I keep trying to install flash for win7 pro 64 bit and it stops half way through and even though I've closed IE, it will not get past 50%. The other thing that concerns me is that flash 32 bit is installed but I can't uninstall it even using adobe's uninstall. I get the same error message that I have to close IE even though it is not open. I've been through all of the troubleshooting steps. I have adobe in my accepted list with https:
Anyone know the answer to this? I can't watch anything online without it. If not, can someone tell me how to contact adobe for this problem because I have no other options.
http://forums.adobe.com/message/5266110
The Flash Player installer WILL install both 64 and 32 bit plugins. The Flash Player(32bit) you see in the control panel is the Global Settings manager, which is a 32 bit app, but it manages both plugins.
Go to: C/Windows/System32/Macromed - there's a Flash folder THAT's the 32 bit plugin.
Go to: C/Windows/SysWOW64/Macromed - there's a Flash folder - THAT's the 64 bit plugin.
I already did that. I use Task Manager all the time. I use IE and Chrome and checked to see if either of these services were running and they were not running. But now I see the rest of your answer and will try that. I really hate having to use forums because most of the time, no one pays attention. But, thanks, Mike, for paying attention.
Do I delete both? Or just the 64-bit? I'll be out for a while so no need to rush. Thanks, Mike.
Hi ladygeek,
The uninstaller should install both 32- and 64-bit versions of the player. There aren't separate uninstallers. If the 32-bit is not being uninstalled there could be an issue. Can you post the FlashInstall.log file found in both C:/Windows/System32/Macromed/Flash AND C:/Windows/SysWow64/Macromed/Flash? If the contents of the files are too large you can send me a private message with the contents of the files.
Thank you in advance.
Maria
Here's the log. Thanks again.
=O====== M/11.5.502.135 2012-12-15+20-32-06.034 ========
0000 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001113 C:\Windows\SysWOW64\Macromed\Flash
* 3
0001 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000010
"C:\ProgramData\Adobe\AIH.be8c985f293b5564c726f5adc6bdb778d77c90d1\install_flash_player_ax.exe"
-install -iv 8 -au 0
0002 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0003 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0004 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0005 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0006 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000011 1
0007 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe
Flash Player ActiveX/ 2
0008 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000013
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_135.ocx
0009 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000015
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.exe
0010 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000016
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.dll
0011 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0012 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0013 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000021
C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0014 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000012
=X====== M/11.5.502.135 2012-12-15+20-32-11.265 ========
2013-3-28+21-33-6.771 Re: How can I get past "close IE" to continue the install even though IE is closed? 1226 1062
=O====== M/11.6.602.180 2013-03-28+21-32-59.642 ========
0000 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000010 FlashPlayerInstaller.exe -install -iv 9
0001 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000011 1
0002 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0003 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000013
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_180.ocx
0004 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000015
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe
0005 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000016
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.dll
0006 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0007 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0008 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
0009 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
0010 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000021
0011 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001106
0012 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001106
0013 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024
C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
=X====== M/11.6.602.180 2013-03-28+21-33-08.331 ========
=O====== M/11.2.202.228 2013-04-06+01-32-58.373 ========
0000 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000010 "C:\Program Files (x86)\Flash Player
Pro\FlashActivex.exe" -install
0001 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001013
=X====== M/11.2.202.228 2013-04-06+01-32-58.838 ========
2013-4-6+2-50-39.64 Re: How can I get past "close IE" to continue the install even though IE is closed? 1226 1062
=O====== M/11.6.602.180 2013-04-06+02-50-35.367 ========
"C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe"
-maintain activex
0001 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001015
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe 5
0002 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000018
0003 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001015
0004 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001015
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.dll 5
0005 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000018
0006 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001015
Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0008 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
0009 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0010 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0011 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001037 Software\Microsoft\Code Store Database\Distribution
Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
