Does anyone know why my Pico Life ereader with ADE installed will not open my library books. Message reads "file open failed"
I assume you have gone through all the step of authorizing ADE, and then authorizing the device?
Can you read the book on ADE itself?
Does this happen for all DRM books or just for one/some?
When I had a Bookeen Opus ereader I found that a small proportion of books would not work on it;
some just would not open, and sometimes trying to read them would even crash the ereader.
I haven't had a similar issue with my Sony PRS-350.
Yes I have gone through the authorizing steps and I can read the book on
ADE itself both on my laptop and also on the ereader while it is plugged
into the laptop it just will not open when the reader is unplugged. I have
tried downloading sample books from ADE site but the first one gave me a
message saying the licence is fullfilled by another user and the second
book I downloaded would not allow copying to the ereader.
I have tried another ebook site and I can download and read books in PDF
format. Can I convert epub to pdf using ADE before I copy the book to my
ereader? If I can do that then I can read books from my public library
which was the reason I bought the reader in the first place.
On Tue, Dec 24, 2013 at 8:06 AM, Rina Tunstall
No you can't convert DRM ebooks.
Another possibility. ADE2.0 has many bugs.
One curious bug is that for some ereader devices (including my Sony) it can operate with most books, but not with Overdrive library books.
For me, I can't even read the library book on ADE itself if the Sony is plugged in.
Luckily, the older version of ADE does not have this bug (ADE2.0 was primarily a bug insertion release), so try that and see if it helps.
There are lots of bugs in ADE2.0 (and 2.0.1). Try replacing ADE2.0 with the older but more reliable v1.7.2.
(You can have them both installed at once if you like.)
Version 1.7.2, it is a little difficult to find, available on Adobe site for Windows and for Mac.
http://helpx.adobe.com/digital-editions/kb/cant-install-digital-editions.html
The forum software is sometimes corrupting the link above. There shouldn't be a blank in 'editio ns.html'. The following redirects to the same page: http://tinyurl.com/diged172
Some people have found ADE trying to upgrade automatically.
It appears (not 100% sure) that if you install ADE2.0 as a new install (not as an upgrade) that your 1.7.2 will continue to run.
Probably best to say no if 2.0.x installation asks if you want to migrate your library.
