1. Re: image export/import script won't work, need guru help
David Torno Dec 4, 2013 2:22 PM (in response to zipkiev)You are not referencing a file object for your ImportOptions argument, only a string. You may want to cleanup the function a bit too.
Instead of this:
function test(){
var myProj = app.project;
var myComp = myProj.activeItem;
app.project.activeItem.saveFrameToPng(app.project.activeItem.time, new File("C:\\Users\\UserName\\Desktop\\1111\\2test.png"));
var importOptions = new ImportOptions("C:\\Users\\UserName\\Desktop\\1111\\2test.png");
var importImg = app.project.importFile (importOptions);
myComp.layers.add(importImg);
Try this this setup. It's a little more organized and you don't need to call the activeItem everytime, just the one time and store it in a variable.
function test(){
var myFile = new File("C:\\Users\\UserName\\Desktop\\1111\\2test.png");
if(myComp instanceof CompItem){
myComp.saveFrameToPng(myComp.time, myFile);
var importOptions = new ImportOptions(myFile);
var importImg = myProj.importFile (importOptions);
2. Re: image export/import script won't work, need guru help
zipkiev Dec 7, 2013 2:09 PM (in response to David Torno)thanks, it exactly is what i need
3. Re: image export/import script won't work, need guru help
zipkiev Dec 14, 2013 12:20 PM (in response to zipkiev)I found a bug when I use a command app.project.activeItem.saveFrameToPng in script, all Created Pictures(png file) have a black glow around the perimeter ( they are not suitable in this condition for further work with them) can this bug be correct?
Oh... then everything was just perfect with the script , (it exports and imports pictures as I wanted) to but because of this problems script useless .... there is clearly a problem in app.project.activeItem.saveFrameToPng , so bad
Please someone check with app.project.activeItem.saveFrameToPng (app.project.activeItem.time, new File ("C: \ \ Users \ \ UserName \ \ Desktop \ \ 1111 \ \ test.png")); and say you have black glow on image?
PS Function "Composition> Save frame As ...> file" works as it should and frames are stored, without black on image
what are the other alternatives? , such as can be possible to use Composition> Save frame As ...> file via script to automatical save to png in one click?
sorry for bad english
4. Re: image export/import script won't work, need guru help
David Torno Dec 14, 2013 1:48 PM (in response to zipkiev)Odd, I haven't come across this issue, I also haven't tested it on PC though. It works fine on Mac. I can try it on a PC machine at the office, but that won't be until Monday unfortunately.
5. Re: image export/import script won't work, need guru help
zipkiev Dec 15, 2013 12:31 PM (in response to David Torno) -
6. Re: image export/import script won't work, need guru help
David Torno Dec 15, 2013 1:02 PM (in response to zipkiev)Ah, that looks like an image with alpha that is not set to premultiply.
7. Re: image export/import script won't work, need guru help
zipkiev Dec 15, 2013 1:44 PM (in response to David Torno)if i use Composition> Save frame As ...> file " then set png sequence, rgb+alpha AE rendering png file with good alpha, but if i use app.project.activeItem.saveFrameToPng AE creates png with black, i try google search for more options for saveFrameToPng but didn't find anything, haw i can fix this "premultiply" bug?
8. Re: image export/import script won't work, need guru help
Arie Stavchansky Dec 17, 2013 10:40 AM (in response to zipkiev)You may need to create a specific Render Template (Edit > Templates > Render Template) for exporting a composition to PNG + alpha. Then, instead of using app.project.activeItem.saveFrameToPng, you would simply need to write code to add the current frame of the current composition into your render queue, and then render it out to a file of your choice.
Here is some code to help you understand what I am suggesting:
var renderComp = app.project.activeItem, frame = 15; //assumes you know how to get the current position in the comp's timeline as a frame number app.project.renderQueue.items.add(renderComp); app.project.renderQueue.item(1).applyTemplate("CUSTOM PNG RENDER TEMPLATE"); app.project.renderQueue.item(1).outputModule(1).applyTemplate("CUSTOM PNG OUTPUT TEMPLATE") app.project.renderQueue.item(1).outputModule(1).file = File("/path/to/where/you/want/to/save/export/png"); app.project.renderQueue.item(1).timeSpanStart = (frame/renderComp.frameRate); app.project.renderQueue.item(1).timeSpanDuration = renderComp.frameDuration; app.project.renderQueue.render();Your file should now be rendered as if it was rendered out of the render queue with your custom render template.
