Folder does not exist
1/8/2013 23:59:28 [INFO] PIM - CREATE PIM Instance ...
1/8/2013 23:59:28 [INFO] Utilities - File does not exist
1/8/2013 23:59:28 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/8/2013 23:59:29 [INFO] PIM - SUCCESS Created Tables.
1/8/2013 23:59:29 [INFO] PIM - PIM Database is Up To Date.
1/8/2013 23:59:29 [INFO] PIM - Updater Inventory location:C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\resources\updaterinventory.dll
1/8/2013 23:59:29 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/8/2013 23:59:29 [INFO] PIM - Current db schema version on machine 1.
1/8/2013 23:59:29 [INFO] PIM - Current db schema version to install 1.
1/8/2013 23:59:29 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/8/2013 23:59:29 [INFO] PIM - Trying to access xml at path:C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 23:59:29 [INFO] PIM - XML is valid
1/8/2013 23:59:29 [WARN] PIM - Failed to find Node
1/8/2013 23:59:29 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/8/2013 23:59:29 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/8/2013 23:59:29 [INFO] PIM - Trying to access xml at path:C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\UWA\UWA.pimx
1/8/2013 23:59:29 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/8/2013 23:59:29 [INFO] PIM - Trying to access xml at path:C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\DWA\DWA.pimx
1/8/2013 23:59:29 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/8/2013 23:59:29 [INFO] PIM - Trying to access xml at path:C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\LWA\LWA.pimx
1/8/2013 23:59:30 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/8/2013 23:59:30 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/8/2013 23:59:30 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/8/2013 23:59:30 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/8/2013 23:59:30 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/8/2013 23:59:30 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/8/2013 23:59:31 [INFO] Setup - TimeLog: End initial checks
1/8/2013 23:59:31 [INFO] Setup - TimeLog: Begin Installing
1/8/2013 23:59:31 [INFO] Setup - Start Installing core package - C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 23:59:31 [INFO] PIM - START installPackage at file C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 23:59:31 [INFO] PIM - Trying to access xml at path:C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\core\PDApp.pimx
1/8/2013 23:59:31 [INFO] PIM - XML is valid
1/8/2013 23:59:31 [WARN] PIM - Failed to find Node
1/8/2013 23:59:31 [ERROR] PIM - Package folder does not exist on the system.
1/8/2013 23:59:31 [INFO] Setup - Finished Installing core package - C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/8/2013 23:59:31 [FATAL] Setup - Error installing C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\core\PDApp.pimx package.
1/8/2013 23:59:31 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/8/2013 23:59:35 [INFO] PIM - PIMSqlite closeDB status 0
1/8/2013 23:59:35 [INFO] PIM - FREE PIM Instance ...
1/8/2013 23:59:35 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/8/2013 23:59:35 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/8/2013 23:59:35 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/8/2013 23:59:35 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/8/2013 23:59:35 [INFO] Setup - End Adobe Setup. Exit code: 1
1/9/2013 06:39:28 [INFO] Setup - Build Version - 2.0.242.0
1/9/2013 06:39:28 [INFO] Setup - Logging Level verbosity Set to 4
1/9/2013 06:39:28 [INFO] Setup - Start Adobe Setup
1/9/2013 06:39:28 [INFO] Setup - TimeLog: Bootstrapper Start
1/9/2013 06:39:28 [INFO] Setup - TimeLog: Start initial checks
1/9/2013 06:39:29 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/9/2013 06:39:30 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/9/2013 06:39:30 [INFO] PIM - XML is valid
1/9/2013 06:39:30 [WARN] PIM - Failed to find Node
1/9/2013 06:39:30 [INFO] Setup - Found 3 packages in setup manifest
1/9/2013 06:39:41 [INFO] PIM - Build Version - 2.0.242.0
1/9/2013 06:39:41 [INFO] PIM - Logging Level verbosity Set to 4
1/9/2013 06:39:41 [INFO] Utilities - Folder does not exist
1/9/2013 06:39:41 [INFO] PIM - CREATE PIM Instance ...
1/9/2013 06:39:41 [INFO] Utilities - File does not exist
1/9/2013 06:39:42 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 06:39:43 [INFO] PIM - SUCCESS Created Tables.
1/9/2013 06:39:43 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 06:39:43 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/9/2013 06:39:44 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 06:39:44 [INFO] PIM - Current db schema version on machine 1.
1/9/2013 06:39:44 [INFO] PIM - Current db schema version to install 1.
1/9/2013 06:39:44 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/9/2013 06:39:44 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 06:39:44 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 06:39:44 [INFO] PIM - XML is valid
1/9/2013 06:39:44 [WARN] PIM - Failed to find Node
1/9/2013 06:39:44 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/9/2013 06:39:44 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/9/2013 06:39:44 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/9/2013 06:39:44 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/9/2013 06:39:44 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/9/2013 06:39:44 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/9/2013 06:39:44 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/9/2013 06:39:45 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/9/2013 06:39:45 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/9/2013 06:39:45 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/9/2013 06:39:46 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/9/2013 06:39:46 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/9/2013 06:39:46 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/9/2013 06:39:46 [INFO] Setup - TimeLog: End initial checks
1/9/2013 06:39:46 [INFO] Setup - TimeLog: Begin Installing
1/9/2013 06:39:46 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 06:39:46 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 06:39:46 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 06:39:46 [INFO] PIM - XML is valid
1/9/2013 06:39:46 [WARN] PIM - Failed to find Node
1/9/2013 06:39:46 [ERROR] PIM - Package folder does not exist on the system.
1/9/2013 06:39:46 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/9/2013 06:39:46 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/9/2013 06:39:46 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/9/2013 06:40:30 [INFO] PIM - PIMSqlite closeDB status 0
1/9/2013 06:40:30 [INFO] PIM - FREE PIM Instance ...
1/9/2013 06:40:30 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/9/2013 06:40:30 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/9/2013 06:40:30 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/9/2013 06:40:30 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/9/2013 06:40:30 [INFO] Setup - End Adobe Setup. Exit code: 1
1/9/2013 06:50:30 [INFO] Setup - Build Version - 2.0.242.0
1/9/2013 06:50:30 [INFO] Setup - Logging Level verbosity Set to 4
1/9/2013 06:50:30 [INFO] Setup - Start Adobe Setup
1/9/2013 06:50:30 [INFO] Setup - TimeLog: Bootstrapper Start
1/9/2013 06:50:30 [INFO] Setup - TimeLog: Start initial checks
1/9/2013 06:50:31 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/9/2013 06:50:31 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/9/2013 06:50:31 [INFO] PIM - XML is valid
1/9/2013 06:50:31 [WARN] PIM - Failed to find Node
1/9/2013 06:50:31 [INFO] Setup - Found 3 packages in setup manifest
1/9/2013 06:50:32 [INFO] PIM - Build Version - 2.0.242.0
1/9/2013 06:50:32 [INFO] PIM - Logging Level verbosity Set to 4
1/9/2013 06:50:32 [INFO] Utilities - Folder does not exist
1/9/2013 06:50:32 [INFO] PIM - CREATE PIM Instance ...
1/9/2013 06:50:32 [INFO] Utilities - File does not exist
1/9/2013 06:50:32 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 06:50:32 [INFO] PIM - SUCCESS Created Tables.
1/9/2013 06:50:32 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 06:50:32 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/9/2013 06:50:33 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 06:50:33 [INFO] PIM - Current db schema version on machine 1.
1/9/2013 06:50:33 [INFO] PIM - Current db schema version to install 1.
1/9/2013 06:50:33 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/9/2013 06:50:33 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 06:50:33 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 06:50:33 [INFO] PIM - XML is valid
1/9/2013 06:50:33 [WARN] PIM - Failed to find Node
1/9/2013 06:50:33 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/9/2013 06:50:33 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/9/2013 06:50:33 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/9/2013 06:50:33 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/9/2013 06:50:33 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/9/2013 06:50:33 [INFO] Setup - TimeLog: End initial checks
1/9/2013 06:50:33 [INFO] Setup - TimeLog: Begin Installing
1/9/2013 06:50:33 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 06:50:33 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 06:50:33 [ERROR] PIM - Package folder does not exist on the system.
1/9/2013 06:50:33 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/9/2013 06:50:33 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/9/2013 06:50:33 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/9/2013 06:51:22 [INFO] PIM - PIMSqlite closeDB status 0
1/9/2013 06:51:22 [INFO] PIM - FREE PIM Instance ...
