I have downloaded both adobe digital editions 2.0 and 1.7 and have authorized my device and my computer with my adobe id. it still won't let me open my borrowed epub book. it comes up as "oops! This document couldn't be opened...not currently authorized for use with your adobe id. please sign in with the authorized adobe id and try again.'
not sure what else to do, would really like to read a book with my ereader....
Just checking ...
thanks for taking the time to respond to my question!
1. yes i can read the book on my computer through ade
2. yes ade allowed me to copy it to my kobo, the book is on my kobo, but the picture is black and when i press on it to open it the warning comes up about not being able to open it.
3. the other books that are on my reader say "KOBO EPUB" beside them and I can read them.
I'm afraid I can't think of much else to suggest.
Is this all borrowed books or just one?
When I had a bookeen Opus I found a few books that it just could not open (including one that crashed the Opus when it tried).
Maybe you have hit the same issue with the Kobo?
It might be worth trying a DRM stripper such as epubee and seeing if you can read the stripped book on the Kobo.
I do NOT advocate using such code to get around the valid limitations placed on a DRM book.
However, where the problem arises only because of the ineptness of Adobe's ADEPT DRM infrastructure and its implementation,
such a measure is totally justifiable.
I am having the EXACT same problem!
I am not willing to try a "DRM stripper"
I have also tried installing the earlier (apparently more reliable) version of ADE and this also did not work.
Are these forums the only way to access customer support for Adobe Digital Editions?
It is quite rare that any Adobe people respond on this forum.
You can try Live Chat, but as ADE is free they are apparantly not usually willing to help except for resetting authorizations (when you have too many devices authorized).
Adobe Live Chat: http://www.adobe.com/support/chat/ivrchat.html,
or as a slight short cut try http://helpx.adobe.com/contact.html?product=digital-editions&topic=using-my-product-or-service
Click on 'I still need help' and then you should see 'Chat with an Agent' at the bottom of the page.
'Ask our experts' will indeed just lead you back to this forum.
Sometimes you will get ‘Sorry! All agents are busy— please check back soon.’
Don’t refresh the page, just hang on and it should eventually go to ‘Chat Now, and agent is available’.
"Ask our experts" is the only option given. Nothing about chatting with an agent.
Thank you very much for trying to help!
Just checked, and I see my instructions were incomplete or they have change the details.
Once you have the page up, you must select a topic from the list (any topic) before you go on to 'I stilll need help'
I still just get "Ask our experts"
There are a few links to generic help pages that don't address my problem
Odd, working for me. I assume you are logged in as you are using the forum?
A screenshot below just in case it triggers an idea. Good luck
I finally got through to a live chat with Adobe (Yay!).... it wasn't a problem with Adobe at all. All I had to do was a factory reset on my Kobo Touch. After that everything worked fine.
To do the factory reset you just have to go to the menue icon in the top right corner > Settings > Device Info > Factory Reset
Then follow the prompts for setting up your device again
Thank you so much! I am going to try this.
Thanks so much for the time and effort you put into helping me, it is much appreciated
I had this issue as well. I couldn't open DRM protected books from the library.
(I bought a new kobo aura.)
My solution that I finally figured out after days and days of frustration was:
Go into where your kobo file on your computer.
Right click and run the trouble shooter.
Once that is done reboot your computer.
Open digital editions and plug in your kobo.
Authorize device. (Computer you should have authorized before)
Now drag and drop your library book onto kobo.
Eject your kobo.
You should be able to open your books on the kobo
Don't know how you went. But the only way I got to read library books was to delete digital editions 4.0 and install 3.0. works fine now
I didn't understand the instructions from "friend of adobe" above, but snlundie's suggestion worked perfect. Downgraded to 3.0 and problem solved.
I've had this problem a number of times. Sometimes a factory reset has resolved it...but not this time. All the books I downloaded from my local library can be read in ADE on my laptop. But some of them wouldn't open on my Kobo - black icon & an 'oops, this item is DRM protected'. Hours & hours of my life have been spent on this. I think I've finally come up with a solution. I downloaded Calibre and installed a plug in (see How to remove ebook DRM with Calibre | TechRadar) for instructions. Now I download the book from the library to ADE...and then move the file to Calibre and then transfer them to my Kobo. What a pain...but at least I can now read my library books. No, I'm not spreading them all over the internet...no, I'm not a thief. I just want to read my legally rented library books on my Kobo.
