Is it possible to transfer DRM books to an android tablet (BQ Edison) so i can read the book without a wifi or 3g connection?
You should be able to install Bluefire on the tablet.
Register it with the same Adobe ID you use on ADE.
Copy the book to the tablet, either using a usb connection and file manager copy of the file to the tablet as mounted drive,
or copy more indirectly using utility such as Dropbox.
You should then be able to read the books on Bluefire.
Thank you very much, sjpt. Worked perfect.
