1. Re: Unable to update Dreamweaver CS5.5 - Update failed
Preran Dec 17, 2013 7:42 AM (in response to palurie)Hi palurie,
Can you check out the solutions in this article? http://helpx.adobe.com/creative-suite/kb/error-u44m1p7-installing-updates-ccm.html
Preran
2. Re: Unable to update Dreamweaver CS5.5 - Update failed
palurie Dec 17, 2013 8:18 AM (in response to Preran)Hi Preran...
could this because I have moved the App files into a subfolder of the Applications folder?
Peter
3. Re: Unable to update Dreamweaver CS5.5 - Update failed
Nancy O. Dec 17, 2013 2:17 PM (in response to palurie)could this because I have moved the App files into a subfolder of the Applications folder?
Can you move them back to where they were originally?
Nancy O.
4. Re: Unable to update Dreamweaver CS5.5 - Update failed
palurie Dec 17, 2013 3:15 PM (in response to Nancy O.)Hi Nancy:
I have done this and retried updating, and the error still occurs. I also tried looking for the Installer in the Downloads section, but this particular updater isn\t posted there. (11.5.3)
Peter
5. Re: Unable to update Dreamweaver CS5.5 - Update failed
Nancy O. Dec 17, 2013 3:36 PM (in response to palurie)This is the very last update for CS5.5 -- issued 7/24/2012
http://www.adobe.com/support/dreamweaver/downloads_updaters.html#dwcs551151
You might have a corrupted cache and/or personal config folder.
Start by deleting your cache.
http://forums.adobe.com/thread/494811
If that fails to help, you may need to do a clean re-install. Backup your preferences and custom snippets before you run the CS Cleaner Tool.
http://helpx.adobe.com/creative-suite/kb/cs5-cleaner-tool-installation-problems.html
Good luck!
Nancy O.
6. Re: Unable to update Dreamweaver CS5.5 - Update failed
palurie Dec 19, 2013 6:09 AM (in response to Nancy O.)Nancy! Thanks for writing.
I have Dreamweaver5.5 v11.5 Build 5366 installed. The Adobe install centre tell me I need to update to 11.5.3 with the installer.
Wondering why this has just appeared? I have had Dreamweaver for many months.
You refer to the last update as 7/24/2012... does this update to 11.5.3? Do I have to update to 11.5.1 first (another updater on the site?)
This may be the issue... except it doesn't sy that I need to run the other installer first.
Let me know
Peter
7. Re: Unable to update Dreamweaver CS5.5 - Update failed
Nancy O. Dec 19, 2013 10:46 AM (in response to palurie)The latest updates are all inclusive.
Nancy O.
8. Re: Unable to update Dreamweaver CS5.5 - Update failed
palurie Dec 20, 2013 10:31 AM (in response to Nancy O.)Hi Preran:
This finally worked. I had to uninstall and reinstall.
Best wishes.
Peter