0012 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001021
0013 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0014 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0015 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0016 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0017 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001037 Software\Microsoft\Windows\CurrentVersion\Control
Panel\Extended
Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
2
0018 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0019 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0020 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001015
0021 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001015
0022 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000011 1
0023 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000012
=X====== M/11.6.602.180 2013-04-06+02-50-41.731 ========
=O====== M/11.6.602.180 2013-04-06+03-03-39.682 ========
"C:\Users\Owner\AppData\Local\Temp\{1C7DA24F-9A85-4354-B01B-0E400C687BD0}\InstallFlashPlayer.exe"
-iv 6
0001 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0002 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0005 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000011 1
0006 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0008 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File
Execution Options
FlashUtil32_11_6_602_180_ActiveX.exe/ 2
0009 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000013
0010 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000015
0011 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000016
0012 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0013 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0014 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000021
0015 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000012
=X====== M/11.6.602.180 2013-04-06+03-04-05.768 ========
=O====== M/11.6.602.180 2013-04-06+03-03-34.471 ========
C:\Users\Owner\AppData\Local\Temp\IDC2.tmp\FP_AX_CAB_INSTALLER64.exe
=X====== M/11.6.602.180 2013-04-06+03-04-05.799 ========
=O====== M/11.7.700.169 2013-04-15+22-20-37.668 ========
"C:\ProgramData\Adobe\AIH.541299abd1ae43ee4cdc1e1bae6baa3d92d8c911\install_flash_player_ax.exe"
-install -iv 8
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_180.ocx 5
0004 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000018
0005 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001015
0006 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000013
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_169.ocx
0007 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000015
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.exe
0008 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000016
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.dll
0009 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0010 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0011 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
0012 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
0014 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001106
0015 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001106
0016 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024
0017 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000012
=X====== M/11.7.700.169 2013-04-15+22-20-44.397 ========
=O====== M/11.7.700.169 2013-04-17+21-04-19.667 ========
-install -iv 8
0001 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001041
=X====== M/11.7.700.169 2013-04-17+21-04-20.111 ========
=O====== M/11.7.700.169 2013-04-17+21-04-34.544 ========
-install -iv 8
=X====== M/11.7.700.169 2013-04-17+21-04-40.864 ========
=O====== M/11.7.700.169 2013-04-18+20-54-08.606 ========
-install -iv 8
=X====== M/11.7.700.169 2013-04-18+20-54-09.001 ========
=O====== M/11.7.700.169 2013-04-18+20-54-55.906 ========
-install -iv 8
=X====== M/11.7.700.169 2013-04-18+20-55-01.498 ========
=O====== M/11.7.700.169 2013-04-20+19-06-50.292 ========
-install -iv 8
=X====== M/11.7.700.169 2013-04-20+19-06-50.752 ========
=O====== M/11.7.700.169 2013-04-20+19-07-01.517 ========
-install -iv 8
=X====== M/11.7.700.169 2013-04-20+19-07-01.836 ========
=O====== M/11.7.700.169 2013-04-20+19-07-29.112 ========
-install -iv 8
=X====== M/11.7.700.169 2013-04-20+19-07-37.244 ========
2013-5-15+16-5-0.242 Re: How can I get past "close IE" to continue the install even though IE is closed? 1223 1056
2013-5-15+17-5-0.238 Re: How can I get past "close IE" to continue the install even though IE is closed? 1223 1056
2013-5-15+21-5-38.607 Re: How can I get past "close IE" to continue the install even though IE is closed? 1226 1062
=O====== M/11.7.700.202 2013-05-15+21-05-15.971 ========
0000 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000010 FlashPlayerInstaller.exe -install -iv 11
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_169.ocx 5
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.exe 5
0007 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001015
C:\Windows\TEMP\{5C63C4B9-4783-428B-B30C-14A370087C3A}\Flash32_11_7_700_202.ocx
0009 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000025
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.dll
0014 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
0015 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
0016 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000021
0017 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001106
0018 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001106
0019 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024
0020 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000012
=X====== M/11.7.700.202 2013-05-15+21-05-41.118 ========
2013-6-12+16-5-14.181 Re: How can I get past "close IE" to continue the install even though IE is closed? 1226 1062
=O====== M/11.7.700.224 2013-06-12+16-05-03.787 ========
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_202.ocx 5
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe 5
C:\Windows\TEMP\{08741A8A-EFE6-42A9-A02A-03D9A6A67093}\Flash32_11_7_700_224.ocx
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.dll