1/9/2013 06:51:22 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/9/2013 06:51:22 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/9/2013 06:51:22 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/9/2013 06:51:22 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/9/2013 06:51:22 [INFO] Setup - End Adobe Setup. Exit code: 1
1/9/2013 06:52:04 [INFO] Setup - Build Version - 2.0.242.0
1/9/2013 06:52:04 [INFO] Setup - Logging Level verbosity Set to 4
1/9/2013 06:52:04 [INFO] Setup - Start Adobe Setup
1/9/2013 06:52:04 [INFO] Setup - TimeLog: Bootstrapper Start
1/9/2013 06:52:04 [INFO] Setup - TimeLog: Start initial checks
1/9/2013 06:52:05 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/9/2013 06:52:05 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/9/2013 06:52:05 [INFO] PIM - XML is valid
1/9/2013 06:52:05 [WARN] PIM - Failed to find Node
1/9/2013 06:52:05 [INFO] Setup - Found 3 packages in setup manifest
1/9/2013 06:52:05 [INFO] PIM - Build Version - 2.0.242.0
1/9/2013 06:52:05 [INFO] PIM - Logging Level verbosity Set to 4
1/9/2013 06:52:05 [INFO] Utilities - Folder does not exist
1/9/2013 06:52:05 [INFO] PIM - CREATE PIM Instance ...
1/9/2013 06:52:05 [INFO] Utilities - File does not exist
1/9/2013 06:52:05 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 06:52:05 [INFO] PIM - SUCCESS Created Tables.
1/9/2013 06:52:05 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 06:52:05 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/9/2013 06:52:05 [INFO] PIM - Current db schema version on machine 1.
1/9/2013 06:52:05 [INFO] PIM - Current db schema version to install 1.
1/9/2013 06:52:05 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/9/2013 06:52:05 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 06:52:05 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/9/2013 06:52:05 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/9/2013 06:52:05 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/9/2013 06:52:05 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/9/2013 06:52:05 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/9/2013 06:52:05 [INFO] Setup - TimeLog: End initial checks
1/9/2013 06:52:05 [INFO] Setup - TimeLog: Begin Installing
1/9/2013 06:52:05 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 06:52:05 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 06:52:05 [ERROR] PIM - Package folder does not exist on the system.
1/9/2013 06:52:05 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/9/2013 06:52:05 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/9/2013 06:52:05 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/9/2013 06:57:38 [INFO] PIM - PIMSqlite closeDB status 0
1/9/2013 06:57:38 [INFO] PIM - FREE PIM Instance ...
1/9/2013 06:57:38 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/9/2013 06:57:38 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/9/2013 06:57:38 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/9/2013 06:57:38 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/9/2013 06:57:38 [INFO] Setup - End Adobe Setup. Exit code: 1
1/9/2013 06:57:39 [INFO] Setup - Build Version - 2.0.242.0
1/9/2013 06:57:39 [INFO] Setup - Logging Level verbosity Set to 4
1/9/2013 06:57:39 [INFO] Setup - Start Adobe Setup
1/9/2013 06:57:39 [INFO] Setup - TimeLog: Bootstrapper Start
1/9/2013 06:57:39 [INFO] Setup - TimeLog: Start initial checks
1/9/2013 06:57:40 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/9/2013 06:57:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/9/2013 06:57:40 [INFO] PIM - XML is valid
1/9/2013 06:57:40 [WARN] PIM - Failed to find Node
1/9/2013 06:57:40 [INFO] Setup - Found 3 packages in setup manifest
1/9/2013 06:57:40 [INFO] PIM - Build Version - 2.0.242.0
1/9/2013 06:57:40 [INFO] PIM - Logging Level verbosity Set to 4
1/9/2013 06:57:40 [INFO] Utilities - Folder does not exist
1/9/2013 06:57:40 [INFO] PIM - CREATE PIM Instance ...
1/9/2013 06:57:40 [INFO] Utilities - File does not exist
1/9/2013 06:57:40 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 06:57:40 [INFO] PIM - SUCCESS Created Tables.
1/9/2013 06:57:40 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 06:57:40 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/9/2013 06:57:40 [INFO] PIM - Current db schema version on machine 1.
1/9/2013 06:57:40 [INFO] PIM - Current db schema version to install 1.
1/9/2013 06:57:40 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/9/2013 06:57:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 06:57:40 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/9/2013 06:57:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/9/2013 06:57:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/9/2013 06:57:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/9/2013 06:57:40 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/9/2013 06:57:40 [INFO] Setup - TimeLog: End initial checks
1/9/2013 06:57:40 [INFO] Setup - TimeLog: Begin Installing
1/9/2013 06:57:40 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 06:57:40 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 06:57:40 [ERROR] PIM - Package folder does not exist on the system.
1/9/2013 06:57:40 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/9/2013 06:57:40 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/9/2013 06:57:40 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/9/2013 06:57:42 [INFO] PIM - PIMSqlite closeDB status 0
1/9/2013 06:57:42 [INFO] PIM - FREE PIM Instance ...
1/9/2013 06:57:42 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/9/2013 06:57:42 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/9/2013 06:57:42 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/9/2013 06:57:42 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/9/2013 06:57:42 [INFO] Setup - End Adobe Setup. Exit code: 1
1/9/2013 07:00:58 [INFO] Setup - Build Version - 2.0.242.0
1/9/2013 07:00:58 [INFO] Setup - Logging Level verbosity Set to 4
1/9/2013 07:00:58 [INFO] Setup - Start Adobe Setup
1/9/2013 07:00:58 [INFO] Setup - TimeLog: Bootstrapper Start
1/9/2013 07:00:58 [INFO] Setup - TimeLog: Start initial checks
1/9/2013 07:00:59 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/9/2013 07:01:00 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/9/2013 07:01:00 [INFO] PIM - XML is valid
1/9/2013 07:01:00 [WARN] PIM - Failed to find Node
1/9/2013 07:01:00 [INFO] Setup - Found 3 packages in setup manifest
1/9/2013 07:01:01 [INFO] PIM - Build Version - 2.0.242.0
1/9/2013 07:01:01 [INFO] PIM - Logging Level verbosity Set to 4
1/9/2013 07:01:01 [INFO] Utilities - Folder does not exist
1/9/2013 07:01:01 [INFO] PIM - CREATE PIM Instance ...
1/9/2013 07:01:01 [INFO] Utilities - File does not exist
1/9/2013 07:01:02 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 07:01:02 [INFO] PIM - SUCCESS Created Tables.
1/9/2013 07:01:02 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 07:01:02 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/9/2013 07:01:03 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 07:01:03 [INFO] PIM - Current db schema version on machine 1.
1/9/2013 07:01:03 [INFO] PIM - Current db schema version to install 1.
1/9/2013 07:01:03 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/9/2013 07:01:03 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 07:01:03 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:01:04 [INFO] PIM - XML is valid
1/9/2013 07:01:04 [WARN] PIM - Failed to find Node
1/9/2013 07:01:04 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/9/2013 07:01:04 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/9/2013 07:01:04 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/9/2013 07:01:04 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/9/2013 07:01:04 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/9/2013 07:01:04 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/9/2013 07:01:04 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/9/2013 07:01:04 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/9/2013 07:01:04 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/9/2013 07:01:04 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/9/2013 07:01:05 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/9/2013 07:01:05 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/9/2013 07:01:05 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/9/2013 07:01:05 [INFO] Setup - TimeLog: End initial checks
1/9/2013 07:01:05 [INFO] Setup - TimeLog: Begin Installing
1/9/2013 07:01:05 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:01:05 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:01:05 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:01:05 [INFO] PIM - XML is valid
1/9/2013 07:01:05 [WARN] PIM - Failed to find Node
1/9/2013 07:01:05 [ERROR] PIM - Package folder does not exist on the system.
1/9/2013 07:01:05 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/9/2013 07:01:05 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
Return Value of pim_installPackage = -1
1/9/2013 07:01:05 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/9/2013 07:04:10 [INFO] PIM - PIMSqlite closeDB status 0
1/9/2013 07:04:10 [INFO] PIM - FREE PIM Instance ...
1/9/2013 07:04:10 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/9/2013 07:04:10 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/9/2013 07:04:10 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/9/2013 07:04:10 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/9/2013 07:04:10 [INFO] Setup - End Adobe Setup. Exit code: 1
1/9/2013 07:04:17 [INFO] Setup - Build Version - 2.0.242.0
1/9/2013 07:04:17 [INFO] Setup - Logging Level verbosity Set to 4
1/9/2013 07:04:17 [INFO] Setup - Start Adobe Setup
1/9/2013 07:04:17 [INFO] Setup - TimeLog: Bootstrapper Start
1/9/2013 07:04:17 [INFO] Setup - TimeLog: Start initial checks
1/9/2013 07:04:18 [INFO] Setup - Build Version - 2.0.242.0
1/9/2013 07:04:18 [INFO] Setup - Logging Level verbosity Set to 4
1/9/2013 07:04:18 [INFO] Setup - Start Adobe Setup
1/9/2013 07:04:18 [INFO] Setup - TimeLog: Bootstrapper Start
1/9/2013 07:04:18 [INFO] Setup - TimeLog: Start initial checks
1/9/2013 07:04:18 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/9/2013 07:04:19 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/9/2013 07:04:19 [INFO] PIM - XML is valid
1/9/2013 07:04:19 [WARN] PIM - Failed to find Node
1/9/2013 07:04:19 [INFO] Setup - Found 3 packages in setup manifest
1/9/2013 07:04:20 [INFO] PIM - Build Version - 2.0.242.0
1/9/2013 07:04:20 [INFO] PIM - Logging Level verbosity Set to 4
1/9/2013 07:04:20 [INFO] Utilities - Folder does not exist
1/9/2013 07:04:20 [INFO] PIM - CREATE PIM Instance ...
