1. Re: NVIDIA, ADOBE WHAT'S UP?
JSS1138 Dec 15, 2013 10:52 AM (in response to desi0214)I'm using that driver here without any problems. It does sound like you may be down to system wipe and clean install of Windows.
2. Re: NVIDIA, ADOBE WHAT'S UP?
desi0214 Dec 15, 2013 10:56 AM (in response to JSS1138)I was afraid you were gonna say that Jim. Ha. But thanks for the reply. I will do that now. I'll keep you posted Sir. Thanks.
3. Re: NVIDIA, ADOBE WHAT'S UP?
Alex - DV411 Dec 15, 2013 11:17 AM (in response to desi0214)Problems range from, choppy timeline, no color correction tools seem to work and sometimes it just hangs.
Anything in the systems logs? Choppy timeline - always? often? how often?
Color correction tools not working: could you elaborate?
Any effect from trashing Pr preferences, running Pr under a different user ID, turning GPU accel off?
I believe there's and issue between Nvidia and Adobe.
Why?
4. Re: NVIDIA, ADOBE WHAT'S UP?
desi0214 Dec 16, 2013 11:49 PM (in response to Alex - DV411)Hi Alex. The problems I was experiencing were happening for quite some time like. For starters the timeline would take a while to show up after start up. I would click project file tab or effects and it would show up, when I scrub the viewer, the timeline would not scrub. When I clicked on a clip and applied three way color corrector saturation slider would not drop down. Sometimes when I would change my workspace to 5.5 it worked but then with another clip (in that workspace) it didn't. I thought for a while it was a memory issue. I have uninstalled, reinstalled premiere pro cc numerous times with no avail. So finally with the advice from Jim I wiped my system clean, reformatted and installed windows 7 pro. I can say so far so good. Seems like it worked, however with my MTS files specifically play back is not up to par. I get this line of separation (kind of "jello" like movement) in my footage during fast pans, on the shoulder or slow zooms even. I tried different sd cards, it even does it with my prores footage too. Though the PP interface seems to be fixed with the new install, the video is still suffering. I gues I can only blame the Nvidia driver at this point. My raid 6, lsi controller card (just replaced) al seem fine, my next plan of action is to call the Sony service center to bring them camera to test the sensor. I'm hoping it's just the fact avchd files and this driver version are out of sync. If not I'm confident I'll get the root of it soon. I'll keep you posted, thanks for the post. Stay well
