1. Re: Generate a composite of all layers below.
Rafael Aviles Dec 15, 2013 1:58 PM (in response to John_Picton)Hold the Alt key when you click on the Merge Visible option in the Layers menu.
2. Re: Generate a composite of all layers below.
John_Picton Dec 15, 2013 2:09 PM (in response to Rafael Aviles)Thanks for the input - but sorry, on two levels that doesn't work for me (although it is entirely possible I am doing something wrong - it has been known :-) ).
When I hold down alt the menu just disappears either when doing it in the layers panel or when I do it in the layers menu.
Secondly (and I really do appreciate your suggestion) a couple of my clients cant use both hands (one of them is an amputee).
Thanks again.
Kind regards
John
3. Re: Generate a composite of all layers below.
Trevor.Dennis Dec 15, 2013 2:13 PM (in response to John_Picton)Sounds like you might need to make some Actions and assign to the Function keys.
4. Re: Generate a composite of all layers below.
JJMack Dec 15, 2013 2:16 PM (in response to John_Picton)John_Picton wrote:
I know how useful keyboard short cuts are but I am working with some clients who have limited mobility and that combination is a bit tough.
For sure you can record a single step action to do that however I would record a two steps
Ctrl+Shift+Alt+N
Ctrl+Shift+Alt+E
Then set a F key to that action. Some times Ctrl+Shift+Alt+E does not do anything has to do with what the current Photoshop target is in the current document. Ctrl+Shift+Alt+N add a new empty layer without a prompt and becomes the current target. Ctrl+Shift+Alt+E will stamp visible layers into the current target layer if its empty.
5. Re: Generate a composite of all layers below.
John_Picton Dec 15, 2013 2:20 PM (in response to Trevor.Dennis)Thanks Trevor - yes that works a treat.
Cheers
John
6. Re: Generate a composite of all layers below.
Trevor.Dennis Dec 15, 2013 2:21 PM (in response to JJMack)Thanks for that JJ. 'Ctrl Alt Shift N' was new to me.
7. Re: Generate a composite of all layers below.
John_Picton Dec 15, 2013 2:24 PM (in response to JJMack)Sorry JJmack my last post crossed with yours. Thanks for the suggestion about the additional step for the action, I will do so.
Thanks to all.
Cheers
John