1/9/2013 07:04:20 [INFO] Utilities - File does not exist
1/9/2013 07:04:20 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 07:04:20 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/9/2013 07:04:20 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/9/2013 07:04:20 [INFO] PIM - XML is valid
1/9/2013 07:04:20 [WARN] PIM - Failed to find Node
1/9/2013 07:04:20 [INFO] Setup - Found 3 packages in setup manifest
1/9/2013 07:04:20 [ERROR] Setup - Another Deployment workflow already running.
1/9/2013 07:04:20 [FATAL] Setup - Errors faced in OS requirement checks. Exiting...
1/9/2013 07:04:20 [INFO] PIM - SUCCESS Created Tables.
1/9/2013 07:04:20 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 07:04:20 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/9/2013 07:04:20 [INFO] PIM - Current db schema version on machine 1.
1/9/2013 07:04:20 [INFO] PIM - Current db schema version to install 1.
1/9/2013 07:04:20 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/9/2013 07:04:20 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:04:20 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/9/2013 07:04:20 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/9/2013 07:04:20 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/9/2013 07:04:20 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/9/2013 07:04:20 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/9/2013 07:04:20 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/9/2013 07:04:20 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/9/2013 07:04:21 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/9/2013 07:04:21 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/9/2013 07:04:21 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/9/2013 07:04:21 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/9/2013 07:04:21 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/9/2013 07:04:21 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/9/2013 07:04:21 [INFO] Setup - TimeLog: End initial checks
1/9/2013 07:04:21 [INFO] Setup - TimeLog: Begin Installing
1/9/2013 07:04:21 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:04:21 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:04:21 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:04:21 [INFO] PIM - XML is valid
1/9/2013 07:04:21 [WARN] PIM - Failed to find Node
1/9/2013 07:04:21 [ERROR] PIM - Package folder does not exist on the system.
1/9/2013 07:04:21 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/9/2013 07:04:21 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/9/2013 07:04:21 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/9/2013 07:04:24 [ERROR] Setup - Another Deployment workflow already running.
1/9/2013 07:04:24 [FATAL] Setup - Errors faced in OS requirement checks. Exiting...
1/9/2013 07:04:26 [ERROR] Setup - Another Deployment workflow already running.
1/9/2013 07:04:26 [FATAL] Setup - Errors faced in OS requirement checks. Exiting...
1/9/2013 07:04:26 [INFO] Setup - End Adobe Setup. Exit code: 1
1/9/2013 07:04:29 [INFO] PIM - PIMSqlite closeDB status 0
1/9/2013 07:04:29 [INFO] PIM - FREE PIM Instance ...
1/9/2013 07:04:29 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/9/2013 07:04:29 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/9/2013 07:04:29 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/9/2013 07:04:29 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/9/2013 07:04:29 [INFO] Setup - End Adobe Setup. Exit code: 1
1/9/2013 07:04:39 [INFO] Setup - Build Version - 2.0.242.0
1/9/2013 07:04:39 [INFO] Setup - Logging Level verbosity Set to 4
1/9/2013 07:04:39 [INFO] Setup - Start Adobe Setup
1/9/2013 07:04:39 [INFO] Setup - TimeLog: Bootstrapper Start
1/9/2013 07:04:39 [INFO] Setup - TimeLog: Start initial checks
1/9/2013 07:04:41 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/9/2013 07:04:41 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/9/2013 07:04:41 [INFO] PIM - XML is valid
1/9/2013 07:04:41 [WARN] PIM - Failed to find Node
1/9/2013 07:04:41 [INFO] Setup - Found 3 packages in setup manifest
1/9/2013 07:04:41 [INFO] PIM - Build Version - 2.0.242.0
1/9/2013 07:04:41 [INFO] PIM - Logging Level verbosity Set to 4
1/9/2013 07:04:41 [INFO] Utilities - Folder does not exist
1/9/2013 07:04:41 [INFO] PIM - CREATE PIM Instance ...
1/9/2013 07:04:41 [INFO] Utilities - File does not exist
1/9/2013 07:04:41 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 07:04:41 [INFO] PIM - SUCCESS Created Tables.
1/9/2013 07:04:41 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 07:04:41 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/9/2013 07:04:41 [INFO] PIM - Current db schema version on machine 1.
1/9/2013 07:04:41 [INFO] PIM - Current db schema version to install 1.
1/9/2013 07:04:41 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/9/2013 07:04:41 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:04:41 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/9/2013 07:04:41 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/9/2013 07:04:41 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/9/2013 07:04:41 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/9/2013 07:04:41 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/9/2013 07:04:41 [INFO] Setup - TimeLog: End initial checks
1/9/2013 07:04:41 [INFO] Setup - TimeLog: Begin Installing
1/9/2013 07:04:41 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:04:41 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:04:41 [ERROR] PIM - Package folder does not exist on the system.
1/9/2013 07:04:41 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/9/2013 07:04:41 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/9/2013 07:04:41 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/9/2013 07:05:21 [INFO] PIM - PIMSqlite closeDB status 0
1/9/2013 07:05:21 [INFO] PIM - FREE PIM Instance ...
1/9/2013 07:05:21 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/9/2013 07:05:21 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/9/2013 07:05:21 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/9/2013 07:05:21 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/9/2013 07:05:21 [INFO] Setup - End Adobe Setup. Exit code: 1
1/9/2013 07:13:01 [INFO] Setup - Build Version - 2.0.242.0
1/9/2013 07:13:01 [INFO] Setup - Logging Level verbosity Set to 4
1/9/2013 07:13:01 [INFO] Setup - Start Adobe Setup
1/9/2013 07:13:01 [INFO] Setup - TimeLog: Bootstrapper Start
1/9/2013 07:13:01 [INFO] Setup - TimeLog: Start initial checks
1/9/2013 07:13:02 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/9/2013 07:13:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/9/2013 07:13:02 [INFO] PIM - XML is valid
1/9/2013 07:13:02 [WARN] PIM - Failed to find Node
1/9/2013 07:13:02 [INFO] Setup - Found 3 packages in setup manifest
1/9/2013 07:13:02 [INFO] PIM - Build Version - 2.0.242.0
1/9/2013 07:13:02 [INFO] PIM - Logging Level verbosity Set to 4
1/9/2013 07:13:02 [INFO] Utilities - Folder does not exist
1/9/2013 07:13:02 [INFO] PIM - CREATE PIM Instance ...
1/9/2013 07:13:02 [INFO] Utilities - File does not exist
1/9/2013 07:13:02 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 07:13:02 [INFO] PIM - SUCCESS Created Tables.
1/9/2013 07:13:02 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 07:13:02 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/9/2013 07:13:02 [INFO] PIM - Current db schema version on machine 1.
1/9/2013 07:13:02 [INFO] PIM - Current db schema version to install 1.
1/9/2013 07:13:02 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/9/2013 07:13:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:13:02 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/9/2013 07:13:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/9/2013 07:13:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/9/2013 07:13:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/9/2013 07:13:02 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/9/2013 07:13:02 [INFO] Setup - TimeLog: End initial checks
1/9/2013 07:13:02 [INFO] Setup - TimeLog: Begin Installing
1/9/2013 07:13:02 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:13:02 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:13:02 [ERROR] PIM - Package folder does not exist on the system.
1/9/2013 07:13:02 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/9/2013 07:13:02 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/9/2013 07:13:02 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/9/2013 07:13:05 [INFO] PIM - PIMSqlite closeDB status 0
1/9/2013 07:13:05 [INFO] PIM - FREE PIM Instance ...
1/9/2013 07:13:05 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/9/2013 07:13:05 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/9/2013 07:13:05 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/9/2013 07:13:05 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/9/2013 07:13:05 [INFO] Setup - End Adobe Setup. Exit code: 1
1/9/2013 07:18:54 [INFO] Setup - Build Version - 2.0.242.0
1/9/2013 07:18:54 [INFO] Setup - Logging Level verbosity Set to 4
1/9/2013 07:18:54 [INFO] Setup - Start Adobe Setup
1/9/2013 07:18:54 [INFO] Setup - TimeLog: Bootstrapper Start
1/9/2013 07:18:54 [INFO] Setup - TimeLog: Start initial checks
1/9/2013 07:18:54 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/9/2013 07:18:54 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/9/2013 07:18:54 [INFO] PIM - XML is valid
1/9/2013 07:18:54 [WARN] PIM - Failed to find Node
1/9/2013 07:18:54 [INFO] Setup - Found 3 packages in setup manifest
1/9/2013 07:18:54 [INFO] PIM - Build Version - 2.0.242.0
1/9/2013 07:18:54 [INFO] PIM - Logging Level verbosity Set to 4
1/9/2013 07:18:54 [INFO] Utilities - Folder does not exist
1/9/2013 07:18:54 [INFO] PIM - CREATE PIM Instance ...