=X====== M/11.7.700.224 2013-06-12+16-05-15.581 ========
=O====== M/11.8.800.94 2013-07-11+08-11-12.586 ========
"C:\Users\Julia\AppData\Local\Adobe\AIH.0b83b6ee08fcfaebb75fd1e42f6a88b136a03e8f\install_flash_player_ax.exe"
-install -iv 10
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_224.ocx 5
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe 5
0008 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_94.ocx
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.dll
0013 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
0014 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
0015 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000021
0016 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001106
0018 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024
0019 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000012
=X====== M/11.8.800.94 2013-07-11+08-11-18.980 ========
=O====== M/11.8.800.94 2013-08-01+17-53-50.778 ========
"C:\Users\Julia\AppData\Local\Adobe\AIH.c019aafa1697aad2f600a7afbec7fe96baf3754e\install_flash_player_ax.exe"
-install -iv 8
=X====== M/11.8.800.94 2013-08-01+17-53-51.207 ========
=O====== M/11.8.800.94 2013-08-01+17-54-10.114 ========
-install -iv 8
=X====== M/11.8.800.94 2013-08-01+17-54-10.480 ========
=O====== M/11.8.800.94 2013-08-01+17-54-23.394 ========
-install -iv 8
=X====== M/11.8.800.94 2013-08-01+17-54-23.701 ========
=O====== M/11.8.800.94 2013-08-01+17-54-39.228 ========
-install -iv 8
=X====== M/11.8.800.94 2013-08-01+17-54-39.552 ========
=O====== M/11.8.800.94 2013-08-01+17-54-40.563 ========
-install -iv 8
=X====== M/11.8.800.94 2013-08-01+17-54-40.871 ========
=O====== M/11.8.800.94 2013-08-01+17-54-50.766 ========
-install -iv 8
=X====== M/11.8.800.94 2013-08-01+17-54-51.085 ========
=O====== M/11.8.800.94 2013-08-01+17-54-52.246 ========
-install -iv 8
=X====== M/11.8.800.94 2013-08-01+17-54-52.564 ========
=O====== M/11.8.800.94 2013-08-28+16-08-05.449 ========
-install -iv 8
=X====== M/11.8.800.94 2013-08-28+16-08-06.165 ========
=O====== M/11.8.800.94 2013-08-28+16-08-13.895 ========
-install -iv 8
=X====== M/11.8.800.94 2013-08-28+16-08-14.347 ========
2013-8-28+16-41-42.474 Re: How can I get past "close IE" to continue the install even though IE is closed? 1226 1062
=O====== M/11.8.800.94 2013-08-28+16-41-35.678 ========
"C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe"
-maintain activex
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe 5
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.dll 5
0011 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001021
0012 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0013 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0014 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0015 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0016 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001037 Software\Microsoft\Windows\CurrentVersion\Control
Panel\Extended
2
0017 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0018 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0019 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001015
0022 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001015
0023 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000011 1
0024 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000012
=X====== M/11.8.800.94 2013-08-28+16-41-47.167 ========
=O====== M/11.8.800.94 2013-08-28+16-54-36.411 ========
"C:\Users\Julia\AppData\Local\Adobe\AIH.34247ff3f66067577a7ca3739e0f2b44e8b29d3c\install_flash_player_ax.exe"
0003 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000011 1
0004 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0005 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe
0006 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_94.ocx
0011 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000021
0012 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000012
=X====== M/11.8.800.94 2013-08-28+16-54-42.299 ========
2013-9-11+11-12-11.176 Re: How can I get past "close IE" to continue the install even though IE is closed? 1226 1062
=O====== M/11.8.800.168 2013-09-11+11-12-03.438 ========
C:\Windows\TEMP\{751F1F7A-AB4C-419E-9425-21A9296A7955}\Flash32_11_8_800_168.ocx
0004 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000025
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.exe
0005 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000015
0006 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000016
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.dll
0007 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0008 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0009 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
0010 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
0013 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001106
=X====== M/11.8.800.168 2013-09-11+11-12-12.455 ========
=O====== M/11.8.800.174 2013-09-13+14-12-21.892 ========
"C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.exe"
-refreshIEElevationPolicies
=X====== M/11.8.800.174 2013-09-13+14-12-21.965 ========
2013-9-13+14-12-23.975 Re: How can I get past "close IE" to continue the install even though IE is closed? 1226 1062
=O====== M/11.8.800.174 2013-09-13+14-12-11.662 ========
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_168.ocx 5
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.exe 5
C:\Windows\TEMP\{252DCD7E-C6A5-40FC-BA68-20E45ABB4EDB}\Flash32_11_8_800_174.ocx
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.dll
=X====== M/11.8.800.174 2013-09-13+14-12-25.771 ========
=O====== M/11.8.800.175 2013-09-19+21-12-18.353 ========
"C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe"
=X====== M/11.8.800.175 2013-09-19+21-12-18.586 ========
2013-9-19+21-12-20.969 Re: How can I get past "close IE" to continue the install even though IE is closed? 1226 1062
=O====== M/11.8.800.175 2013-09-19+21-12-08.773 ========
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_174.ocx 5
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.exe 5
C:\Windows\TEMP\{5E5A3AC3-1401-49FA-B68E-582B7F89F4D1}\Flash32_11_8_800_175.ocx
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll
