CF10: Address already in use: JVM_Bind
Aug 22, 2013 Aug 22, 2013
After a fresh install of CF 10 multiserver I have made 6 instances.
After a reboot of the server 4 of the instances have an exception:
"Address already in use: JVM_Bind"
java.net.BindException: Address already in use: JVM_Bind
    at java.net.DualStackPlainSocketImpl.bind0(Native Method)
    at java.net.DualStackPlainSocketImpl.socketBind(DualStackPlainSocketImpl.java:96)
    at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:376)
    at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:175)
    at java.net.ServerSocket.bind(ServerSocket.java:376)
    at java.net.ServerSocket.<init>(ServerSocket.java:237)
    at java.net.ServerSocket.<init>(ServerSocket.java:128)
    at coldfusion.server.jrun4.metrics.CfstatServer.run(CfstatServer.java:71)
All the features and applications seem to work. But I'm not convinced.
Can someone please help me?
My server details:
System Information
Server Details
Server Product  ColdFusion
Version  ColdFusion 10,283922
Tomcat Version  7.0.23.0
Edition  Enterprise
Operating System  Windows Server 2008 R2
OS Version  6.1
Adobe Driver Version  4.1 (Build 0001)
JVM Details
Java Version  1.7.0_15
Java Vendor  Oracle Corporation
Java Vendor URL  http://java.oracle.com/
7.2K
Adobe Employee ,
Hello Jurriaan,
The "Address already in use: JVM_Bind" error signifies that, ColdFusion’s internal port are being used by some other process.
Can you check the Server shutdown port in server.xml. <Server port="XXXX" shutdown="SHUTDOWN">, where XXXX is the port number . If that port is already in use by the other instance, please replace XXXX by any other port no it use.
You also need to check the port numbers for <Connector port="XXXX" protocol="AJP/1.3" redirectPort="XXXX" tomcatAuthentication="false" />
Please take a backup of your existing server.xml(s) before making the changes.
After that, try to restart the server and check if you are still facing the issue.
Note:- To check the list of ports in use, please Launch Command prompt as Administrator and type the command netstat –ano.
Anit Kumar
Aug 26, 2013 Aug 26, 2013
Due to a few others bugs in CF10 that where not to be fixed by Adobe we downgraded to CF9.
In just 2 hours of installation all our CF10 troubles where gone. CF9 works PERFECTLY for us.
Jurriaan Balleur
Dec 27, 2013 Dec 27, 2013
Having the same problem and can find no port conflicts; still the same error even when I change the ports to something else not in use.
Will open a call with CFInstall next week.
Adobe Employee ,
You can try Launching Command prompt as Administrator. Type the command netstat –ano and press enter. Please append the output to a text file and check the port usage.
Anit Kumar
Dec 31, 2013 Dec 31, 2013
I did that prior to posting in the forum; have dealt with port conflicts in the past, so was used to debugging that way.  Unfortunately, there are no port conflicts:  none of the ports in use by the CF instance are being used elsewhere on the system as far as the output in the text file shows.  I also tried changing the ports (Shutdown, Connector, Redirect) to other ports, but the results were the same error message.  I will work on it again this afternoon, and let you know the results.
Scott
Feb 28, 2014 Feb 28, 2014
Hi spellbmw,
Did you find out something to sove this problem ?
thanks
Stephane
Here is my config :
instance #1 (cfusion)
<Server port="8007" shutdown="SHUTDOWN">
<Connector port="8012" protocol="AJP/1.3" redirectPort="8445" tomcatAuthentication="false" />
instance #2
<Server port="8008" shutdown="SHUTDOWN">
<Connector port="8013" protocol="AJP/1.3" redirectPort="8446" tomcatAuthentication="false">
So I stop both instances, then start instance #1 :
none of the instance #2 ports (8008, 8013, 8446) appears in netstat -ano...
Then I start the instance #2 :
I immediately get the "Address already in use: JVM_Bind" entry in exception.log of instance #2...
Stephane
Hi Stephane,
No, I did not find a resolution to this.  I've been working with Adobe CF support on and off for four months now and am not able to get CF10 to cluster with session replication on Windows 2012; still working on it.
Scott
Aug 19, 2015 Aug 19, 2015
I can see the same issue in our Linux (Redhat) CF10 cluster. I tried to change the different ports as suggested but it doesn't change anything.
Do you have more information concerning this issue?
Thanks.
Christophe
Feb 02, 2016 Feb 02, 2016
I had this problem, and couldn't find any duplicates checking the ports with
sudo grep -i port /opt/coldfusion10/*/runtime/conf/server.xml
Then i realised that the Jenkins server running on this machine was using port 8009
sudo netstat -lptu|grep 80
sudo netstat -lptu|grep 85
Aug 12, 2020 Aug 12, 2020
I know this post is 7 years old, but I came across this same problem today: someone running CF10, where it would not start, and the ports reported in the log as "in use" were very clearly NOT in use. And it was the AJP and http ports, so while CF "started", neither the admin nor any web site would work.
With no choice, the box (Windows) was rebooted--and lo and behold, now CF started, with no errors, and the admin and sites now worked. FWIW, there were in fact Windows updates "pending a restart". Perhaps something was in an unexpected state.
Just sharing this if anyone else ever hits the same situation.
/Charlie (troubleshooter, carehart.org)
Documentation