1/9/2013 07:18:54 [INFO] Utilities - File does not exist
1/9/2013 07:18:54 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 07:18:55 [INFO] PIM - SUCCESS Created Tables.
1/9/2013 07:18:55 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 07:18:55 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/9/2013 07:18:55 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 07:18:55 [INFO] PIM - Current db schema version on machine 1.
1/9/2013 07:18:55 [INFO] PIM - Current db schema version to install 1.
1/9/2013 07:18:55 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/9/2013 07:18:55 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:18:55 [INFO] PIM - XML is valid
1/9/2013 07:18:55 [WARN] PIM - Failed to find Node
1/9/2013 07:18:55 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/9/2013 07:18:55 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/9/2013 07:18:55 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/9/2013 07:18:55 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/9/2013 07:18:55 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/9/2013 07:18:55 [INFO] Setup - TimeLog: End initial checks
1/9/2013 07:18:55 [INFO] Setup - TimeLog: Begin Installing
1/9/2013 07:18:55 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:18:55 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:18:55 [ERROR] PIM - Package folder does not exist on the system.
1/9/2013 07:18:55 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/9/2013 07:18:55 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/9/2013 07:18:55 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/9/2013 07:19:30 [INFO] PIM - PIMSqlite closeDB status 0
1/9/2013 07:19:30 [INFO] PIM - FREE PIM Instance ...
1/9/2013 07:19:30 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/9/2013 07:19:30 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/9/2013 07:19:30 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/9/2013 07:19:30 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/9/2013 07:19:30 [INFO] Setup - End Adobe Setup. Exit code: 1
1/9/2013 07:21:39 [INFO] PIM - Build Version - 1.5.115.0
1/9/2013 07:21:39 [INFO] PIM - Logging Level verbosity Set to 4
1/9/2013 07:21:39 [INFO] Utilities - Folder does not exist
1/9/2013 07:21:39 [INFO] PIM - CREATE PIM Instance ...
1/9/2013 07:21:39 [INFO] Utilities - File does not exist
1/9/2013 07:21:39 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 07:21:39 [INFO] PIM - SUCCESS Created Tables.
1/9/2013 07:21:39 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 07:21:39 [INFO] PIM - Updater Inventory location:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\resources\updaterinventory.dll
1/9/2013 07:21:39 [INFO] PIM - Current db schema version on machine 1.
1/9/2013 07:21:39 [INFO] PIM - Current db schema version to install 1.
1/9/2013 07:21:39 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/9/2013 07:21:39 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\core\PDApp.pimx
1/9/2013 07:21:39 [INFO] PIM - XML is valid
1/9/2013 07:21:39 [WARN] PIM - Failed to find Node
1/9/2013 07:21:39 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Package id EA2BC663-B77E-49CD-A81D-1CBE763C9CE2 is a old Package, new is installed on the system. Size required: 0
1/9/2013 07:21:39 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\UWA\UWA.pimx
1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Package id 7A28185C-2F17-48A0-A0AC-A470B17743CC is a old Package, new is installed on the system. Size required: 10166919
1/9/2013 07:21:39 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\DWA\DWA.pimx
1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Package id 28D6E8A4-E4EC-45B0-85C4-E749B884D817 is a old Package, new is installed on the system. Size required: 4753339
1/9/2013 07:21:39 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\LWA\LWA.pimx
1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Package id 42509BD9-5E28-4A2A-AEA7-2535481A969B is a old Package, new is installed on the system. Size required: 11019801
1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/9/2013 07:21:38 [INFO] Setup - Build Version - 1.5.115.0
1/9/2013 07:21:38 [INFO] Setup - Logging Level verbosity Set to 4
1/9/2013 07:21:38 [INFO] Setup - Start Adobe Setup
1/9/2013 07:21:38 [INFO] Setup - TimeLog: Bootstrapper Start
1/9/2013 07:21:38 [INFO] Setup - TimeLog: Start initial checks
1/9/2013 07:21:38 [INFO] Setup - Dictionary Path: C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\resources\Dictionary\en_US\stringTable.zdct
1/9/2013 07:21:38 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\resources\setup.xml
1/9/2013 07:21:38 [INFO] PIM - XML is valid
1/9/2013 07:21:38 [WARN] PIM - Failed to find Node
1/9/2013 07:21:38 [INFO] Setup - Found 3 packages in setup manifest
1/9/2013 07:21:39 [INFO] Setup - TimeLog: End initial checks
1/9/2013 07:21:39 [INFO] Setup - TimeLog: Begin Installing
1/9/2013 07:21:39 [INFO] Setup - Start Installing core package - C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\core\PDApp.pimx
1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/9/2013 07:21:39 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/9/2013 07:21:39 [INFO] PIM - START installPackage at file C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\core\PDApp.pimx
1/9/2013 07:21:39 [ERROR] PIM - Package folder does not exist on the system.
1/9/2013 07:21:41 [INFO] PIM - PIMSqlite closeDB status 0
1/9/2013 07:21:41 [INFO] PIM - FREE PIM Instance ...
1/9/2013 07:21:39 [INFO] Setup - Finished Installing core package - C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\core\PDApp.pimx, Return status: -1
1/9/2013 07:21:39 [FATAL] Setup - Error installing C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\core\PDApp.pimx package.
1/9/2013 07:21:39 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/9/2013 07:21:41 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/9/2013 07:21:41 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/9/2013 07:21:41 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/9/2013 07:21:41 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/9/2013 07:21:41 [INFO] Setup - End Adobe Setup. Exit code: 1
1/9/2013 07:21:55 [INFO] Setup - Build Version - 2.0.242.0
1/9/2013 07:21:55 [INFO] Setup - Logging Level verbosity Set to 4
1/9/2013 07:21:55 [INFO] Setup - Start Adobe Setup
1/9/2013 07:21:55 [INFO] Setup - TimeLog: Bootstrapper Start
1/9/2013 07:21:55 [INFO] Setup - TimeLog: Start initial checks
1/9/2013 07:21:55 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/9/2013 07:21:55 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/9/2013 07:21:55 [INFO] PIM - XML is valid
1/9/2013 07:21:55 [WARN] PIM - Failed to find Node
1/9/2013 07:21:55 [INFO] Setup - Found 3 packages in setup manifest
1/9/2013 07:21:56 [INFO] PIM - Build Version - 2.0.242.0
1/9/2013 07:21:56 [INFO] PIM - Logging Level verbosity Set to 4
1/9/2013 07:21:56 [INFO] Utilities - Folder does not exist
1/9/2013 07:21:56 [INFO] PIM - CREATE PIM Instance ...
1/9/2013 07:21:56 [INFO] Utilities - File does not exist
1/9/2013 07:21:56 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 07:21:56 [INFO] PIM - SUCCESS Created Tables.
1/9/2013 07:21:56 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 07:21:56 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/9/2013 07:21:56 [INFO] PIM - Current db schema version on machine 1.
1/9/2013 07:21:56 [INFO] PIM - Current db schema version to install 1.
1/9/2013 07:21:56 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/9/2013 07:21:56 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:21:56 [INFO] PIM - XML is valid
1/9/2013 07:21:56 [WARN] PIM - Failed to find Node
1/9/2013 07:21:56 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/9/2013 07:21:56 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/9/2013 07:21:56 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/9/2013 07:21:56 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/9/2013 07:21:56 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/9/2013 07:21:56 [INFO] Setup - TimeLog: End initial checks
1/9/2013 07:21:56 [INFO] Setup - TimeLog: Begin Installing
1/9/2013 07:21:56 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:21:56 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:21:56 [ERROR] PIM - Package folder does not exist on the system.
1/9/2013 07:21:56 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/9/2013 07:21:56 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/9/2013 07:21:56 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/9/2013 07:22:00 [INFO] PIM - PIMSqlite closeDB status 0
1/9/2013 07:22:00 [INFO] PIM - FREE PIM Instance ...
