1. Re: Dual Display - Speedgrade
Joost van der Hoeven Jan 2, 2014 2:55 AM (in response to MuseumsSheffield)This is how you do it:
- In Preferences > Display > Dual Display Output you need to check √ Enable.
- Below you need to manually set the coordinates of this second screen relative to your main OS screen. Meaning that if you have two HD screens and you are using the right one as your main screen, you need to set Window size > Left > to -1920 (YES negative value!)
Hope this helps. See also here:
2. Re: Dual Display - Speedgrade
MuseumsSheffield Jan 2, 2014 6:20 AM (in response to Joost van der Hoeven)Thanks, muche appreciated.
3. Re: Dual Display - Speedgrade
Joost van der Hoeven Jan 2, 2014 7:00 AM (in response to MuseumsSheffield)Most welcome. That's what this forum is for.
4. Re: Dual Display - Speedgrade
sankoor2012 Jan 24, 2014 12:39 AM (in response to Joost van der Hoeven)i have sony tv for reference or second monitor,i worked with this in premiere pro by connecting hdmi cable but in speedgrade it's not working,i checked enable in dual monitor(preferences)can anyone help me my graphic card is gtx titan
5. Re: Dual Display - Speedgrade
Joost van der Hoeven Jan 24, 2014 12:55 AM (in response to sankoor2012)Is it set up as a second monitor/desktop?
6. Re: Dual Display - Speedgrade
sankoor2012 Jan 24, 2014 5:48 AM (in response to Joost van der Hoeven)in nvidia control panel multi displays sony tv is 1st monitor and my acer monitor is 2nd one using hdmi cable
7. Re: Dual Display - Speedgrade
James Pageau Jan 28, 2014 5:34 PM (in response to Joost van der Hoeven)That works... but honestly.. this app is very rough around the edges for that to be the way to position its windows. Hopefully Adobe can address in a future release the bazar window management and UI paradigm that SpeedGrade has, but I know it has a mountain of critical fixes before you can even get to that stuff. I want to like it... but right now It is the buggiest app in the whole CC suite, and I cant count on it to work when I need it. It often refuses to refresh the main window when moved across screens. I can get some use out of it on my iMac... but it is crash happy on my Retina MB Pro. I do think SG is going to be very nice, but it probably is one more major release away before I can truly adopt it with confidence.