=X====== M/11.8.800.175 2013-09-19+21-12-23.236 ========
=O====== M/11.8.800.174 2013-09-23+23-34-53.448 ========
-install -iv 8
=X====== M/11.8.800.174 2013-09-23+23-34-54.463 ========
2013-9-30+17-31-4.599 Re: How can I get past "close IE" to continue the install even though IE is closed? 1226 1062
=O====== M/11.8.800.175 2013-09-30+17-30-41.915 ========
"C:\Users\Julia\AppData\Local\Temp\{F16FF06E-E529-4211-8303-73A0AFDF03E4}\InstallFlashPlayer.exe"
-iv 4
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_175.ocx
=X====== M/11.8.800.175 2013-09-30+17-31-09.486 ========
2013-10-9+1-12-1.268 Re: How can I get past "close IE" to continue the install even though IE is closed? 1221 1115
=O====== M/11.9.900.117 2013-10-09+02-12-19.865 ========
"C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe"
=X====== M/11.9.900.117 2013-10-09+02-12-19.928 ========
2013-10-9+2-12-21.28 Re: How can I get past "close IE" to continue the install even though IE is closed? 1226 1062
=O====== M/11.9.900.117 2013-10-09+02-12-08.231 ========
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_175.ocx 5
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe 5
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_117.ocx
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.dll
=X====== M/11.9.900.117 2013-10-09+02-12-22.875 ========
=O====== M/11.9.900.117 2013-10-25+19-22-52.679 ========
-maintain activex
0001 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001039
=X====== M/11.9.900.117 2013-10-25+19-23-00.768 ========
=O====== M/11.9.900.117 2013-11-03+00-59-00.708 ========
-install -iv 8
=X====== M/11.9.900.117 2013-11-03+00-59-01.680 ========
=O====== M/11.9.900.117 2013-11-03+01-00-33.663 ========
-install -iv 8
=X====== M/11.9.900.117 2013-11-03+01-00-35.746 ========
=O====== M/11.9.900.117 2013-11-03+01-02-30.560 ========
-install -iv 8
=X====== M/11.9.900.117 2013-11-03+01-02-31.315 ========
=O====== M/11.9.900.117 2013-11-03+01-02-52.311 ========
-install -iv 8
=X====== M/11.9.900.117 2013-11-03+01-02-53.038 ========
=O====== M/11.9.900.117 2013-11-03+01-06-33.987 ========
"C:\Users\Julia\AppData\Local\Adobe\AIH.3e58920ee336bd8b7549829d8bdd9915d1118392\install_flash_player_ax.exe"
-install -iv 8
=X====== M/11.9.900.117 2013-11-03+01-06-44.483 ========
2013-11-4+2-12-0.532 Re: How can I get past "close IE" to continue the install even though IE is closed? 1223 1056
=O====== M/11.9.900.117 2013-11-07+01-59-24.258 ========
-install -iv 8
=X====== M/11.9.900.117 2013-11-07+01-59-25.185 ========
=O====== M/11.9.900.117 2013-11-07+01-59-55.679 ========
-install -iv 8
=X====== M/11.9.900.117 2013-11-07+02-00-05.836 ========
2013-11-9+4-12-0.692 Re: How can I get past "close IE" to continue the install even though IE is closed? 1223 1056
=O====== M/11.9.900.152 2013-11-25+00-41-32.834 ========
"C:\Users\Julia\AppData\Local\Adobe\AIH.e9b8cc87d700a24bd04f18ea67baa59851f96bc9\install_flash_player_ax.exe"
-install -iv 10
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_117.ocx 5
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe 5
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_152.ocx
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.exe
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.dll
=X====== M/11.9.900.152 2013-11-25+00-41-41.155 ========
2013-12-9+1-12-0.292 Re: How can I get past "close IE" to continue the install even though IE is closed? 1223 1056
=O====== M/11.9.900.152 2013-12-09+07-56-12.336 ========
"C:\Users\Julia\AppData\Local\Adobe\AIH.e212434f8bf163dbbc8d7625346be719646239ee\install_flash_player_ax.exe"
-install -iv 8
=X====== M/11.9.900.152 2013-12-09+07-56-14.675 ========
=O====== M/11.9.900.152 2013-12-09+07-57-01.037 ========
-install -iv 8
=X====== M/11.9.900.152 2013-12-09+07-57-02.898 ========
=O====== M/11.9.900.152 2013-12-09+07-57-35.654 ========
-install -iv 8
=X====== M/11.9.900.152 2013-12-09+07-57-37.204 ========
=O====== M/11.9.900.152 2013-12-09+07-57-40.955 ========
-install -iv 8
=X====== M/11.9.900.152 2013-12-09+07-57-42.516 ========
=O====== M/11.9.900.152 2013-12-09+07-58-12.427 ========
-install -iv 8
=X====== M/11.9.900.152 2013-12-09+07-58-13.973 ========
=O====== M/11.9.900.152 2013-12-09+07-58-17.058 ========
-install -iv 8
=X====== M/11.9.900.152 2013-12-09+07-58-18.646 ========
=O====== M/11.9.900.152 2013-12-09+07-58-38.821 ========
-install -iv 8
=X====== M/11.9.900.152 2013-12-09+07-58-40.365 ========
=O====== M/11.9.900.152 2013-12-09+07-59-47.584 ========
"C:\Users\Julia\AppData\Local\Adobe\AIH.5aa6098f5a605b6aefa5f8cca70e50570344a904\install_flash_player_ax.exe"
-install -iv 8
=X====== M/11.9.900.152 2013-12-09+07-59-49.101 ========
=O====== M/11.9.900.170 2013-12-11+02-13-27.306 ========
"C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.exe"
=X====== M/11.9.900.170 2013-12-11+02-13-28.706 ========
2013-12-11+2-13-34.505 Re: How can I get past "close IE" to continue the install even though IE is closed? 1226 1062
=O====== M/11.9.900.170 2013-12-11+02-12-54.861 ========
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_152.ocx 5
C:\Windows\TEMP\{C9550C3A-3F7D-4351-89A3-F6F52FB20ECA}\Flash32_11_9_900_170.ocx
0007 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000025
0008 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000015
0009 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000016
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.dll
0010 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0011 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0012 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
0013 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
0017 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001024
0018 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000012
=X====== M/11.9.900.170 2013-12-11+02-13-37.636 ========
=O====== M/11.9.900.170 2013-12-13+18-49-10.585 ========
"C:\Users\Julia\AppData\Local\Adobe\AIH.bf6a395168492cd3eac925d0b31b295549eeecec\install_flash_player_ax.exe"
-install -iv 8
=X====== M/11.9.900.170 2013-12-13+18-49-13.093 ========
=O====== M/11.9.900.170 2013-12-13+18-51-42.395 ========
-install -iv 8
=X====== M/11.9.900.170 2013-12-13+18-51-58.275 ========
