19 Replies Latest reply: Dec 15, 2013 7:32 AM by csuebele RSS
    Lighting Effect Question
    ColdForest Community Member
      I recently installed PS CC and am working with some images that I'd like to apply lighting effects to. In particular I'm trying to apply the spot light effect. I see all the appropriate controls and can manipulate the individual characteristics. However, the lighting effect appears to be getting applied to the entire image (i.e., not focused to the spot outline). The effect is like a complete layer blend as opposed to a targetted effect.
      I've confirmed that "use graphics processor" is selected and that the image is 8-bit RGB. This is on Win7 64-bit (Dell Core i7 w/8GB RAM and a fast internal HD).
      Anyone have any ideas here?
        • 1. Re: Lighting Effect Question
          csuebele CommunityMVP
          Can you post some examples?
          • 2. Re: Lighting Effect Question
            Sure:
            ...and without preview:
            • 3. Re: Lighting Effect Question
              FRom your samples, this looks normal.  The lighting effect does apply to the entire layer.  You just have to adjust the values to your needs.  If you want the color that you appled to be just applied to the spot and the spot to lighting the image, you might want to consider dropping down the ambient light then use a layer blend mode such as screen or lighten to blend the results.
              • 4. Re: Lighting Effect Question
                Exactly how would you like the lighting effect to look?
                • 5. Re: Lighting Effect Question
                  Thanks for your comments.
                  I must be missing something since all of the tutorials/reading I've done on this suggest that the default filter settings will result in a more "narrow" (spotlight) effect (as opposed to what this looks like to me, which seems to be more like an "infinite light" effect - i.e., applied to the whole layer). I thought the default "spot effect" would focus the light more directly??
                  • 6. Re: Lighting Effect Question
                    I'm after a "spotlight" effect (don't konw how to describe this more specifically, but hopefully you know what I mean ).
                    • 7. Re: Lighting Effect Question
                      Like this (from the CC help)cc-le-help.PNG:
                      • 8. Re: Lighting Effect Question
                        I'm not sure if you want the yellow color over the entire image.  If not, then set it in top control that says color.  If you want the spot to be brighter, increase the intensity of that top control.  The yellow color as you have it now mutes everything, especially since you have a negative value for the intensity.  You can further control how bright the rest of the image looks by ambience.  A value of 100% will give you the full tonal value of your origianl layer.  Here's a little sample if putting a reg spot on an image.  I don't know it that along the lines that you want.
                        • 9. Re: Lighting Effect Question
                          Just saw your last post.  In that case, you need to drop down the ambience, and if you want the yellow cast over the entire image, boost up the intensity, as well as increase the intensity of the main light (top control).
                          • 10. Re: Lighting Effect Question
                            Something has got to be wrong with my setup - intensity and ambience don't seem to do anything (meaningful/relevant). I can remove the overall yellow cast by changing colorize to 'white' (along with the color of the top control - to white), but ambience just changes the whole image from dark to light and intensity doesn't do *anything*.
                            Weird?
                            • 11. Re: Lighting Effect Question
                              Color control the actual color of the light source, and intensity controls how bright that light source is.  The two work with each other in that the darker the color, the less intensity you can get.
                              Colorize color the entire image, and exposure controls how much of the colorized color affects the light source, so a lower value will lower the light source intensity and make the light more the color of the color selected in the colorized box.
                              Ambience is also tied to the colorize control.  It will adjust the overall brightness on the image based on the color selected.  With white, you can bring up the value to see the original image at 100%.  With black there is no affect, as there is no "light" to brighten the image.
                              • 12. Re: Lighting Effect Question
                                Thanks - yes, this all makes sense.
                                However, this just does not seem to work for me. I've matched the settings in the CC help example (posted above), but just don't see the same effect:
                                • 13. Re: Lighting Effect Question
                                  Yes, that is odd.  I set this image for those same values.  I'm wondering if your graphic card is working right with this?  What type of card do you have and are the drivers updated?