1/9/2013 07:22:00 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/9/2013 07:22:00 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/9/2013 07:22:00 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/9/2013 07:22:00 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/9/2013 07:22:00 [INFO] Setup - End Adobe Setup. Exit code: 1
1/9/2013 07:30:01 [INFO] Setup - Build Version - 2.0.242.0
1/9/2013 07:30:01 [INFO] Setup - Logging Level verbosity Set to 4
1/9/2013 07:30:01 [INFO] Setup - Start Adobe Setup
1/9/2013 07:30:01 [INFO] Setup - TimeLog: Bootstrapper Start
1/9/2013 07:30:01 [INFO] Setup - TimeLog: Start initial checks
1/9/2013 07:30:03 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
1/9/2013 07:30:03 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
1/9/2013 07:30:03 [INFO] PIM - XML is valid
1/9/2013 07:30:03 [WARN] PIM - Failed to find Node
1/9/2013 07:30:03 [INFO] Setup - Found 3 packages in setup manifest
1/9/2013 07:30:04 [INFO] PIM - Build Version - 2.0.242.0
1/9/2013 07:30:04 [INFO] PIM - Logging Level verbosity Set to 4
1/9/2013 07:30:04 [INFO] Utilities - Folder does not exist
1/9/2013 07:30:04 [INFO] PIM - CREATE PIM Instance ...
1/9/2013 07:30:05 [INFO] Utilities - File does not exist
1/9/2013 07:30:05 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 07:30:06 [INFO] PIM - SUCCESS Created Tables.
1/9/2013 07:30:06 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 07:30:06 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
1/9/2013 07:30:07 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
1/9/2013 07:30:07 [INFO] PIM - Current db schema version on machine 1.
1/9/2013 07:30:07 [INFO] PIM - Current db schema version to install 1.
1/9/2013 07:30:07 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
1/9/2013 07:30:07 [INFO] PIM - PIM Database is Up To Date.
1/9/2013 07:30:07 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:30:07 [INFO] PIM - XML is valid
1/9/2013 07:30:07 [WARN] PIM - Failed to find Node
1/9/2013 07:30:07 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
1/9/2013 07:30:07 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
1/9/2013 07:30:07 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
1/9/2013 07:30:07 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
1/9/2013 07:30:07 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
1/9/2013 07:30:07 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
1/9/2013 07:30:07 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
1/9/2013 07:30:09 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
1/9/2013 07:30:09 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
1/9/2013 07:30:09 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
1/9/2013 07:30:10 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
1/9/2013 07:30:10 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
1/9/2013 07:30:10 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
1/9/2013 07:30:10 [INFO] Setup - TimeLog: End initial checks
1/9/2013 07:30:10 [INFO] Setup - TimeLog: Begin Installing
1/9/2013 07:30:10 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:30:10 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:30:10 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
1/9/2013 07:30:10 [INFO] PIM - XML is valid
1/9/2013 07:30:10 [WARN] PIM - Failed to find Node
1/9/2013 07:30:10 [ERROR] PIM - Package folder does not exist on the system.
1/9/2013 07:30:10 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
1/9/2013 07:30:10 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
1/9/2013 07:30:10 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
1/9/2013 07:30:39 [INFO] PIM - PIMSqlite closeDB status 0
1/9/2013 07:30:39 [INFO] PIM - FREE PIM Instance ...
1/9/2013 07:30:39 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
1/9/2013 07:30:39 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
1/9/2013 07:30:39 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
1/9/2013 07:30:39 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
1/9/2013 07:30:39 [INFO] Setup - End Adobe Setup. Exit code: 1
9. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
pebble Dec 12, 2013 7:32 AM (in response to SamanthamChavez)I have the same problem using os x 10.9.
I checked the file size of the Akaimai Download Manage and it was 2.4GB, my file size is 2.57GB. Is that ok that it's larger?
I went to the Library to find the log files and there is no Adobe folder. Is there somewhere else I can look? Here's a screen shot of my Library/Logs folder.
10. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
pebble Dec 12, 2013 7:39 AM (in response to pebble)I found this PDApp.log file which contained Adobe CS5... here is the log: Wed Dec 11 22:38:04 2013 [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 22:38:04 2013 [INFO] PIM - Logging Level verbosity Set to 4 Wed Dec 11 22:38:04 2013 [WARN] PIM - Detected Old content in USF trying to delte it... Wed Dec 11 22:38:04 2013 [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x23c430 {NSUnderlyingError=0x23c3d0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/, NSUserStringVariant=( Remove )}. Wed Dec 11 22:38:04 2013 [WARN] PIM - Failed to delete Old content in USF. Wed Dec 11 22:38:04 2013 [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 22:38:04 2013 [INFO] PIM - Logging Level verbosity Set to 4 Wed Dec 11 22:38:04 2013 [INFO] PIM - CREATE PIM Instance ... Wed Dec 11 22:38:04 2013 [INFO] PIM - trying to createOrUpdatePIMDbSchema. Wed Dec 11 22:38:04 2013 [INFO] PIM - SUCCESS Created Tables. Wed Dec 11 22:38:04 2013 [INFO] PIM - PIM Database is Up To Date. Wed Dec 11 22:38:04 2013 [INFO] PIM - Updater Inventory location:/Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/Install.app/Contents/Frameworks/UpdaterInventory.framework/UpdaterInventory Wed Dec 11 22:38:04 2013 [INFO] PIM - BEGIN pim_requireUpdateAtPath... Wed Dec 11 22:38:04 2013 [INFO] PIM - PIM CF PATH :/Library/Application Support/Adobe/OOBE/PDApp Wed Dec 11 22:38:04 2013 [INFO] PIM - PIM db doesnot exits at the destination ... req update YES. Wed Dec 11 22:38:04 2013 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 103182610 Wed Dec 11 22:38:04 2013 [INFO] PIM - freeDiskSpace ... 250678407168 Wed Dec 11 22:38:04 2013 [INFO] PIM - START installPackage at file /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx Wed Dec 11 22:38:04 2013 [INFO] PIM - SUCCESS insertPackageUpdateList. Wed Dec 11 22:38:04 2013 [INFO] PIM - SUCCESS insertAppletRegInfoList. Wed Dec 11 22:38:05 2013 [FATAL] PIM - Error in copy. Wed Dec 11 22:38:04 2013 [INFO] Setup - Build Version - 1.0.175.0 Wed Dec 11 22:38:04 2013 [INFO] Setup - Logging Level verbosity Set to 4 Wed Dec 11 22:38:04 2013 [INFO] Setup - TimeLog: Bootstrapper Start Wed Dec 11 22:38:04 2013 [INFO] Setup - TimeLog: Start initial checks Wed Dec 11 22:38:04 2013 [INFO] Setup - Launch Path set to /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard Wed Dec 11 22:38:04 2013 [INFO] Setup - Found 3 packages in setup manifest Wed Dec 11 22:38:04 2013 [INFO] Setup - Latest Build not installed in ACF. Wed Dec 11 22:38:04 2013 [INFO] Setup - TimeLog: End initial checks Wed Dec 11 22:38:04 2013 [INFO] Setup - TimeLog: Begin Installing Wed Dec 11 22:38:05 2013 [FATAL] Setup - Error installing core /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx package. pim_installPackage returned -8 Wed Dec 11 22:38:05 2013 [FATAL] Setup - Error installing Packages. Wed Dec 11 22:38:34 2013 [ERROR] Setup - Error while cleaning up. Error: Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x15f370 {NSUnderlyingError=0x15f050 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp, NSUserStringVariant=( Remove )} Wed Dec 11 22:38:05 2013 [FATAL] PIM - Error Failed to extract assets... Wed Dec 11 22:38:05 2013 [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“core” couldn’t be removed because you don’t have permission to access it." UserInfo=0x455560 {NSUnderlyingError=0x44d1c0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/core, NSUserStringVariant=( Remove )}. Wed Dec 11 22:38:05 2013 [FATAL] PIM - Error Failed to remove the Package