=O====== M/11.9.900.170 2013-12-13+18-52-07.292 ========
-install -iv 8
=X====== M/11.9.900.170 2013-12-13+18-52-08.168 ========
=O====== M/11.9.900.170 2013-12-13+18-52-48.684 ========
-install -iv 8
=X====== M/11.9.900.170 2013-12-13+18-52-50.553 ========
=O====== M/11.9.900.170 2013-12-13+18-53-30.169 ========
-install -iv 8
=X====== M/11.9.900.170 2013-12-13+18-53-32.370 ========
=O====== M/11.9.900.170 2013-12-13+18-53-33.735 ========
-install -iv 8
=X====== M/11.9.900.170 2013-12-13+18-53-34.588 ========
=O====== M/11.9.900.170 2013-12-13+18-53-38.534 ========
-install -iv 8
=X====== M/11.9.900.170 2013-12-13+18-53-40.931 ========
=O====== M/11.9.900.170 2013-12-13+18-57-17.239 ========
0000 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000010 "C:\Users\Julia\AppData\Local\Microsoft\Windows\Temporary
Internet Files\Content.IE5\WHI0CJIL\uninstall_flash_player.exe" -force
0001 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0002 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0003 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0004 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0005 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0006 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0007 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0008 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0009 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0010 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0011 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0012 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
=X====== M/11.9.900.170 2013-12-13+18-57-34.021 ========
=O====== M/11.9.900.170 2013-12-13+19-00-06.223 ========
0000 Re: How can I get past "close IE" to continue the install even though IE is closed? 00000010 "C:\Users\Julia\Downloads\uninstall_flash_player.exe"
-force
0017 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0020 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0021 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0022 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0023 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0024 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0025 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0026 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0027 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0028 Re: How can I get past "close IE" to continue the install even though IE is closed? 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
=X====== M/11.9.900.170 2013-12-13+19-00-43.486 ========
=O====== M/11.9.900.170 2013-12-13+19-28-52.068 ========
-install -iv 8
=X====== M/11.9.900.170 2013-12-13+19-28-54.098 ========
=O====== M/11.9.900.170 2013-12-13+19-29-08.708 ========
-install -iv 8
=X====== M/11.9.900.170 2013-12-13+19-29-10.763 ========
=O====== M/11.9.900.170 2013-12-13+19-29-15.446 ========
-install -iv 8
=X====== M/11.9.900.170 2013-12-13+19-29-17.275 ========
=O====== M/11.9.900.170 2013-12-13+19-29-18.380 ========
-install -iv 8
=X====== M/11.9.900.170 2013-12-13+19-29-20.193 ========
=O====== M/11.9.900.170 2013-12-13+20-05-35.470 ========
"C:\Users\Julia\AppData\Local\Adobe\AIH.817f342d52e65f0202083c35d3f93193ef5d7c77\install_flash_player_ax.exe"
-install -iv 8
=X====== M/11.9.900.170 2013-12-13+20-05-37.371 ========
=O====== M/11.9.900.170 2013-12-13+20-05-49.499 ========
-install -iv 8
=X====== M/11.9.900.170 2013-12-13+20-05-52.024 ========
[private data removed]
There are some modules that could not be deleted/replaced by the installer. You need to perform a clean install; see http://forums.adobe.com/thread/928315
P.S. this is a public forum; please do not post your email address, telephone number, etc.!
That's what I thought but I couldn't see how to do that. I'll try your recommendation. Of course, I'm sitting here scratching my head as to why the last log file displayed the way it did but...
Thank you.
That should uninstall every Flash Player but PepperFlash in Chrome, as was stated by m_vargas.
Correct, Mike. Thank you for the clarification.
And likewise, on Windows 8/8.1, it will not uninstall the Flash Player activex control, only the plugin, but we're dealing with Windows 7 in this situation.
Maria
I have win7 pro. i don't think i want to do 8 but i said the same thing about vista and i survived.
I sent you the log via email instead of posting it so here it is again:
0000
0001 00000010 "C:\ProgramData\Adobe\AIH.be8c985f293b5564c726f5adc6bdb778d77c90d1\install_flash_player_ax.exe" -install -iv 8 -au 0
0002
0003
0004
0005 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0006 00000011 1
0007
0008 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_135.ocx
0009 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.exe
0010 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.dll
0011 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0012 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0013 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0014 00000012
2013-3-28+21-33-6.771 [error] 1226 1062
0000 00000010 FlashPlayerInstaller.exe -install -iv 9
0001 00000011 1
0002 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0003 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_180.ocx
0004 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe
0005 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.dll
0006 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0007 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0008
0009
0010 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0011
0012
0013
0014 00000012
0000 00000010 "C:\Program Files (x86)\Flash Player Pro\FlashActivex.exe" -install
0001
2013-4-6+2-50-39.64 [error] 1226 1062
0000 00000010 "C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe" -maintain activex
0001
0002 00000018
0003
0004
0005 00000018
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022 00000011 1
0023 00000012
0000 00000010 "C:\Users\Owner\AppData\Local\Temp\{1C7DA24F-9A85-4354-B01B-0E400C687BD0}\InstallFlashPlayer.exe" -iv 6
0001
0002
0003
0004
0005 00000011 1
0006 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0007
0008
0009 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_180.ocx