                                  • 14. Re: Lighting Effect Question
                                    Ya, odd - sure would be nice to get this figured out...
                                    Graphics card is AMD Radeon HD6450
                                    Here's the system info:
                                    Adobe Photoshop Version: 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00) x64
                                    Operating System: Windows 7 64-bit
                                    Version: 6.1 Service Pack 1
                                    System architecture: Intel CPU Family:6, Model:10, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
                                    Physical processor count: 4
                                    Logical processor count: 8
                                    Processor speed: 3392 MHz
                                    Built-in memory: 8174 MB
                                    Free memory: 5044 MB
                                    Memory available to Photoshop: 7192 MB
                                    Memory used by Photoshop: 70 %
                                    Image tile size: 1024K
                                    Image cache levels: 4
                                    Display: 1
                                    Display Bounds: top=0, left=0, bottom=1080, right=1920
                                    OpenGL Drawing: Enabled.
                                    OpenGL Allow Old GPUs: Not Detected.
                                    OpenGL Drawing Mode: Advanced
                                    OpenGL Allow Normal Mode: True.
                                    OpenGL Allow Advanced Mode: True.
                                    NumGPUs=1
                                    gpu[0].OGLVersion="3.0"
                                    gpu[0].MemoryMB=1024
                                    gpu[0].RectTextureSize=16384
                                    gpu[0].Renderer="AMD Radeon HD 6450"
                                    gpu[0].RendererID=26489
                                    gpu[0].Vendor="ATI Technologies Inc."
                                    gpu[0].VendorID=4098
                                    gpu[0].HasNPOTSupport=1
                                    gpu[0].DriverVersion="8.850.0.0"
                                    gpu[0].Driver="aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64. dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dl l"
                                    gpu[0].DriverDate="20110419000000.000000-000"
                                    gpu[0].CompileProgramGLSL=1
                                    gpu[0].TestFrameBuffer=1
                                    gpu[0].OCLSupported=0
                                    gpu[0].CUDASupported=0
                                    gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.10"
                                    gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[214748 3647]
                                    gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                                    gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[32]
                                    gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
                                    gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
                                    gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                                    gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[16384]
                                    gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[16384]
                                    gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
                                    gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[29]
                                    gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                                    gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                                    gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                                    gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                                    gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                                    gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                                    gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                                    gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                                    gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                                    gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                                    Serial number: 96040573687862543208
                                    Application folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\
                                    Temporary file path: C:\Users\David\AppData\Local\Temp\
                                    Photoshop scratch has async I/O enabled
                                    Scratch volume(s):
                                      Startup, 915.2G, 277.2G free
                                    Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Required\Plug-Ins\
                                    Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Plug-ins\
                                    Installed components:
                                       ACE.dll   ACE 2013/07/14-12:09:50   79.543790   79.543790
                                       adbeape.dll   Adobe APE 2013/02/04-09:52:32   0.1160850   0.1160850
                                       AdobeLinguistic.dll   Adobe Linguisitc Library   7.0.0
