3 Replies Latest reply: Dec 29, 2013 9:58 AM by -hans- RSS
    math / array / matrix-question
    -hans- Community Member
      Hallo everybody,
      first of all: it's not a indesignscripting-  but general math-javascriptquestion. please be patient
      I've got a first (matrixlike-)array (won't change)
      var containers = [
      'container11', 'container12', 'container13', 'container14', 'container15',
      'container21', 'container22', 'container23', 'container24', 'container25',
      'container31', 'container32', 'container33', 'container34', 'container35',
      'container41', 'container42', 'container43', 'container44', 'container45',
      'container51', 'container52', 'container53', 'container54', 'container55'
      and I've got a second array:
      ["container14", "container25", "container34", "container44", "container54"] //this array may contain 3 up to 8 items
      My aim is to check if a part of 5 to 3 items of the second array is part of or equal to a row or column of the matrix-like-array.
      For example: "container34", "container44", "container54" or "container11", "container12", "container13", "container14" (as part of second array) would be a result I#m looking for. Note: I only want to find the 'biggest charge'!
      Hope it's getting clear and one of the math-cracks will have a idea.
      Addittional: there's no MUST to work with arrays. I can also store the data to a object or mixture ... and may fill it with numbers instead of strings ...
      To get it visible:
      https://dl.dropboxusercontent.com/spa/3ftsuc9opmid3j4/Exports/fourWins/fourWins.html
      Items can be dragged and dropped. After every dropp the arrays have to be compared ... and I#m searching for a nice and elegant solution
      May be someone's interested
      Hans
        • 1. Re: math / array / matrix-question
          Good morning,
          splitted the sourcearray to its 'cols' and 'rows' to compare each with the resultarrays.
          Solved
          Hans
          • 2. Re: math / array / matrix-question
            Marc Autret MeganK
            Hi Hans,
            Just a quick note although your question is solved.
            Provided that your matrix is 5×5 you could easily map any element to a single character in the set { A, B..., Z } (for example).
            Then your problem can be reduced to some pattern matching algorithm, that is, finding the longest part of the input string within a 'flat string' that just concatenates the rows and the columns of the search matrix in the form ROW1|ROW2...|COL1|COL2...|COL5
            And you can create RegExp on the fly to compute the solution(s) with almost no effort:
            const MX_ORDER = 5;
            const MIN_MATCH = 3; // We need at least 3 contiguous items
            var bestMatrixMatch = function F(/*str[]*/ROWS, /*str*/ND)
            // NB: No check is made on ROWS, so make sure you supply
            //     MX_ORDER strings, each being MX_ORDER-sized
                // Put in cache some subroutines
                F.RES_TO_STR ||(F.RES_TO_STR = function()
                        return localize("'%1' found in %2", this.result, this.location);
                F.ROWS_TO_HS ||(F.ROWS_TO_HS = function(R, C,i,j)
                        for( i=0,C=[] ; i < MX_ORDER ; ++i )
                        for( C[i]='',j=0 ; j < MX_ORDER ; C[i]+=R[j++][i] );
                        return R.concat(C).join('|');
                // Vars
                var haystack = F.ROWS_TO_HS(ROWS),
                    candidates = ND &&
                        haystack.match( new RegExp('['+ND+']{'+MIN_MATCH+',}','g') ),
                    t, p;
                if( !candidates ) return null;
                // Sort the candidates by increasing size
                candidates.sort( function(x,y){return x.length-y.length} );
                // Grab the matches and keep the best
                while( t=candidates.pop() )
                    if( 0 > ND.indexOf(t) ) continue;
                    p = 1+~~(haystack.indexOf(t)/(1+MX_ORDER));
                    return {
                        result:   t,
                        location: (p<=MX_ORDER)?('Row #'+p):('Col #'+(p-MX_ORDER)),
                        toString: F.RES_TO_STR,
                return null;
            // Sample code
            var rows = [
                "ABCDE",
                "FGHIJ",
                "KLMNO",
                "PQRST",
                "UVWXY"
            var needle = "EKLMINSX";
            // get the result
            var result = bestMatrixMatch(rows, needle);
            alert(
                "Searching the longest part of '" + needle + "' in:\r\r" +
                ' '+rows.join('\r').split('').join(' ') +
                '\r\r===============\r\r' +
                (result || "No result.")
            Marc
            • 3. Re: math / array / matrix-question
              sorry for the late reply. works like a charm
              Perhaps, some day I'll even understand how ... ;-)
              Hans
