Having problems with Flash player for windows 7 ie9
Says I downloaded it fine even verified version and to see if it's working and everything checks out also enabled Flash add ons but yet I went to a link that needs Adobe Flash and it tells me I need Adobe Flash in order to view video. HELP ???
Does it show Flash Player as installed and working: http://helpx.adobe.com/flash-player.html ?
Yes ............or I should say when I go to this link
http://helpx.adobe.com/flash-player.html and check if I have the latest
version it tells me I do and then go to next step to enable Flash in my IE9
in my add on's and I do enable it. then to step 5 verify the clouds moving
and yes they are moving except Flash still won't work ???
Can you post a link to a site that tells you to install Flash Player?
Hi Pat I believe
I'm seeing a common thread here it seems so far that the videos are all
from Yahoo news although I don't know what other sites support Flash
player, You tube works fine, Fox news videos work , Facebook videos work....
http://tv.yahoo.com/nighttime/strange-coincidence-countless-newscasts-092613573.html
Yahoo IS seeing a major problem with IE, but.. NOT IE9. It's IE11 that's not working there lately.
YouTube has almost completely converted everything to "multiformat" (HTML5, Flash and WebM). If your Flash Player isn't working, it'll switch to HTML5 which requires no Plugin. Yahoo hasn't done that yet.
Facebook has seen problems with their image uploader, which uses Flash, but again, that's only with IE11.
You may want to try repairing IE: http://support.microsoft.com/kb/318378
Well Pat I found my problem. I did a system restore recently and for the
heck of it I double checked my ie version and it was ie11 seems I checked
the box that allows for automatic updating which allowed ie11 to be
installed. Any way all is good.
thanks for your help