Best,
Arie
9. Re: image export/import script won't work, need guru help
David Torno Dec 19, 2013 12:17 PM (in response to zipkiev)Curious, have you tried setting the image alpha to premultiply when importing it back in, or are these png outputs being used outside of AE?
Pg. 70 in the CS6 Scripting Guide
FootageSource alphaMode attribute:
app.project.item(index).mainSource.alphaMode
app.project.item(index).proxySource.alphaMode
Description:
The alphaMode attribute of footageSource defines how the alpha information in the footage is to be inter- preted. If hasAlpha is false, this attribute has no relevant meaning.
Type:
An AlphaMode enumerated value; (read/write). One of:
AlphaMode.IGNORE
AlphaMode.STRAIGHT
AlphaMode.PREMULTIPLIED
10. Re: image export/import script won't work, need guru help
David Torno Dec 19, 2013 12:21 PM (in response to zipkiev)Another thing you could try too, is to make sure there is a solid as the bottom layer in the composition, so the exported PNG would not have an alpha issue. This is of course is assuming that you do not need the alpha on this export.
11. Re: image export/import script won't work, need guru help
zipkiev Dec 20, 2013 1:26 AM (in response to David Torno)Hi guys...
thx, i will try this
thx David for try helping, but i don't understend how i can use this code
AlphaMode.IGNORE
AlphaMode.STRAIGHT
i used command saveframetopng() where i can set alpha mode for it(or for layer what i used for export)
now problam in savefremetopng 100%, becouse when i save frame from AE to windows folder this frame already has black!!
i need export good png, becouse i use this png in other place(in 2d game engine) so i need true alpha image without black
12. Re: image export/import script won't work, need guru help
David Torno Dec 20, 2013 8:51 PM (in response to zipkiev)i need export good png, becouse i use this png in other place(in 2d game engine) so i need true alpha image without black
Ah, ok. The alpha mode isn't gonna help you then. It's a process within AE to interperet the alpha channel of an asset for use in AE.
I think Arie's solution may be your best bet. It's more involved to create the PNG, but should do solidly for you.
13. Re: image export/import script won't work, need guru help
zipkiev Dec 30, 2013 7:08 AM (in response to David Torno)i used Arie Stavchansky method , and it works(there are the problems with adding 00000(number of frame) to file name, and fix this with renaming file name), but now i have new question, has AE script can check if template preset exist? then select it, or create new template via script?
14. Re: image export/import script won't work, need guru help
Arie Stavchansky Dec 30, 2013 8:51 AM (in response to zipkiev)Glad you were able to get it to work. I now recall that file naming bug. Glad you fixed that one, too.
You can retrieve an array of available templates via some method that I cannot recall at the moment. Do a search / find in the Scripting guide for "templates" and you'll find the code. Once you have that array, you can write code to check and see if the one you want to use is in there. If it is, use it.
When I'm back at my desktop I can provide more details, but maybe that's a good start.
--Arie
15. Re: image export/import script won't work, need guru help
Arie Stavchansky Dec 30, 2013 12:10 PM (in response to Arie Stavchansky)Here is the documentation I was referring to in my last post. On page 168 of the CS6 guide:
RenderQueueItem templates attribute
app.project.renderQueue.item(index).templates Description
The names of all Render Settings templates available for the item. See also “RenderQueueItem saveAsTem- plate() method” on page 167.
Type
Array of strings; read-only.
16. Re: image export/import script won't work, need guru help
zipkiev Dec 30, 2013 1:24 PM (in response to Arie Stavchansky)also i have problem with render Queue(if RQ has not rendered/rendered items), for example i need save all renders what i do early, but if i lunch script it not work properly and do something weird(like rendering all files in render Queue, or rendering one file but not my one frame, or other stuff...) now for code work i try do loop, for cleaning render Queue and after that add my file render preset(but i want to save all previous render if its possible?)
