I'm trying to create a Sarbanex Oxley Application using RoR [
Ruby on Rails ] and Adobe Flex. The concept is fairly simple:
3 Main Tables [ Databases , Servers , Applications ]
3 Join Tables [ Databases-Servers, Databases-Applications,
Server-Applications ]
The relation on the join tables is 1 to Many. that means one
server can have multiple databases or multiple applications etc...
Ok the Ruby on Rails let me create the web-application,
trying to use the HTTP Services with XML to complete my application
found a problem with DataGrid.
I have 3 Canvas in my Flex application in a Horizontal
Alignment. the left is for example the array from the rails xml for
the Servers, later my goal the join table empty at this time. the
last dataGrid is the rails xml for the Databases. What I'm trying
to do is to be able to drag or click and automatically select a
particular server to be added to the join table later another click
on the databases list and propagate to be considered as the new
join record.
DataGrid did not like the click, I needed to use some text
field to propagate my clicks, It's ok, I can click the Servers and
retrieve the name later click on the Databases and populate in my
two text fields, the question of the million
How can I populate in a hidden way the value of the ID of the
Server and the Value of the ID of the Database since is the only
data that rails will be required to make the insert into the DB ???
I wonder if DataGrid can populate more than 1 value to send me that
information that is included in the XML ???
The other question is, is there a way to validate if the Join
selection that I'm making does not exist already in the DB Join
table for the Servers& Databases ??? perhaps some Action Script
to see if that join does not exist already in memory and alert or
prevent duplicated inserts ???
Thanks in advance for any suggestion !!!.
Best Regards Dino.