0010 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe
0011 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.dll
0012 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0013 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0014 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0015 00000012
0000 00000010 C:\Users\Owner\AppData\Local\Temp\IDC2.tmp\FP_AX_CAB_INSTALLER64.exe
0001 00000011 1
0000 00000010 "C:\ProgramData\Adobe\AIH.541299abd1ae43ee4cdc1e1bae6baa3d92d8c911\install_flash_player_ax.exe" -install -iv 8
0001 00000011 1
0003
0004 00000018
0005
0006 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_169.ocx
0007 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.exe
0008 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.dll
0009 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0010 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0011
0012
0014
0015
0016
0017 00000012
0001
0001 00000011 1
0003 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_169.ocx
0004 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.exe
0005 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.dll
0008
0009
0011
0012
0013
0014 00000012
0001
0001 00000011 1
0008
0009
0011
0012
0013
0014 00000012
0001
0001
0001 00000011 1
0008
0009
0011
0012
0013
0014 00000012
2013-5-15+16-5-0.242 [error] 1223 1056
2013-5-15+17-5-0.238 [error] 1223 1056
2013-5-15+21-5-38.607 [error] 1226 1062
0000 00000010 FlashPlayerInstaller.exe -install -iv 11
0001 00000011 1
0003
0004 00000018
0005
0006
0007
0008 00000013 C:\Windows\TEMP\{5C63C4B9-4783-428B-B30C-14A370087C3A}\Flash32_11_7_700_202.ocx
0009 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe
0010 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe
0011 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.dll
0014
0015
0016 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0017
0018
0019
0020 00000012
2013-6-12+16-5-14.181 [error] 1226 1062
0001 00000011 1
0003
0004 00000018
0005
0006
0007
0008 00000013 C:\Windows\TEMP\{08741A8A-EFE6-42A9-A02A-03D9A6A67093}\Flash32_11_7_700_224.ocx
0009 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe
0010 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe
0011 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.dll
0014
0015
0017
0018
0019
0020 00000012
0000 00000010 "C:\Users\Julia\AppData\Local\Adobe\AIH.0b83b6ee08fcfaebb75fd1e42f6a88b136a03e8f\install_flash_player_ax.exe" -install -iv 10
0001 00000011 1
0003
0004 00000018
0005
0006
0007
0008 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_94.ocx
0009 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe
0010 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.dll
0013
0014
0015 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0016
0017
0018
0019 00000012
0000 00000010 "C:\Users\Julia\AppData\Local\Adobe\AIH.c019aafa1697aad2f600a7afbec7fe96baf3754e\install_flash_player_ax.exe" -install -iv 8
0001
0001
0001
0001
0001
0001
0001
0001
0001
2013-8-28+16-41-42.474 [error] 1226 1062
0000 00000010 "C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe" -maintain activex
0001
0002 00000018
0003
0004
0005 00000018
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023 00000011 1
0024 00000012
0000 00000010 "C:\Users\Julia\AppData\Local\Adobe\AIH.34247ff3f66067577a7ca3739e0f2b44e8b29d3c\install_flash_player_ax.exe" -install -iv 8 -au 0
0001
0002
0003 00000011 1
0004 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0005
0006 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_94.ocx
0007 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe
0008 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.dll
0011 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0012 00000012
2013-9-11+11-12-11.176 [error] 1226 1062
0001 00000011 1
0003 00000013 C:\Windows\TEMP\{751F1F7A-AB4C-419E-9425-21A9296A7955}\Flash32_11_8_800_168.ocx
0004 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.exe
0005 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.exe
0006 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.dll
0007 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0008 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0009
0010
0012
0013
0014
0015 00000012
0000 00000010 "C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.exe" -refreshIEElevationPolicies
2013-9-13+14-12-23.975 [error] 1226 1062
0001 00000011 1
0003
0004 00000018
0005
0006
0007
0008 00000013 C:\Windows\TEMP\{252DCD7E-C6A5-40FC-BA68-20E45ABB4EDB}\Flash32_11_8_800_174.ocx
0009 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.exe
0010 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.exe
0011 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.dll
0014
0015
0017
0018
0019
0020 00000012
0000 00000010 "C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe" -refreshIEElevationPolicies
2013-9-19+21-12-20.969 [error] 1226 1062
0001 00000011 1
0003
0004 00000018
0005
0006
0007
0008 00000013 C:\Windows\TEMP\{5E5A3AC3-1401-49FA-B68E-582B7F89F4D1}\Flash32_11_8_800_175.ocx
0009 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe
0010 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe
0011 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll
0014
0015
0017
0018
0019
0020 00000012
0001
2013-9-30+17-31-4.599 [error] 1226 1062
0000 00000010 "C:\Users\Julia\AppData\Local\Temp\{F16FF06E-E529-4211-8303-73A0AFDF03E4}\InstallFlashPlayer.exe" -iv 4
0001 00000011 1
0003 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_175.ocx
0004 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe
0005 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll
0008
0009
0011
0012
0013
0014 00000012
2013-10-9+1-12-1.268 [error] 1221 1115
0000 00000010 "C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe" -refreshIEElevationPolicies
2013-10-9+2-12-21.28 [error] 1226 1062
0001 00000011 1
0003
0004 00000018
0005
0006
0007
0008 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_117.ocx
0009 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe
0010 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.dll
0013
0014
0016
0017
0018
0019 00000012
0000 00000010 "C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe" -maintain activex
0001
0001
0001
0001
0001