copied Wed Dec 11 22:38:34 2013 [INFO] PIM - PIMSqlite closeDB status 0 Wed Dec 11 22:38:34 2013 [INFO] PIM - FREE PIM Instance ... Wed Dec 11 22:38:34 2013 [INFO] Setup - Exiting Installer with Code: 0 Wed Dec 11 22:41:02 2013 [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 22:41:02 2013 [INFO] PIM - Logging Level verbosity Set to 4 Wed Dec 11 22:41:02 2013 [WARN] PIM - Detected Old content in USF trying to delte it... Wed Dec 11 22:41:02 2013 [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x38c330 {NSUnderlyingError=0x38c2d0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/, NSUserStringVariant=( Remove )}. Wed Dec 11 22:41:02 2013 [WARN] PIM - Failed to delete Old content in USF. Wed Dec 11 22:41:02 2013 [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 22:41:02 2013 [INFO] PIM - Logging Level verbosity Set to 4 Wed Dec 11 22:41:02 2013 [INFO] PIM - CREATE PIM Instance ... Wed Dec 11 22:41:02 2013 [INFO] PIM - trying to createOrUpdatePIMDbSchema. Wed Dec 11 22:41:02 2013 [INFO] PIM - SUCCESS Created Tables. Wed Dec 11 22:41:02 2013 [INFO] PIM - PIM Database is Up To Date. Wed Dec 11 22:41:02 2013 [INFO] PIM - Updater Inventory location:/Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/Install.app/Contents/Frameworks/UpdaterInventory.framework/UpdaterInventory Wed Dec 11 22:41:02 2013 [INFO] PIM - BEGIN pim_requireUpdateAtPath... Wed Dec 11 22:41:02 2013 [INFO] PIM - PIM CF PATH :/Library/Application Support/Adobe/OOBE/PDApp Wed Dec 11 22:41:02 2013 [INFO] PIM - PIM db doesnot exits at the destination ... req update YES. Wed Dec 11 22:41:02 2013 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 103182610 Wed Dec 11 22:41:02 2013 [INFO] PIM - freeDiskSpace ... 249871843328 Wed Dec 11 22:41:02 2013 [INFO] PIM - START installPackage at file /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx Wed Dec 11 22:41:02 2013 [INFO] PIM - SUCCESS insertPackageUpdateList. Wed Dec 11 22:41:02 2013 [INFO] PIM - SUCCESS insertAppletRegInfoList. Wed Dec 11 22:41:03 2013 [FATAL] PIM - Error in copy. Wed Dec 11 22:48:01 2013 [INFO] Setup - Build Version - 1.0.175.0 Wed Dec 11 22:48:01 2013 [INFO] Setup - Logging Level verbosity Set to 4 Wed Dec 11 22:48:01 2013 [INFO] Setup - TimeLog: Bootstrapper Start Wed Dec 11 22:48:01 2013 [INFO] Setup - TimeLog: Start initial checks Wed Dec 11 22:48:01 2013 [INFO] Setup - Launch Path set to /Applications Wed Dec 11 22:48:01 2013 [INFO] Setup - Found 3 packages in setup manifest Wed Dec 11 22:48:01 2013 [ERROR] Setup - Another Deployment workflow already running. Wed Dec 11 22:48:01 2013 [INFO] Setup - TimeLog: End initial checks Wed Dec 11 22:48:06 2013 [INFO] Setup - Exiting Installer with Code: 0 Wed Dec 11 22:41:02 2013 [INFO] Setup - Build Version - 1.0.175.0 Wed Dec 11 22:41:02 2013 [INFO] Setup - Logging Level verbosity Set to 4 Wed Dec 11 22:41:02 2013 [INFO] Setup - TimeLog: Bootstrapper Start Wed Dec 11 22:41:02 2013 [INFO] Setup - TimeLog: Start initial checks Wed Dec 11 22:41:02 2013 [INFO] Setup - Launch Path set to /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard Wed Dec 11 22:41:02 2013 [INFO] Setup - Found 3 packages in setup manifest Wed Dec 11 22:41:02 2013 [INFO] Setup - Latest Build not installed in ACF. Wed Dec 11 22:41:02 2013 [INFO] Setup - TimeLog: End initial checks Wed Dec 11 22:41:02 2013 [INFO] Setup - TimeLog: Begin Installing Wed Dec 11 22:41:03 2013 [FATAL] Setup - Error installing core /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx package. pim_installPackage returned -8 Wed Dec 11 22:41:03 2013 [FATAL] Setup - Error installing Packages. Wed Dec 11 22:49:46 2013 [ERROR] Setup - Error while cleaning up. Error: Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x384140 {NSUnderlyingError=0x3b70e0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp, NSUserStringVariant=( Remove )} Wed Dec 11 22:41:03 2013 [FATAL] PIM - Error Failed to extract assets... Wed Dec 11 22:41:03 2013 [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“core” couldn’t be removed because you don’t have permission to access it." UserInfo=0x46f460 {NSUnderlyingError=0x4721e0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/core, NSUserStringVariant=( Remove )}. Wed Dec 11 22:41:03 2013 [FATAL] PIM - Error Failed to remove the Package copied Wed Dec 11 22:49:46 2013 [INFO] PIM - PIMSqlite closeDB status 0 Wed Dec 11 22:49:46 2013 [INFO] PIM - FREE PIM Instance ... Wed Dec 11 22:49:46 2013 [INFO] Setup - Exiting Installer with Code: 0 Wed Dec 11 23:07:52 2013 [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:07:52 2013 [INFO] PIM - Logging Level verbosity Set to 4 Wed Dec 11 23:07:52 2013 [WARN] PIM - Detected Old content in USF trying to delte it... Wed Dec 11 23:07:52 2013 [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x71e1b0 {NSUnderlyingError=0x71e150 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/, NSUserStringVariant=( Remove )}. Wed Dec 11 23:07:52 2013 [WARN] PIM - Failed to delete Old content in USF. Wed Dec 11 23:07:52 2013 [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:07:52 2013 [INFO] PIM - Logging Level verbosity Set to 4 Wed Dec 11 23:07:52 2013 [INFO] PIM - CREATE PIM Instance ... Wed Dec 11 23:07:52 2013 [INFO] PIM - trying to createOrUpdatePIMDbSchema. Wed Dec 11 23:07:52 2013 [INFO] PIM - SUCCESS Created Tables. Wed Dec 11 23:07:52 2013 [INFO] PIM - PIM Database is Up To Date. Wed Dec 11 23:07:52 2013 [INFO] PIM - Updater Inventory location:/Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/Install.app/Contents/Frameworks/UpdaterInventory.framework/UpdaterInventory Wed Dec 11 23:07:52 2013 [INFO] PIM - BEGIN pim_requireUpdateAtPath... Wed Dec 11 23:07:52 2013 [INFO] PIM - PIM CF PATH :/Library/Application Support/Adobe/OOBE/PDApp Wed Dec 11 23:07:52 2013 [INFO] PIM - PIM db doesnot exits at the destination ... req update YES. Wed Dec 11 23:07:52 2013 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 103182610 Wed Dec 11 23:07:52 2013 [INFO] PIM - freeDiskSpace ... 248216338432 Wed Dec 11 23:07:52 2013 [INFO] PIM - START installPackage at file /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx Wed Dec 11 23:07:52 2013 [INFO] PIM - SUCCESS insertPackageUpdateList. Wed Dec 11 23:07:52 2013 [INFO] PIM - SUCCESS insertAppletRegInfoList. Wed Dec 11 23:07:53 2013 [FATAL] PIM - Error in copy. Wed Dec 11 23:07:51 2013 [INFO] Setup - Build Version - 1.0.175.0 Wed Dec 11 23:07:51 2013 [INFO] Setup - Logging Level verbosity Set to 4 Wed Dec 11 23:07:51 2013 [INFO] Setup - TimeLog: Bootstrapper Start Wed Dec 11 23:07:52 2013 [INFO] Setup - TimeLog: Start initial checks Wed Dec 11 23:07:52 2013 [INFO] Setup - Launch Path set to /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard Wed Dec 11 23:07:52 2013 [INFO] Setup - Found 3 packages in setup manifest Wed Dec 11 23:07:52 2013 [INFO] Setup - Latest Build not installed in ACF. Wed Dec 11 23:07:52 2013 [INFO] Setup - TimeLog: End initial checks Wed Dec 11 23:07:52 2013 [INFO] Setup - TimeLog: Begin Installing Wed Dec 11 23:07:53 2013 [FATAL] Setup - Error installing core /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx package. pim_installPackage returned -8 Wed Dec 11 23:07:53 2013 [FATAL] Setup - Error installing Packages. Wed Dec 11 23:07:56 2013 [ERROR] Setup - Error while cleaning up. Error: Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x733f60 {NSUnderlyingError=0x73a570 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp, NSUserStringVariant=( Remove )} Wed Dec 11 23:07:53 2013 [FATAL] PIM - Error Failed to extract assets... Wed Dec 11 23:07:53 2013 [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“core” couldn’t be removed because you don’t have permission to access it." UserInfo=0x65edb0 {NSUnderlyingError=0x65efd0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/core, NSUserStringVariant=( Remove )}. Wed Dec 11 23:07:53 2013 [FATAL] PIM - Error Failed to remove the Package copied Wed Dec 11 23:07:56 2013 [INFO] PIM - PIMSqlite closeDB status 0 Wed Dec 11 23:07:56 2013 [INFO] PIM - FREE PIM Instance ... Wed Dec 11 23:07:56 2013 [INFO] Setup - Exiting Installer with Code: 0 Wed Dec 11 