Is it possible to create Map IDs using the File name of the HTM, instead of its Topic Title?
The MapID part of a CSH call can be anything text you want. It links to a map number to link to the HTM file. Is that what you are asking? If not, please explain a little more of what you are trying to achieve.
While Generating Map IDs, we get an ID along with a Map # for each HTM in the CSH.
For Example, I have a HTM in my CSH with the following Details:
Topic Title - Access Masks
File Name - admpr00001.htm
Now when I create a Map ID for this page. I can customise the Map ID by setting any/all of the three options: - 'Prefix Map IDs with', 'Make Uppercase' and 'Start Numbering with'. But the Map ID is generated only based on the Topic Title.
Like - ebACCESS_MASKS 1000 where, eb is the set prefix.
Is it possible for me to create a MAP ID using the File Name. In this case, as ebadmpr00001 1000?
Hope I am clear .
Yes it is. Just set the prefix to eb and create the mapid the way you want.
RoboColum(n),
I think misk0105 wants to auto-generate IDs for all topics at once using the file name, by highlighting all topics and clicking Auto-map. Of course one could type in the ID manually.
The way the Auto-map works in my instance (RH10) is to assign the topic name. The help says "By default, the application assigns the topic title or filename as the topic ID and assigns a map number," but where can you change it to use the filename?
