i want to be able to pass the id from the query into the popup window but not sure how to do it, would you please help me with this? - thanks
code below (A) working fine with open the pop up detail page but din't know how to passs an id into detail page.
<!----A--->
<script>
function openWin()
window.open("detail.cfm","_blank","toolbar=yes, scrollbars=yes, resizable=yes, top=500, left=500, width=400, height=400");
</script>
<cfset foo = querynew('id_int,aNo_var,Renew,Cancel')>
<cfloop query="getOrderHist">
<cfset queryaddrow(foo)>
<cfset querysetcell(foo,'id_int',getOrderHist.id_int)>
<cfset querysetcell(foo,'aNo_var',getOrderHist.aNo_var)>
<cfset querysetcell(foo,'Renew','<a href="javascript: void(0);" onclick="openWin()">view</a>')>
</cfloop>
<!---B--->
I try to call the page directly such as below but got an error for "invalid character"
<cfset querysetcell(foo,'Renew','<a href="javascript: void(0);" onclick="window.open("detail.cfm?id=#id#","_blank");>renew</a>')>
</cfloop>
you have an 'openWin' function, but then you're trying to add inline JS to do the same thing. I assume that later on you're looping over your 'foo' query outputting these links to renew. In which case I'd want to simply pass either a URL or just the ID into the openWin function. Much simpler than trying to add dynamic JS into a query cell.
I'm slightly confused as well why you're creating a new query, foo, when you already have the query getOrderHist which seems to have everything you need.
fun
...Copy link to clipboard
function openWin(id) {
window.open("detail.cfm?id=" + id, "_blank","toolbar=yes, scrollbars=yes, resizable=yes, top=500, left=500, width=400, height=400");
<cfoutput query="getOrderHist">
aNo: #getOrderHist.aNo_var#<br>
<a href="" onclick="openWin(#getOrderHist.id_int#); return false;">Renew</a><br>
</cfoutput>
worked, thanks millions