0000 00000010 "C:\Users\Julia\AppData\Local\Adobe\AIH.3e58920ee336bd8b7549829d8bdd9915d1118392\install_flash_player_ax.exe" -install -iv 8
0001 00000011 1
0003 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_117.ocx
0004 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe
0005 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.dll
0008
0009
0011
0012
0013
0014 00000012
2013-11-4+2-12-0.532 [error] 1223 1056
0001
0001 00000011 1
0008
0009
0011
0012
0013
0014 00000012
2013-11-9+4-12-0.692 [error] 1223 1056
0000 00000010 "C:\Users\Julia\AppData\Local\Adobe\AIH.e9b8cc87d700a24bd04f18ea67baa59851f96bc9\install_flash_player_ax.exe" -install -iv 10
0001 00000011 1
0003
0004 00000018
0005
0006
0007
0008 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_152.ocx
0009 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.exe
0010 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.dll
0013
0014
0016
0017
0018
0019 00000012
2013-12-9+1-12-0.292 [error] 1223 1056
0000 00000010 "C:\Users\Julia\AppData\Local\Adobe\AIH.e212434f8bf163dbbc8d7625346be719646239ee\install_flash_player_ax.exe" -install -iv 8
0001
0001
0001
0001
0001
0001
0001
0000 00000010 "C:\Users\Julia\AppData\Local\Adobe\AIH.5aa6098f5a605b6aefa5f8cca70e50570344a904\install_flash_player_ax.exe" -install -iv 8
0001
0000 00000010 "C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.exe" -refreshIEElevationPolicies
2013-12-11+2-13-34.505 [error] 1226 1062
0001 00000011 1
0003
0004 00000018
0005
0006 00000013 C:\Windows\TEMP\{C9550C3A-3F7D-4351-89A3-F6F52FB20ECA}\Flash32_11_9_900_170.ocx
0007 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.exe
0008 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.exe
0009 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.dll
0010 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0011 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0012
0013
0015
0016
0017
0018 00000012
0000 00000010 "C:\Users\Julia\AppData\Local\Adobe\AIH.bf6a395168492cd3eac925d0b31b295549eeecec\install_flash_player_ax.exe" -install -iv 8
0001
0001
0001
0001
0001
0001
0001
0000 00000010 "C:\Users\Julia\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\WHI0CJIL\uninstall_flash_player.exe" -force
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0000 00000010 "C:\Users\Julia\Downloads\uninstall_flash_player.exe" -force
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027
0028
0001
0001
0001
0001
0000 00000010 "C:\Users\Julia\AppData\Local\Adobe\AIH.817f342d52e65f0202083c35d3f93193ef5d7c77\install_flash_player_ax.exe" -install -iv 8
0001
0001
here's the 32 bit:
=O====== M/11.5.502.135 2012-12-15+20-32-07.016 ========
0000
0001 00000010 "C:\Users\Owner\AppData\Local\Temp\{36397D0B-88B3-4EA1-8DE0-4727242DAC03}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0002
0003
0004
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_5_502_135.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_135_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_135_ActiveX.dll
0010 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0012 00000012
=X====== M/11.5.502.135 2012-12-15+20-32-07.934 ========
=O====== M/11.6.602.180 2013-03-28+21-33-01.732 ========
0000 00000010 "C:\Windows\TEMP\{372846B3-CF49-4D41-B661-798062707CD7}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0001 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0002
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_180.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_ActiveX.dll
0006 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0008 00000012
=X====== M/11.6.602.180 2013-03-28+21-33-04.774 ========
=O====== M/11.6.602.180 2013-04-06+02-50-40.156 ========
0000 00000010 "C:\Users\Owner\AppData\Local\Temp\{CC1188A4-3079-4574-84E0-FF9CE56BD74E}\InstallFlashPlayer.exe" -uninstall activex
0001
0002
0003 00000018
0004
0005
0006 00000018
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
=X====== M/11.6.602.180 2013-04-06+02-50-40.343 ========
=O====== M/11.6.602.180 2013-04-06+03-03-47.965 ========
0000 00000010 "C:\Users\Owner\AppData\Local\Temp\{11166912-7C1B-4CD2-8217-62E9FAA5AD11}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 6 -au 4294967295
0001
0002
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004
0005
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_180.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_ActiveX.dll
0009 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0011 00000012
=X====== M/11.6.602.180 2013-04-06+03-03-50.898 ========
=O====== M/11.7.700.169 2013-04-15+22-20-39.091 ========
0000 00000010 "C:\Users\Julia\AppData\Local\Temp\{18BD02DC-B5E3-4094-B882-E6979398593D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0002
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_169.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.dll
0008 00000012
=X====== M/11.7.700.169 2013-04-15+22-20-40.858 ========
=O====== M/11.7.700.169 2013-04-17+21-04-35.929 ========
0000 00000010 "C:\Users\Julia\AppData\Local\Temp\{C15318AA-D826-4631-B376-ADD7E5D38455}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0002
0008 00000012
=X====== M/11.7.700.169 2013-04-17+21-04-38.053 ========
=O====== M/11.7.700.169 2013-04-18+20-54-57.280 ========
0000 00000010 "C:\Users\Julia\AppData\Local\Temp\{F684D435-52EE-4A0B-B13D-5F16E92091E6}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0002
0008 00000012
=X====== M/11.7.700.169 2013-04-18+20-54-58.904 ========
=O====== M/11.7.700.169 2013-04-20+19-07-30.718 ========
0000 00000010 "C:\Users\Julia\AppData\Local\Temp\{61527849-7839-489C-9856-885833F15CEA}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0002
0008 00000012
=X====== M/11.7.700.169 2013-04-20+19-07-33.453 ========
=O====== M/11.7.700.202 2013-05-15+21-05-18.553 ========
0000 00000010 "C:\Windows\TEMP\{75878F48-BA81-43EE-9628-20B9DBC551FC}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007 00000013 C:\Windows\TEMP\{1FCC601A-561F-48F4-B286-A55EB89FFD2C}\Flash64_11_7_700_202.ocx
0008 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.exe
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.exe
0010 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.dll
0011 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0013 00000012