                                       AdobeOwl.dll   Adobe Owl 2013/03/03-12:10:08   5.0.13   79.533484
                                       AdobePDFL.dll   PDFL 2013/03/13-12:09:15   79.499517   79.499517
                                       AdobePIP.dll   Adobe Product Improvement Program   7.0.0.1786
                                       AdobeXMP.dll   Adobe XMP Core 2013/03/13-12:09:15   79.151481   79.151481
                                       AdobeXMPFiles.dll   Adobe XMP Files 2013/03/13-12:09:15   79.151481   79.151481
                                       AdobeXMPScript.dll   Adobe XMP Script 2013/03/13-12:09:15   79.151481   79.151481
                                       adobe_caps.dll   Adobe CAPS   7,0,0,21
                                       AGM.dll   AGM 2013/07/14-12:09:50   79.543790   79.543790
                                       ahclient.dll    AdobeHelp Dynamic Link Library   1,8,0,31
                                       aif_core.dll   AIF   5.0   79.534508
                                       aif_ocl.dll   AIF   5.0   79.534508
                                       aif_ogl.dll   AIF   5.0   79.534508
                                       amtlib.dll   AMTLib (64 Bit)   7.0.0.169 BuildVersion: 7.0; BuildDate: Mon Apr 8 2013 2:31:50)   1.000000
                                       ARE.dll   ARE 2013/07/14-12:09:50   79.543790   79.543790
                                       AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
                                       AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
                                       Bib.dll   BIB 2013/07/14-12:09:50   79.543790   79.543790
                                       BIBUtils.dll   BIBUtils 2013/07/14-12:09:50   79.543790   79.543790
                                       boost_date_time.dll   DVA Product   7.0.0
                                       boost_signals.dll   DVA Product   7.0.0
                                       boost_system.dll   DVA Product   7.0.0
                                       boost_threads.dll   DVA Product   7.0.0
                                       cg.dll   NVIDIA Cg Runtime   3.0.00007
                                       cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                                       CIT.dll   Adobe CIT   2.1.6.30929   2.1.6.30929
                                       CITThreading.dll   Adobe CITThreading   2.1.6.30929   2.1.6.30929
                                       CoolType.dll   CoolType 2013/07/14-12:09:50   79.543790   79.543790
                                       dvaaudiodevice.dll   DVA Product   7.0.0
                                       dvacore.dll   DVA Product   7.0.0
                                       dvamarshal.dll   DVA Product   7.0.0
                                       dvamediatypes.dll   DVA Product   7.0.0
                                       dvaplayer.dll   DVA Product   7.0.0
                                       dvatransport.dll   DVA Product   7.0.0
                                       dvaunittesting.dll   DVA Product   7.0.0
                                       dynamiclink.dll   DVA Product   7.0.0
                                       ExtendScript.dll   ExtendScript 2013/03/21-12:10:31   79.535742   79.535742
                                       FileInfo.dll   Adobe XMP FileInfo 2013/03/19-12:09:02   79.151561   79.151561
                                       filter_graph.dll   AIF   5.0   79.534508
                                       icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                                       icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                                       imslib.dll   IMSLib DLL   7.0.0.116
                                       JP2KLib.dll   JP2KLib 2013/02/19-12:28:44   79.248139   79.248139
                                       libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                                       libiomp5md.dll   Intel(R) OMP Runtime Library   5.0
                                       libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                                       LogSession.dll   LogSession   2.1.2.1785
                                       mediacoreif.dll   DVA Product   7.0.0
                                       MPS.dll   MPS 2013/03/15-13:25:52   79.535029   79.535029
                                       msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6229
                                       msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                                       msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                                       msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6229
                                       msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                                       msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                                       msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6229
                                       msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                                       PatchMatch.dll   PatchMatch 2013/06/11-12:08:08   79.542390   79.542390
                                       pdfsettings.dll   Adobe PDFSettings   1.04
                                       Photoshop.dll   Adobe Photoshop CC   CC
                                       Plugin.dll   Adobe Photoshop CC   CC
                                       PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   4.0.1.34
                                       PSArt.dll   Adobe Photoshop CC   CC
