I am using Robohelp 10 on Win 7 OS
After renaming some files and folders in the Project Manager, I closed RoboHelp and when I tried to open the project again it was corrupted. Got the message "Robohelp stopped working" and could not open the project.
I wonder if I broke some rule(s) for using Project Manager. Here's what I did:
Do any of these actions break the rules of using Project Manager?
It may be helpful to also note that i have not as yet created a ToC for this project
One more note: fortunately i had a backup of the project. I opened this project and after i made the following changes, the project was corrupted:
What option is not permissible?
They are all permissible. If your project is still corrupted, try deleting the <projectname>.cpd file and reopen the project.
robocolum(n),
Thank you for the tip.
In the meantime i created a new project and am building the project folder/file structure from scratch by creating the new folder and then importing the html files from the old project.
I started the old project by importing a framemaker project and i think there are a lot of residual "stuff" in the windows explorer directory structure that makes it easy to break when shuffling things around from inside robohelp.
By just importing the html files into a new folder in a new project seems to create a cleaner project --and so far it is not breaking.
RoboColum(n)
After I had been working on my project for several hours (wherein i made a few changes to some topic properties), i closed my project and the problem noted previously occurred again barring me from opening the project.
Thanks to your suggestion, I tried deleting the CPD file and i was able to open the project.
Using your tip saved me from having to refer to the backup where i would have lost several hours of tedious work.
Thanks for the tip.