=X====== M/11.7.700.202 2013-05-15+21-05-34.022 ========
=O====== M/11.7.700.224 2013-06-12+16-05-04.890 ========
0000 00000010 "C:\Windows\TEMP\{A66A1DD6-3428-48C5-A6EB-5EDBB796BDDA}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007 00000013 C:\Windows\TEMP\{654F53D4-0932-49CA-9D53-1AE09042805F}\Flash64_11_7_700_224.ocx
0008 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_224_ActiveX.exe
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_224_ActiveX.exe
0010 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_224_ActiveX.dll
0013 00000012
=X====== M/11.7.700.224 2013-06-12+16-05-11.325 ========
=O====== M/11.8.800.94 2013-07-11+08-11-13.901 ========
0000 00000010 "C:\Users\Julia\AppData\Local\Temp\{8A50AA7A-CBC7-496C-91FC-6635A549020C}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 10 -au 4294967295
0002
0003
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_8_800_94.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_94_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_94_ActiveX.dll
0012 00000012
=X====== M/11.8.800.94 2013-07-11+08-11-15.628 ========
=O====== M/11.8.800.94 2013-08-28+16-41-42.875 ========
0000 00000010 "C:\Users\Julia\AppData\Local\Temp\{58C69542-7CFF-4B87-8111-D46BDF9922C0}\InstallFlashPlayer.exe" -uninstall activex
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
=X====== M/11.8.800.94 2013-08-28+16-41-43.062 ========
=O====== M/11.8.800.94 2013-08-28+16-54-37.733 ========
0000 00000010 "C:\Users\Julia\AppData\Local\Temp\{09F1031F-E9FA-465E-8618-52111D5F462A}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0001
0002
0004
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_8_800_94.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_94_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_94_ActiveX.dll
0008 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0009 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0010 00000012
=X====== M/11.8.800.94 2013-08-28+16-54-38.945 ========
=O====== M/11.8.800.168 2013-09-11+11-12-04.733 ========
0000 00000010 "C:\Windows\TEMP\{71A09E8E-1F21-4970-AFE6-4DCEB79F51BC}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003 00000013 C:\Windows\TEMP\{E740C068-84F6-4435-82FE-8A21A46D55CC}\Flash64_11_8_800_168.ocx
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_168_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_168_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_168_ActiveX.dll
0007 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0009 00000012
=X====== M/11.8.800.168 2013-09-11+11-12-08.789 ========
=O====== M/11.8.800.174 2013-09-13+14-12-12.470 ========
0000 00000010 "C:\Windows\TEMP\{587BE581-367D-4AA5-9AB1-BDCDC03D1CBF}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007 00000013 C:\Windows\TEMP\{E40AB918-54E1-42EA-AD21-C275C40141FF}\Flash64_11_8_800_174.ocx
0008 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_174_ActiveX.exe
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_174_ActiveX.exe
0010 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_174_ActiveX.dll
0013 00000012
=X====== M/11.8.800.174 2013-09-13+14-12-20.447 ========
=O====== M/11.8.800.175 2013-09-19+21-12-09.841 ========
0000 00000010 "C:\Windows\TEMP\{962D81D4-2F1D-4651-A962-AE484F04FAF4}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003 00000013 C:\Windows\TEMP\{1D011302-ED51-48E5-9FA5-2444E4B74A0B}\Flash64_11_8_800_175.ocx
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_175_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_175_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_175_ActiveX.dll
0009 00000012
=X====== M/11.8.800.175 2013-09-19+21-12-16.410 ========
=O====== M/11.8.800.175 2013-09-30+17-31-00.246 ========
0000 00000010 "C:\Users\Julia\AppData\Local\Temp\{E9234382-406B-4697-AD12-553A15007C60}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 4 -au 4294967295
0002
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_8_800_175.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_175_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_175_ActiveX.dll
0008 00000012
=X====== M/11.8.800.175 2013-09-30+17-31-01.869 ========
=O====== M/11.9.900.117 2013-10-09+02-12-10.015 ========
0000 00000010 "C:\Windows\TEMP\{865BE9B3-514D-4F55-8D89-357592618351}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0002
0003
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_9_900_117.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_ActiveX.dll
0012 00000012
=X====== M/11.9.900.117 2013-10-09+02-12-18.651 ========
=O====== M/11.9.900.117 2013-11-03+01-06-36.021 ========
0000 00000010 "C:\Users\Julia\AppData\Local\Temp\{D8460B40-20B5-4569-88AA-709724D217BA}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0002
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_9_900_117.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_ActiveX.dll
0008 00000012
=X====== M/11.9.900.117 2013-11-03+01-06-38.712 ========
=O====== M/11.9.900.117 2013-11-07+01-59-57.654 ========
0000 00000010 "C:\Users\Julia\AppData\Local\Temp\{46D889A3-C061-4356-837D-0940D6D8876D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0002
0008 00000012
=X====== M/11.9.900.117 2013-11-07+02-00-00.753 ========
=O====== M/11.9.900.152 2013-11-25+00-41-34.603 ========
0000 00000010 "C:\Users\Julia\AppData\Local\Temp\{7C5BA549-88A0-49EB-B961-3C6B3D4E4EA6}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 10 -au 4294967295
0002
0003
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_9_900_152.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_152_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_152_ActiveX.dll
0012 00000012
=X====== M/11.9.900.152 2013-11-25+00-41-36.450 ========
=O====== M/11.9.900.170 2013-12-11+02-13-07.088 ========
0000 00000010 "C:\Windows\TEMP\{AD5E33B6-68BD-4450-9704-3D0C0EEF34DE}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003 00000013 C:\Windows\TEMP\{12AB23E8-1190-4181-B7BB-CDB0845BF04C}\Flash64_11_9_900_170.ocx
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_170_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_170_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_170_ActiveX.dll
0009 00000012
=X====== M/11.9.900.170 2013-12-11+02-13-21.203 ========