23:18:17 2013 [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:18:17 2013 [INFO] PIM - Logging Level verbosity Set to 4 Wed Dec 11 23:18:17 2013 [WARN] PIM - Detected Old content in USF trying to delte it... Wed Dec 11 23:18:17 2013 [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x45f040 {NSUnderlyingError=0x45ef30 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/, NSUserStringVariant=( Remove )}. Wed Dec 11 23:18:17 2013 [WARN] PIM - Failed to delete Old content in USF. Wed Dec 11 23:18:17 2013 [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:18:17 2013 [INFO] PIM - Logging Level verbosity Set to 4 Wed Dec 11 23:18:17 2013 [INFO] PIM - CREATE PIM Instance ... Wed Dec 11 23:18:17 2013 [INFO] PIM - trying to createOrUpdatePIMDbSchema. Wed Dec 11 23:18:17 2013 [INFO] PIM - SUCCESS Created Tables. Wed Dec 11 23:18:17 2013 [INFO] PIM - PIM Database is Up To Date. Wed Dec 11 23:18:17 2013 [INFO] PIM - Updater Inventory location:/Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/Install.app/Contents/Frameworks/UpdaterInventory.framework/UpdaterInventory Wed Dec 11 23:18:17 2013 [INFO] PIM - BEGIN pim_requireUpdateAtPath... Wed Dec 11 23:18:17 2013 [INFO] PIM - PIM CF PATH :/Library/Application Support/Adobe/OOBE/PDApp Wed Dec 11 23:18:17 2013 [INFO] PIM - PIM db doesnot exits at the destination ... req update YES. Wed Dec 11 23:18:17 2013 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 103182610 Wed Dec 11 23:18:17 2013 [INFO] PIM - freeDiskSpace ... 247905804288 Wed Dec 11 23:18:17 2013 [INFO] PIM - START installPackage at file /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx Wed Dec 11 23:18:17 2013 [INFO] PIM - SUCCESS insertPackageUpdateList. Wed Dec 11 23:18:17 2013 [INFO] PIM - SUCCESS insertAppletRegInfoList. Wed Dec 11 23:18:19 2013 [FATAL] PIM - Error in copy. Wed Dec 11 23:18:17 2013 [INFO] Setup - Build Version - 1.0.175.0 Wed Dec 11 23:18:17 2013 [INFO] Setup - Logging Level verbosity Set to 4 Wed Dec 11 23:18:17 2013 [INFO] Setup - TimeLog: Bootstrapper Start Wed Dec 11 23:18:17 2013 [INFO] Setup - TimeLog: Start initial checks Wed Dec 11 23:18:17 2013 [INFO] Setup - Launch Path set to /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard Wed Dec 11 23:18:17 2013 [INFO] Setup - Found 3 packages in setup manifest Wed Dec 11 23:18:17 2013 [INFO] Setup - Latest Build not installed in ACF. Wed Dec 11 23:18:17 2013 [INFO] Setup - TimeLog: End initial checks Wed Dec 11 23:18:17 2013 [INFO] Setup - TimeLog: Begin Installing Wed Dec 11 23:18:19 2013 [FATAL] Setup - Error installing core /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx package. pim_installPackage returned -8 Wed Dec 11 23:18:19 2013 [FATAL] Setup - Error installing Packages. Wed Dec 11 23:18:20 2013 [ERROR] Setup - Error while cleaning up. Error: Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x47bd70 {NSUnderlyingError=0x47c5b0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp, NSUserStringVariant=( Remove )} Wed Dec 11 23:18:19 2013 [FATAL] PIM - Error Failed to extract assets... Wed Dec 11 23:18:19 2013 [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“core” couldn’t be removed because you don’t have permission to access it." UserInfo=0x424e120 {NSUnderlyingError=0x424e350 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/core, NSUserStringVariant=( Remove )}. Wed Dec 11 23:18:19 2013 [FATAL] PIM - Error Failed to remove the Package copied Wed Dec 11 23:18:20 2013 [INFO] PIM - PIMSqlite closeDB status 0 Wed Dec 11 23:18:20 2013 [INFO] PIM - FREE PIM Instance ... Wed Dec 11 23:18:20 2013 [INFO] Setup - Exiting Installer with Code: 0 Wed Dec 11 23:21:43 2013 [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:21:43 2013 [INFO] PIM - Logging Level verbosity Set to 4 Wed Dec 11 23:21:43 2013 [WARN] PIM - Detected Old content in USF trying to delte it... Wed Dec 11 23:21:43 2013 [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x6358d0 {NSUnderlyingError=0x634180 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/, NSUserStringVariant=( Remove )}. Wed Dec 11 23:21:43 2013 [WARN] PIM - Failed to delete Old content in USF. Wed Dec 11 23:21:43 2013 [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:21:43 2013 [INFO] PIM - Logging Level verbosity Set to 4 Wed Dec 11 23:21:43 2013 [INFO] PIM - CREATE PIM Instance ... Wed Dec 11 23:21:43 2013 [INFO] PIM - trying to createOrUpdatePIMDbSchema. Wed Dec 11 23:21:43 2013 [INFO] PIM - SUCCESS Created Tables. Wed Dec 11 23:21:43 2013 [INFO] PIM - PIM Database is Up To Date. Wed Dec 11 23:21:43 2013 [INFO] PIM - Updater Inventory location:/Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/Install.app/Contents/Frameworks/UpdaterInventory.framework/UpdaterInventory Wed Dec 11 23:21:43 2013 [INFO] PIM - BEGIN pim_requireUpdateAtPath... Wed Dec 11 23:21:43 2013 [INFO] PIM - PIM CF PATH :/Library/Application Support/Adobe/OOBE/PDApp Wed Dec 11 23:21:43 2013 [INFO] PIM - PIM db doesnot exits at the destination ... req update YES. Wed Dec 11 23:21:43 2013 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 103182610 Wed Dec 11 23:21:43 2013 [INFO] PIM - freeDiskSpace ... 248414744576 Wed Dec 11 23:21:43 2013 [INFO] PIM - START installPackage at file /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx Wed Dec 11 23:21:43 2013 [INFO] PIM - SUCCESS insertPackageUpdateList. Wed Dec 11 23:21:43 2013 [INFO] PIM - SUCCESS insertAppletRegInfoList. Wed Dec 11 23:21:44 2013 [FATAL] PIM - Error in copy. Wed Dec 11 23:21:43 2013 [INFO] Setup - Build Version - 1.0.175.0 Wed Dec 11 23:21:43 2013 [INFO] Setup - Logging Level verbosity Set to 4 Wed Dec 11 23:21:43 2013 [INFO] Setup - TimeLog: Bootstrapper Start Wed Dec 11 23:21:43 2013 [INFO] Setup - TimeLog: Start initial checks Wed Dec 11 23:21:43 2013 [INFO] Setup - Launch Path set to /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard Wed Dec 11 23:21:43 2013 [INFO] Setup - Found 3 packages in setup manifest Wed Dec 11 23:21:43 2013 [INFO] Setup - Latest Build not installed in ACF. Wed Dec 11 23:21:43 2013 [INFO] Setup - TimeLog: End initial checks Wed Dec 11 23:21:43 2013 [INFO] Setup - TimeLog: Begin Installing Wed Dec 11 23:21:44 2013 [FATAL] Setup - Error installing core /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx package. pim_installPackage returned -8 Wed Dec 11 23:21:44 2013 [FATAL] Setup - Error installing Packages. Wed Dec 11 23:21:47 2013 [ERROR] Setup - Error while cleaning up. Error: Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x255f90 {NSUnderlyingError=0x2534b0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp, NSUserStringVariant=( Remove )} Wed Dec 11 23:21:44 2013 [FATAL] PIM - Error Failed to extract assets... Wed Dec 11 23:21:44 2013 [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“core” couldn’t be removed because you don’t have permission to access it." UserInfo=0x254870 {NSUnderlyingError=0x255710 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/core, NSUserStringVariant=( Remove )}. Wed Dec 11 23:21:44 2013 [FATAL] PIM - Error Failed to remove the Package copied Wed Dec 11 23:21:47 2013 [INFO] PIM - PIMSqlite closeDB status 0 Wed Dec 11 23:21:47 2013 [INFO] PIM - FREE PIM Instance ... Wed Dec 11 23:21:47 2013 [INFO] Setup - Exiting Installer with Code: 0 Wed Dec 11 23:26:07 2013 [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:26:07 2013 [INFO] PIM - Logging Level verbosity Set to 4 Wed Dec 11 23:26:07 2013 [WARN] PIM - Detected Old content in USF trying to delte it... Wed Dec 11 23:26:07 2013 [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x24a810 {NSUnderlyingError=0x24a7a0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/, NSUserStringVariant=( Remove )}. Wed Dec 11 23:26:07 2013 [WARN] PIM - Failed to delete Old content in USF. Wed Dec 11 23:26:07 2013 [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:26:07 2013 [INFO] PIM - Logging Level verbosity Set to 4 Wed Dec 11 23:26:07 2013 [INFO] PIM - CREATE PIM Instance ... Wed Dec 11 23:26:07 2013 [INFO] PIM - trying to createOrUpdatePIMDbSchema. Wed Dec 11 23:26:07 2013 [INFO] PIM - SUCCESS Created Tables. Wed Dec 11 23:26:07 2013 [INFO] PIM - PIM Database is Up To Date. Wed Dec 11 23:26:07 2013 [INFO] PIM - Updater Inventory location:/Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/Install.app/Contents/Frameworks/UpdaterInventory.framework/UpdaterInventory Wed Dec 11 23:26:07 2013 [INFO] PIM - BEGIN pim_requireUpdateAtPath... Wed Dec 11 23:26:07 2013 [INFO] PIM - PIM CF PATH :/Library/Application Support/Adobe/OOBE/PDApp Wed Dec 11 23:26:07 2013 [INFO] PIM - PIM db doesnot exits at the destination ... req update YES. Wed Dec 11 23:26:07 2013 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 103182610 Wed Dec 11 23:26:07 2013 [INFO] PIM - freeDiskSpace ... 