1. Re: I need help figuring out the best way to convert analogue video to DV so that I can edit it.
John T Smith Dec 31, 2013 9:33 PM (in response to TheHausOfMarsian)If your computer has a Firewire port, http://www.grassvalley.com/products/converters is the place to look
DV AVI (Windows name, I think MOV is equivalent) is about 13Gig per hour of video
2. Re: I need help figuring out the best way to convert analogue video to DV so that I can edit it.
Biggles Lamb Jan 1, 2014 4:12 AM (in response to John T Smith)What John has linked you to works. I have one of their ADVC products, input video from s.video, composite or component and it outputs via FireWire.
If your Mac has a FireWire input then you can capture in Premiere
Alternatively buy a DV camcorder on eBay that has a working recording input and use that as a feed through, an old Sony PC100 that I used to have enabled this function, it's. FireWire output being captured in Premiere
Col
3. Re: I need help figuring out the best way to convert analogue video to DV so that I can edit it.
TheHausOfMarsian Jan 1, 2014 1:22 PM (in response to Biggles Lamb)I have a media converter box with a firewire output. I was hoping not to buy another piece of exquipment. What I actually need help with is figuring out where in the program I am able to import from the media converter source and then what good settings are.
4. Re: I need help figuring out the best way to convert analogue video to DV so that I can edit it.
Biggles Lamb Jan 1, 2014 1:57 PM (in response to TheHausOfMarsian)Your media box is quite an old product.
In Premiere go to file > capture
The capture window should then present itself and as long as your mac has the correct device drivers, you should then see the Sony as the source device
5. Re: I need help figuring out the best way to convert analogue video to DV so that I can edit it.
Steven L. Gotz Jan 1, 2014 4:02 PM (in response to Biggles Lamb)As Biggles says, the capture window should work. You will have to set the camera to generic because the program will not recognize your device, but it should capture for you, even tough you will have to start and stop manually.
6. Re: I need help figuring out the best way to convert analogue video to DV so that I can edit it.
TheHausOfMarsian Jan 2, 2014 9:30 PM (in response to Biggles Lamb)Thanks Biggles and Gotz. I just couldint find capture, but now I can! (It was right under my nose too).
I'm trying it now and it appears to be working. Do you have any other recommendations for capturing from hi8 video source as far as setting go? I am using DV to capture. Are there any other settings I should pay attention to?
There is an extra line of video noise at the bottom, but when I google it, it sounds like it won't show on most standard tvs and if I want to fix it for online, that I should mask it after the fact vs scaling up the video.
7. Re: I need help figuring out the best way to convert analogue video to DV so that I can edit it.
Steven L. Gotz Jan 3, 2014 6:34 AM (in response to TheHausOfMarsian)It sounds like you have it right. Just ignore the noise until the end and then mask it. Or, for playback now and then, create a new sequence and drop you main sequence into it like a clip. Mask that. Then after playing it, go back to editing in the main sequence again. That way the noise will not bother you as you review your work, but the mask won't slow you down during editing.
8. Re: I need help figuring out the best way to convert analogue video to DV so that I can edit it.
Bill Hunt Jan 3, 2014 9:32 AM (in response to Steven L. Gotz)Also, a tiny bit of Effect>Motion>Scale (Scale UP just a bit), and then Effect>Motion>Position (Position that Scaled Video, down, so that the line of video noise is effectively cropped off) will work too, and give you a full, clean Frame.
Good luck,
Hunt
9. Re: I need help figuring out the best way to convert analogue video to DV so that I can edit it.
TheHausOfMarsian Jan 3, 2014 10:14 AM (in response to Bill Hunt)I noticed that all of the Hi8 captures are having toothy interlaced effects (especially on diagonal lines or motion).
Is this something I can correct through Premiere through the capture process or is it something that I have to do after?
Or is it not correctable at all?
I've done some googling but did not see anything premiere-specific about correcting that.
10. Re: I need help figuring out the best way to convert analogue video to DV so that I can edit it.
Biggles Lamb Jan 3, 2014 1:13 PM (in response to TheHausOfMarsian)I would not worry about it on your Mac, from a captured DV avi clip make an mpg file then a DVD and see how it looks on a TV
I captured all my DV tapes onto my PC about five years ago, some of them have the same effect but are OK outputted
11. Re: I need help figuring out the best way to convert analogue video to DV so that I can edit it.
TheHausOfMarsian Jan 3, 2014 1:35 PM (in response to Biggles Lamb)Thanks Biggles. Since I wrote that last comment about interlacing, I realized that the interlacing looks horrible during the capture, but then when you play the .mov file its not very noticable.