example of code:
for (i = 1; i <=app.project.renderQueue.numItems; i++)
app.project.renderQueue.item(i).remove();
frame=activeframenimber;
RQindex=app.project.renderQueue.numItems;
app.project.renderQueue.item(RQindex).applyTemplate("test_template");
app.project.renderQueue.item(RQindex).outputModule(1).applyTemplate("test_template2") //can find how i can create this template via script
app.project.renderQueue.item(RQindex).outputModule(1).file = File("C:\\Users\\username\\Desktop\\1111\\"+filename);
app.project.renderQueue.item(RQindex).timeSpanStart = (frame/renderComp.frameRate);
app.project.renderQueue.item(RQindex).timeSpanDuration = renderComp.frameDuration;
app.project.renderQueue.render(RQindex);
app.project.renderQueue.item(RQindex).remove();
Also i try add RQindex to set index element of renderQueue, i think AE script must work with RQindex index, but it not work, so for now i must clean render queue every time
17. Re: image export/import script won't work, need guru help
zipkiev Dec 30, 2013 1:55 PM (in response to zipkiev)UPD
just see:
this code not work
and this also
var i=0;
while (i <app.project.renderQueue.numItems)
i++;
what wrong with it? how i can clean my RQ?
18. Re: image export/import script won't work, need guru help
Dan Ebberts Dec 30, 2013 2:01 PM (in response to zipkiev)You should probably start at the end of the queue and move backwards:
for (var i = app.project.renderQueue.numItems; i > 0; i--)
Dan
19. Re: image export/import script won't work, need guru help
zipkiev Dec 31, 2013 2:13 PM (in response to Dan Ebberts)tnx Arie, for your reply, but i don't understand from CS6 script guide how i can create template from scratch(via script), i think method
RenderQueueItem saveAsTemplate() get a already created item present in RQ and save it to templates?
thx also Dan, back loop is working fine, but who know? can i use my script without cleaning RQ or its is bug of AE? and AE cant add new item without affecting on other items that is already in Queue?
with 2014 Year Guys thx2all
20. Re: image export/import script won't work, need guru help
Dan Ebberts Dec 31, 2013 2:22 PM (in response to zipkiev)When you remove item 1, the remaining items get renumbered, so when you next remove item 2, it is actually the original item 3, and the original item 2 (now item 1) gets left behind. I guess you could continually remove item 1 until the queue is empty (but I've never tried it).
Dan
21. Re: image export/import script won't work, need guru help
Arie Stavchansky Jan 2, 2014 8:19 AM (in response to zipkiev)I'm not sure it is possible to create a render template via scripting. I have not tried it, and I've always assumed that a user would create the template via AE's GUI. If you find out how to do it, please let us know.
22. Re: image export/import script won't work, need guru help
zipkiev Jan 2, 2014 1:52 PM (in response to Arie Stavchansky)thx for reply, i searched in internet and i think creating templates via script is impossible?, i want cheaty i try find my presets(test_template, test_template2) in AE files for writing my templates to this file(via script), and i find this AE preference file, but structure of this AE preference file is totally not readable ( for AE cs5.5 in windows it stores here C:\Users\username\AppData\Roaming\Adobe\After Effects\10.5\Adobe After Effects 10.5-x64 Prefs.txt) so, for now i will be ignoring, this problem.....oh so bad....
PS also i cant find(in google,ae scripting sites) example for working with templates array, who can post little example?
PS2 AE scripts has command something like mycomp.SetFocus()? because when i add comp to render, focus transfer to RQ, but i need get it back to my comp.
23. Re: image export/import script won't work, need guru help
cty71 Jan 4, 2014 10:09 AM (in response to David Torno)Dan! I'm trying to understand how to set alphaMode on import. For some reason a few of my imported sequences have 'alpha ignored" no matter how I set up the import preferences. I am able to use remeber interpretation but would like to avoid having to do this step and have the import script set the alpha mode. I've modified the SmartImport script a bit to import and drop the files into a comp. I'd also like to force the alphamode to be premultiplied at the same time. Is there a simple way to do this?
This is what I have:
var myFootageItems = [];
var myFootage = app.project.importFile(importOptions);
myFootageItems.push(myFootage);
for (var i = 0; i < myFootageItems.length; i++){
//add footage to comp
myComp.layers.add(myFootageItems[i],masterComp.duration);
24. Re: image export/import script won't work, need guru help
Dan Ebberts Jan 4, 2014 10:16 AM (in response to cty71)I haven't tried this, but I think it would be like this:
myFootageItems[i].mainSource.alphaMode = AlphaMode.PREMULTIPLIED;
Dan
25. Re: image export/import script won't work, need guru help
cty71 Jan 4, 2014 3:30 PM (in response to Dan Ebberts)Thanks Dan! Now I get it!!! ;)
