I'm using Adobe Pro 9.0.0 and LC ES. I am trying to take three fields of data, like: Number, date, and name. Add or merge them together to be placed into a hidden field, then when the user selects the SAVE button I need a script that will get the hidden field data and insert it as the filename to be saved to a specific path. Is this possible in LC ES?
Total Likes
You'll have to create a folder level script which has to be installed on every system you want to use the customized save function.
Here's an example.
http://thelivecycle.blogspot.de/2009/11/save-form-to-specific-directories-and.html
Total Likes
Thanks radzmar,
It is alittle confusing to me, but I'll figure it out, once I start applying it to my situation.
Thanks again for the tip.
Total Likes