                                       PSViews.dll   Adobe Photoshop CC   CC
                                       SCCore.dll   ScCore 2013/03/21-12:10:31   79.535742   79.535742
                                       ScriptUIFlex.dll   ScriptUIFlex 2013/03/21-12:10:31   79.535742   79.535742
                                       svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                                       tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 1, 2012, 1003
                                       tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 1, 2012, 1003
                                       updaternotifications.dll   Adobe Updater Notifications Library   7.0.1.102 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   7.0.1.102
                                       WRServices.dll   WRServices Mon Feb 25 2013 16:09:10   Build 0.19078   0.19078
                                    Required plug-ins:
                                       3D Studio 14.1.2 (14.1.2 x001)
                                       Accented Edges 14.1.2
                                       Adaptive Wide Angle 14.1.2
                                       Angled Strokes 14.1.2
                                       Average 14.1.2 (14.1.2 x001)
                                       Bas Relief 14.1.2
                                       BMP 14.1.2
                                       Camera Raw 8.3
                                       Camera Raw Filter 8.3
                                       Chalk & Charcoal 14.1.2
                                       Charcoal 14.1.2
                                       Chrome 14.1.2
                                       Cineon 14.1.2 (14.1.2 x001)
                                       Clouds 14.1.2 (14.1.2 x001)
                                       Collada 14.1.2 (14.1.2 x001)
                                       Color Halftone 14.1.2
                                       Colored Pencil 14.1.2
                                       CompuServe GIF 14.1.2
                                       Conté Crayon 14.1.2
                                       Craquelure 14.1.2
                                       Crop and Straighten Photos 14.1.2 (14.1.2 x001)
                                       Crop and Straighten Photos Filter 14.1.2
                                       Crosshatch 14.1.2
                                       Crystallize 14.1.2
                                       Cutout 14.1.2
                                       Dark Strokes 14.1.2
                                       De-Interlace 14.1.2
                                       Dicom 14.1.2
                                       Difference Clouds 14.1.2 (14.1.2 x001)
                                       Diffuse Glow 14.1.2
                                       Displace 14.1.2
                                       Dry Brush 14.1.2
                                       Eazel Acquire 14.1.2 (14.1.2 x001)
                                       Embed Watermark 4.0
                                       Entropy 14.1.2 (14.1.2 x001)
                                       Extrude 14.1.2
                                       FastCore Routines 14.1.2 (14.1.2 x001)
                                       Fibers 14.1.2
                                       Film Grain 14.1.2
                                       Filter Gallery 14.1.2
                                       Flash 3D 14.1.2 (14.1.2 x001)
                                       Fresco 14.1.2
                                       Glass 14.1.2
                                       Glowing Edges 14.1.2
                                       Google Earth 4 14.1.2 (14.1.2 x001)
                                       Grain 14.1.2
                                       Graphic Pen 14.1.2
                                       Halftone Pattern 14.1.2
                                       HDRMergeUI 14.1.2
                                       IFF Format 14.1.2
                                       Ink Outlines 14.1.2
                                       JPEG 2000 14.1.2
                                       Kurtosis 14.1.2 (14.1.2 x001)
                                       Lens Blur 14.1.2
                                       Lens Correction 14.1.2
                                       Lens Flare 14.1.2
                                       Liquify 14.1.2
                                       Matlab Operation 14.1.2 (14.1.2 x001)
                                       Maximum 14.1.2 (14.1.2 x001)
                                       Mean 14.1.2 (14.1.2 x001)
                                       Measurement Core 14.1.2 (14.1.2 x001)
                                       Median 14.1.2 (14.1.2 x001)
                                       Mezzotint 14.1.2
                                       Minimum 14.1.2 (14.1.2 x001)
                                       MMXCore Routines 14.1.2 (14.1.2 x001)
                                       Mosaic Tiles 14.1.2
                                       Multiprocessor Support 14.1.2 (14.1.2 x001)
                                       Neon Glow 14.1.2
                                       Note Paper 14.1.2
                                       NTSC Colors 14.1.2 (14.1.2 x001)
                                       Ocean Ripple 14.1.2
                                       Oil Paint 14.1.2
                                       OpenEXR 14.1.2
                                       Paint Daubs 14.1.2
                                       Palette Knife 14.1.2
                                       Patchwork 14.1.2
                                       Paths to Illustrator 14.1.2
                                       PCX 14.1.2 (14.1.2 x001)
