Bought a new ereader and authorised it correctly with ADE. seems to download a book to the ereader library until i try to open it then it says 'no file found'. In 'annotations' on the reader it also comes up with that message. The books are there in the library on the ereader though!
Next step:
Check the state of the file using the file manager (Windows Explorer or Mac FInder) on your computer.
The ereader should show up as a mounted drive when plugged in.
Navigate to a .epub file on the ereader and see if you can open it with ADE (eg drag/drop it onto ADE).
That should confirm whether the correct file really is on the ereader and not corrupted.
When I try to open the book the message is 'invalid active info.' on the reader. i have just downloaded a new epub book from Adobe's list of sample books. This is ok on the computer and still the same result on the ereader.
Now more developments.....I have actually downloaded a book form Gutenberg and I CAN READ that one on the reader!! What is going on i wonder!
Gutenberg books will usually be fine, no DRM. (aside ... Calibre (free) is much better software than ADE for handling non DRM books)
One more thing to try:
If the file manager copy doesn't work, maybe there is something odd in the ereader registration?
Try to deregister (ctrl-shift-D to ADE with ereader plugged in, cmd-shift-E on Mac) and reregister the ereader (menu/Help/Authorize device).
If that fails too, I'm not sure what to suggest.
If the file manager copy does work, looks like something wrong in the ADE DRM file copy mechanism.
In that case, it may be worth trying with the older more reliable ADE1.7.2
There are lots of bugs in ADE2.0 (and 2.0.1). Try replacing ADE2.0 with the older but more reliable v1.7.2.
(You can have them both installed at once if you like.)
Version 1.7.2, it is a little difficult to find, available on Adobe site for Windows and for Mac.
http://helpx.adobe.com/digital-editions/kb/cant-install-digital-editions.html
The forum software is sometimes corrupting the link above. There shouldn't be a blank in 'editio ns.html'. The following redirects to the same page: http://tinyurl.com/diged172
Some people have found ADE trying to upgrade automatically.
It appears (not 100% sure) that if you install ADE2.0 as a new install (not as an upgrade) that your 1.7.2 will continue to run.
Probably best to say no if 2.0.x installation asks if you want to migrate your library.
Hi, I have been able to install this version on my laptop but can you tell me how I can now get it onto my Pico Ereader. I cannot find an option to change the destination folder for the install. I am getting so very frustrated with this new ereader. I started with Version 2.0 and all I could get was a message when I tried to read the books on the reader which said "file open failed". Thanks Very much. Rina
You don't install ADE on the ereader, it already has the necessary software builtin (assuming it is one that supports Adobe DRM),
If any of those steps fails, post back to say exactly where it failed, and what message you got.
I installed the ADE as per the instructions in the booklet that came with
my Pico Life ereader. Prior to that the message I was recieving read "file
open failed". I followed the steps as you detailed above and still recieved
the same message. I have tried with ADE installed, without ADE installed
and the only difference is now I am also getting a message which says "file
not found". Do you have any other suggestions?
I have just checked the instruction booklet for my reader and it says
double click on the readers disk to open, double click on the
digitaleditions_172 file to open the installer or alternatively you can
download the installer from
http://www.adobe.com/products/digitaleditions/#fp. The download was the
option I used as I could not find the file on my ereader.
Hi again, I am following your steps. Have copied the book across and can
see it in book on my ereader. It is an epub file. I have tried to open it
and the message reads "file open failed"
@Granma Rina Answer on your other thread
