1. Re: How to turn a stereo clip into mono
SteveG(AudioMasters) Dec 15, 2013 2:28 AM (in response to Elliott B.)There are so many ways you can do this, it's hard to pick the most suitable!
Probably the easiest thing to do (because it doesn't muck up anything else) is to double-click on the imported track so that it opens up in the waveform editor. If you now open up Effects>Amplitude and compression>Channel mixer, you can manipulate what's on both channels from what's there at present. Without looking I'm not exactly sure, but there's a good chance that there's a preset in there that will do exactly what you want without you having to figure out the settings yourself, but it's not difficult anyway. When you click on Multitrack again at the top LHS of the screen, the original file will be updated. When you close the session you'll be reminded that you haven't saved it, and whether you do or not is up to you.
2. Re: How to turn a stereo clip into mono
ryclark Dec 15, 2013 4:58 AM (in response to SteveG(AudioMasters))Yes Fill Left or Fill Right are presets under the Channel Mixer as outlined by Steve.
3. Re: How to turn a stereo clip into mono
Elliott B. Dec 15, 2013 9:02 AM (in response to SteveG(AudioMasters))Perfect, thanks! It works in multitrack mode too in the effects rack.
4. Re: How to turn a stereo clip into mono
SteveG(AudioMasters) Dec 15, 2013 9:41 AM (in response to Elliott B.)Elliott B. wrote:
Well I did say that there were other ways...
