2 Replies Latest reply: Dec 19, 2013 10:51 AM by ZenDao RSS
    Crop Dimensions Issue CS5 vs CS6
    ZenDao Community Member
      I am transitioning from Photoshop CS5.5 CS6.
      Using CS6, I was cropping a photo and I defined an exact pixel dimension of 94px x 99px with an output 72ppi.When I went to resample it in the Image dialogue box to 94px x 99px. I was able to get the desired width of 94px but the height ended up being 89px. If I cropped it to the correct dimensions, why can't I do the same when I re-sample it?
      I went back to CS5.5 and it did it flawlessly. I can't figure out what is going on with CS6.
        • 1. Re: Crop Dimensions Issue CS5 vs CS6
          c.pfaffenbichler Community Member
          Did you check »Constrain Proportions«?
          • 2. Re: Crop Dimensions Issue CS5 vs CS6
            I tried it with Constraint Proportions on before. I went back to the image file again and apply the cropping, restraining the size to 94px x 99px in CS6 and saved the file without the image resampling.
            I just notice when I apply the cropping again in CS5, it cropped the picture slightly differently and got the results I wanted after resampling.
            So if I restrained the dimensions when I cropped the image in both C5 and CS6, why is CS6 cropping it differently? I notice there are some extra options in C6 tool bar where you define the cropping measurements, (I'm not in front of the computer right now so this may not be accurate), I think there is an option to crop off white edges or something. Maybe there's a feature that is new I'm overlooking?
