What is the path format for a custom button on main window when it is a local help topic? I am using RH9 and trying to setup Button 1 or Button 2 to go to a help topic in my current Help project. Is a Web URL the only thing that works?
Hi there
If the topic is in the root level of the project it is simply the topic file name. If it is inside a folder, it's the folder name/file name.
Cheers... Rick
Cannot get the "Reply to Message" to work on the forum.
Anyway, thanks for the reply. What you suggested was the way I thought it
should work. But, unless I start the path with something like HTTP to
insinuate a web address, the button won't even display.
Hi there
I'm moments away from a meeting but afterwards will create a brief video to show the steps.
Might be as long as two or three hours... Rick
Hello again
See if the video linked below helps any.
http://screencast.com/t/eXDbSuP1FPQg
Cheers... Rick
Again, I cannot get the "Reply" to work on the forum.
I appreciate so much Rick, you taking the time to do a video. What is
interesting here is that I was doing the process almost verbatim to your
video, however, this time I went to the topic file properties and copied
the file name like you did, had to add a folder name in front of the file
name and bingo it worked. Apparently, when typing in the path, I was doing
something it did not like. Anyway, mission accomplished and thanks again.
Mike
