3 Replies Latest reply: Jan 5, 2014 9:42 AM by zipkiev RSS
    Can i do Expression to keyframes and smooth via script?
    zipkiev Community Member
      hi guys, who know AE scripts can translate expression to linear keyframes via script(now i use app.executeCommand(app.findMenuCommandId("Convert Expression to Keyframes")) ; command) but , for Comman work i must select every time property of layer(opacity, position, scale, etc) where i have expression.... but i need translate very many layers, i always click on property with expression and then do Convert Expression to Keyframes its to long.., can i do something like this
      for (var j= 0; j<selectedLayers.length; j++)
                         var SelLaye= selectedLayers[j];
                         if (SelLayer.transform.opacity.expression!=null && (SelLayer.transform.opacity.expression!=null) && (SelLayer.transform.opacity.expression!=null)) //check if layer have expression
                               SelLayer.transform.position.select=true;  //and here i need set cursor to position, expression, etc, where i have expression and translate to linear kayframes(but i dont know how)
                               app.executeCommand(app.findMenuCommandId("Convert Expression to Keyframes")) //do translation
                               SelLayer.transform.rotation.select=true;
                               SelLayer.transform.scale.select=true;
                               //and after this also need do a smoother or something like this for decreasing linear keys for max(because app.executeCommand(app.findMenuCommandId("Convert Expression to Keyframes")) create to many keyframes)
      sorry for bad English
