I need help!!
How can i make work my older Macbook with the flashplayer?? Cant watch any videos on Facebook etc...
I am using 10.5.8 and Safari 5.0.6
The latest version that will work with 10.5.8 is Flash Player 10.3.183.90. It will likely get "booted" from most Flash video sites today by the HTML in the page. If that's the version you have, it's as far as you can go with Leopard. That's the bad news.
If you've got a PowerPC processor (G5), the news gets worse. You've reached the end of the road for updating a lot of software on your Mac.
If however, you've got an Intel Mac, then there's good news. Apple has OS 10.6 (Snow Leopard) for $19.99 and they ship free. You can upgrade without losing your software or files. Snow Leopard is compatible with the latest Flash Player, as well as a lot fo other software that won't run on 10.5.
HI
Thank you very much for your reply, in fact my machine has a Intel Core Duo 1.87 Mhz! So you mean i could make a uppdate and install the latest version of flashplayer?
Absolutely. Get the DVD from Apple. Install it, as au upgrade (which retains your accounts, software, and files) and then do the "combo" update to 10.6.8. Then you'll be able to run Flash Player 11.9.900.170, and a whole lot of other stuff.
Thank you for your help! I would like reinstall the hole operating system, shouldnt be a problem?
How about the drivers etc?
The drivers are proprietary (Mac software, Mac hardware). There were a limited few early 2009 MBPs that experienced an audio issue after upgrading to 10.6, but that was resolved with updates.
Hi men, first happy new year!
I tried to install 10.6 but my machine refuse the installation, whats wrong?
Is your Mac Intel or PowerPC?
>About this Mac will show it
Its a intel 1.83 Ghz, not power pc
How much RAM do you have?
1 gb ram
Mvh Chris
Odd.
That's the bare minimum you'd need. Is there enough hard drive space?
Yeah plenty, about 40 Gb
What's the exact error it gives when you attempt the install?
It says that this operationsystem cannot be installed on your system
Mvh Chris
I'm thinking that you've got an Intel CureDuo and NOT a Core2Duo. That's what usually causes this. The CoreDuo is a 32 bit processor, and the Core2Duo is 64. Snow Leopard is a 64 bit OS and it won't install on a CoreDuo processor.
Hi men, yeah its a core duo, so thats it, in fact the only thing i need is to get work the flashplayer, dont know how to fix this issue
Chris
