Hi gurus,
I'm trying to create QR code bigger. I mean not with amount of data, but enlarge it. That I'll be able to read it with barcode reader from bigger distance.
I'm using LiveCycle ES2.
Any guesss?
THanks for any answer.
Total Likes
The trick to resizing barcodes within Designer is actually to NOT use the mouse to attempt to resize the barcode itself. Click on the barcode object itself and then resize using the height and width properties of the object. If you try to change the size using your mouse Designer attempts to chose the "best" sizing.
Keep in mind that QRCode will always be square and PDF417 will always be rectangle (you can force it to be square but there would be little to no data capture).
Total Likes
I found that option on Layout tab. But it changes only size of background of QR code but not QR code itself. I put 40 characters in it (it will be approximately like this). Under Width and Height is option Expand to fit(for both), but they are both greyed.
Could you explain it little more how to enlarge QR code(maybe some printscreens)?
Thanks a lot.
Total Likes
In XML Source tab ,Modify the value of the "moduleWidth" and "moduleHeight" fields.
Total Likes
Hi , but i have also get the same requirement to increase the size of the QR code . But i am not able to see the xml source in my layout of this qr code . So can i increase the size please help me out .
Total Likes
Hi, you can prnt the QR Code as vector image, and you may enlarge it by drag it. Or you just set the width, height and bar module size to change size of the generated QR Code. Hope this helps.
Total Likes
Hi psmusic,
Writed you code Whow event for barcode size in adobe form layout? I tried but it is not .
Hope this helps
Total Likes
Total Likes
I'm confused. If the QR code was generated as vector, why can't it just be placed in Illustrator and resized?
I can understand a problem if the QR code was generated as a screened halftone, but it seems the .eps files I'm generating are vector. So can someone help me understand the dilemma?
Total Likes