                                       Photocopy 14.1.2
                                       Photoshop 3D Engine 14.1.2 (14.1.2 x001)
                                       Photoshop Touch 14.0
                                       Picture Package Filter 14.1.2 (14.1.2 x001)
                                       Pinch 14.1.2
                                       Pixar 14.1.2 (14.1.2 x001)
                                       Plaster 14.1.2
                                       Plastic Wrap 14.1.2
                                       PNG 14.1.2
                                       Pointillize 14.1.2
                                       Polar Coordinates 14.1.2
                                       Portable Bit Map 14.1.2 (14.1.2 x001)
                                       Poster Edges 14.1.2
                                       Radial Blur 14.1.2
                                       Radiance 14.1.2 (14.1.2 x001)
                                       Range 14.1.2 (14.1.2 x001)
                                       Read Watermark 4.0
                                       Reticulation 14.1.2
                                       Ripple 14.1.2
                                       Rough Pastels 14.1.2
                                       Save for Web 14.1.2
                                       ScriptingSupport 14.1.2
                                       Shake Reduction 14.1.2
                                       Shear 14.1.2
                                       Skewness 14.1.2 (14.1.2 x001)
                                       Smart Blur 14.1.2
                                       Smudge Stick 14.1.2
                                       Solarize 14.1.2 (14.1.2 x001)
                                       Spatter 14.1.2
                                       Spherize 14.1.2
                                       Sponge 14.1.2
                                       Sprayed Strokes 14.1.2
                                       Stained Glass 14.1.2
                                       Stamp 14.1.2
                                       Standard Deviation 14.1.2 (14.1.2 x001)
                                       STL 14.1.2 (14.1.2 x001)
                                       Sumi-e 14.1.2
                                       Summation 14.1.2 (14.1.2 x001)
                                       Targa 14.1.2
                                       Texturizer 14.1.2
                                       Tiles 14.1.2
                                       Torn Edges 14.1.2
                                       Twirl 14.1.2
                                       Underpainting 14.1.2
                                       Vanishing Point 14.1.2
                                       Variance 14.1.2 (14.1.2 x001)
                                       Variations 14.1.2 (14.1.2 x001)
                                       Water Paper 14.1.2
                                       Watercolor 14.1.2
                                       Wave 14.1.2
                                       Wavefront|OBJ 14.1.2 (14.1.2 x001)
                                       WIA Support 14.1.2 (14.1.2 x001)
                                       Wind 14.1.2
                                       Wireless Bitmap 14.1.2 (14.1.2 x001)
                                       ZigZag 14.1.2
                                    Optional and third party plug-ins: NONE
                                    Plug-ins that failed to load: NONE
                                    Flash:
                                       Mini Bridge
                                       Kuler
                                       Adobe Exchange
                                    Installed TWAIN devices: NONE
                                    • 15. Re: Lighting Effect Question
                                      Chris Cox Adobe Employee
                                      Your video card driver is over 2 years out of date...
                                      • 16. Re: Lighting Effect Question
                                        Thanks Chris.
                                        Well, that was not an instantaneous process (updating the ATI driver), but this seemed to do the trick(!).
                                        Thanks very much to both of you for helping to isolate this, much appreciated!
                                        • 17. Re: Lighting Effect Question
                                          Great!  I had an issue with lighting also with my AMD card, but in my case it was a switchable card that AMD would not update and left that to HP.  They never updated the driver.  I ended up getting a new comptuer and making sure I didn't have that type of setup!
                                          • 18. Re: Lighting Effect Question
                                            Ya, in this case it's interesting that the effect was present after a driver update; I'd be interested in knowing what exactly was fixed (newly available) in the driver that allowed Photoshop to correctly render the effect. I'm partly curious because it sure would have been nice if PS had the ability to detect this (i.e., driver update required/recommended). Moreover, I typically rely on Windows Update to identify these updates, but in this case this never happened...
                                            Cheers.
                                            • 19. Re: Lighting Effect Question
                                              Windows updates don't detect driver updates.  It would be nice to have some notice.  I was getting a completely black screen, and when using 3D the shadows would never show, then it got so the lights wouldn't show.
