I am trying to launch Adobe Presenter from PowerPoint and keep getting the following error:
"Adobe Presenter has encountered an unexpected problem while working with this presentation. Try saving your work to a new file and restarting PowerPoint. If the problem persists, consult the Help menu item, or contact support at http://www.adobe.com/support/presenter."
Hello,
Adobe Presenter 9 is not certified and supported on MS Powerpoint 2013 64bit (http://www.adobe.com/products/presenter/tech-specs.html)
You may install MS Powerpoint 2013 32bit and then install Adobe Presenter 9 32bit
Vikram
Hello,
Welcome to Adobe Forums.
Which version of Adobe Presenter are you using ?
Which version of MS Office are you using ?
Did you try using Adobe Presneter with a different user account of your computer ?
Does this happen with every presentation or with a specific presentation ?
Vikram
Version 8.0.1.260 Adobe, PowerPoint 2013. This is happening for every presentation. I do not have a different user acct of my computer.
Hello,
Do you have MS Office in 32bit or 64 bit ?
Which windows do have and is it 32bit or 64bit ?
Vikram
Both 64 bit
Hello,
Adobe Presenter 8 64bit is not certified and tested for MS Office 2013 64bit (http://www.adobe.com/products/presenter/tech-specs.html)
Vikram
Vikram,
I am using the newest update of Presenter 9 64 bit with Office 2013 64 bit and am getting the same error message as above. Are there any suggestions for how to solve the issue?
Ed
Hello,
Vikram