248442183680 Wed Dec 11 23:26:07 2013 [INFO] PIM - START installPackage at file /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx Wed Dec 11 23:26:07 2013 [INFO] PIM - SUCCESS insertPackageUpdateList. Wed Dec 11 23:26:07 2013 [INFO] PIM - SUCCESS insertAppletRegInfoList. Wed Dec 11 23:26:08 2013 [FATAL] PIM - Error in copy. Wed Dec 11 23:26:07 2013 [INFO] Setup - Build Version - 1.0.175.0 Wed Dec 11 23:26:07 2013 [INFO] Setup - Logging Level verbosity Set to 4 Wed Dec 11 23:26:07 2013 [INFO] Setup - TimeLog: Bootstrapper Start Wed Dec 11 23:26:07 2013 [INFO] Setup - TimeLog: Start initial checks Wed Dec 11 23:26:07 2013 [INFO] Setup - Launch Path set to /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard Wed Dec 11 23:26:07 2013 [INFO] Setup - Found 3 packages in setup manifest Wed Dec 11 23:26:07 2013 [INFO] Setup - Latest Build not installed in ACF. Wed Dec 11 23:26:07 2013 [INFO] Setup - TimeLog: End initial checks Wed Dec 11 23:26:07 2013 [INFO] Setup - TimeLog: Begin Installing Wed Dec 11 23:26:08 2013 [FATAL] Setup - Error installing core /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx package. pim_installPackage returned -8 Wed Dec 11 23:26:08 2013 [FATAL] Setup - Error installing Packages. Wed Dec 11 23:43:37 2013 [ERROR] Setup - Error while cleaning up. Error: Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x45a1e0 {NSUnderlyingError=0x44e760 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp, NSUserStringVariant=( Remove )} Wed Dec 11 23:26:08 2013 [FATAL] PIM - Error Failed to extract assets... Wed Dec 11 23:26:08 2013 [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“core” couldn’t be removed because you don’t have permission to access it." UserInfo=0x24a410 {NSUnderlyingError=0x2476d0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/core, NSUserStringVariant=( Remove )}. Wed Dec 11 23:26:08 2013 [FATAL] PIM - Error Failed to remove the Package copied Wed Dec 11 23:43:37 2013 [INFO] PIM - PIMSqlite closeDB status 0 Wed Dec 11 23:43:37 2013 [INFO] PIM - FREE PIM Instance ... Wed Dec 11 23:43:37 2013 [INFO] Setup - Exiting Installer with Code: 0 Thu Dec 12 09:16:11 2013 [INFO] PIM - Build Version - 1.0.175.0 Thu Dec 12 09:16:11 2013 [INFO] PIM - Logging Level verbosity Set to 4 Thu Dec 12 09:16:11 2013 [WARN] PIM - Detected Old content in USF trying to delte it... Thu Dec 12 09:16:11 2013 [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x34e5e0 {NSUnderlyingError=0x3446f0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/, NSUserStringVariant=( Remove )}. Thu Dec 12 09:16:11 2013 [WARN] PIM - Failed to delete Old content in USF. Thu Dec 12 09:16:11 2013 [INFO] PIM - Build Version - 1.0.175.0 Thu Dec 12 09:16:11 2013 [INFO] PIM - Logging Level verbosity Set to 4 Thu Dec 12 09:16:11 2013 [INFO] PIM - CREATE PIM Instance ... Thu Dec 12 09:16:11 2013 [INFO] PIM - trying to createOrUpdatePIMDbSchema. Thu Dec 12 09:16:11 2013 [INFO] PIM - SUCCESS Created Tables. Thu Dec 12 09:16:11 2013 [INFO] PIM - PIM Database is Up To Date. Thu Dec 12 09:16:11 2013 [INFO] PIM - Updater Inventory location:/Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/Install.app/Contents/Frameworks/UpdaterInventory.framework/UpdaterInventory Thu Dec 12 09:16:11 2013 [INFO] PIM - BEGIN pim_requireUpdateAtPath... Thu Dec 12 09:16:11 2013 [INFO] PIM - PIM CF PATH :/Library/Application Support/Adobe/OOBE/PDApp Thu Dec 12 09:16:11 2013 [INFO] PIM - PIM db doesnot exits at the destination ... req update YES. Thu Dec 12 09:16:11 2013 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 103182610 Thu Dec 12 09:16:11 2013 [INFO] PIM - freeDiskSpace ... 241479671808 Thu Dec 12 09:16:11 2013 [INFO] PIM - START installPackage at file /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx Thu Dec 12 09:16:11 2013 [INFO] PIM - SUCCESS insertPackageUpdateList. Thu Dec 12 09:16:11 2013 [INFO] PIM - SUCCESS insertAppletRegInfoList. Thu Dec 12 09:16:12 2013 [FATAL] PIM - Error in copy. Thu Dec 12 09:16:11 2013 [INFO] Setup - Build Version - 1.0.175.0 Thu Dec 12 09:16:11 2013 [INFO] Setup - Logging Level verbosity Set to 4 Thu Dec 12 09:16:11 2013 [INFO] Setup - TimeLog: Bootstrapper Start Thu Dec 12 09:16:11 2013 [INFO] Setup - TimeLog: Start initial checks Thu Dec 12 09:16:11 2013 [INFO] Setup - Launch Path set to /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard Thu Dec 12 09:16:11 2013 [INFO] Setup - Found 3 packages in setup manifest Thu Dec 12 09:16:11 2013 [INFO] Setup - Latest Build not installed in ACF. Thu Dec 12 09:16:11 2013 [INFO] Setup - TimeLog: End initial checks Thu Dec 12 09:16:11 2013 [INFO] Setup - TimeLog: Begin Installing Thu Dec 12 09:16:12 2013 [FATAL] Setup - Error installing core /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx package. pim_installPackage returned -8 Thu Dec 12 09:16:12 2013 [FATAL] Setup - Error installing Packages. Thu Dec 12 09:16:22 2013 [ERROR] Setup - Error while cleaning up. Error: Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x37f300 {NSUnderlyingError=0x344dd0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp, NSUserStringVariant=( Remove )} Thu Dec 12 09:16:12 2013 [FATAL] PIM - Error Failed to extract assets... Thu Dec 12 09:16:12 2013 [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“core” couldn’t be removed because you don’t have permission to access it." UserInfo=0x7335e0 {NSUnderlyingError=0x735530 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/core, NSUserStringVariant=( Remove )}. Thu Dec 12 09:16:12 2013 [FATAL] PIM - Error Failed to remove the Package copied Thu Dec 12 09:16:22 2013 [INFO] PIM - PIMSqlite closeDB status 0 Thu Dec 12 09:16:22 2013 [INFO] PIM - FREE PIM Instance ... Thu Dec 12 09:16:22 2013 [INFO] Setup - Exiting Installer with Code: 0
11. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
polave Dec 26, 2013 4:51 PM (in response to Arpit Kapoor)Hello,
I have the disc version.
I have just upgraded iMac's and I'm trying to install CS5 into my new iMac....and get the same response.
When I run Support, it tells me there is no issue.
This is my error log SUMMARY. If you could analyze it and provide suggestions please?
Many thanks,
PatrickSUMMARY
- 0 fatal error(s), 3 error(s), 0 warning(s)
----------- Payload: {AD7623FD-F90A-4181-A37C-63342ACC3FA7} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul 15.0.2.0 -----------
ERROR: DF019: Unable to locate file to patch at "/Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Resources/es.lproj/InfoPlist.strings"(Seq 52)
ERROR: DW063: Command ARKPatchCommand failed.(Seq 52)
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul: Install failed
Please search the above error/warning string(s) to find when the error occurred.
These errors resulted in installer Exit Code mentioned below.
12. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
ilovethesims4 Jul 12, 2014 9:55 PM (in response to Siuwongau)I cant find installer in my logs folder on my mac
13. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
RNLDEdits Aug 5, 2014 2:42 PM (in response to Siuwongau)I have the same problem.. with any kind of After Effects from CS6 to CC (2013).. whats the deal?
15. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
Trompie Oct 26, 2014 1:00 PM (in response to Siuwongau)This is my log files. Please analyse
2014/10/26 9:21:54,261 PM CoreServicesUIAgent[3428]: Error -60005 creating authorization
2014/10/26 9:21:54,605 PM CoreServicesUIAgent[3428]: Error: qtn_file_apply_to_path error: Read-only file system
What should I do to fix?
