1. Re: Device testing with Shared Objects are failing: Error #2130
Mark.fromOP Dec 13, 2013 2:25 PM (in response to spinlight)I am seeing a similar type of error, not sure if it is SharedObject class related I think the debugger might be broken. I am getting an error on the iPad in a place where I get no error on the PC.
2. Re: Device testing with Shared Objects are failing: Error #2130
spinlight Dec 14, 2013 4:54 PM (in response to Mark.fromOP)My projects hang at this line whether I'm in debug mode or not. It doesn't fail until it's running on the device.
3. Re: Device testing with Shared Objects are failing: Error #2130
pranjain Dec 17, 2013 1:41 AM (in response to spinlight)Hi,
I am not able to reproduce the issue.
I tried with the latest AIR 4.0 build on iPad version 7.0 and Flash Pro CC version 13.1.0.217.
Could you please share the Flash Pro version you are using?
Also if possible, please share the sample app as it would help us in investigating the issue.
Pranali
4. Re: Device testing with Shared Objects are failing: Error #2130
spinlight Dec 17, 2013 1:22 PM (in response to pranjain)I wasn't on the 4.0 Beta. It worked under the Beta. Is it safe to create builds for app store distribution with the Beta?
Thanks.
5. Re: Device testing with Shared Objects are failing: Error #2130
Colin Holgate Dec 17, 2013 1:23 PM (in response to spinlight)Yes, though currently AIR 4 has its own serious issues, at least on iOS.
