I have successfully installed coldfusion on Ubuntu 13.10, but as a newbie to Ubuntu I am looking for a guide on the best way to continue from here?
For example, I can view the CFADMIN at "http://localhost:8500/CFIDE/administrator/index.cfm", but am having difficulties viewing test documents placed in the wwwroot folder.
Wayne
Hi Wayne,
What is the version of ColdFusion you are using? ColdFusion is not yet supported on Ubuntu 13.10. It's great , that it is working for you.
You may refer to http://help.adobe.com/en_US/ColdFusion/10.0/Developing/index.html and http://blogs.coldfusion.com/post.cfm/getting-started-with-tomcat-in-coldfusion-10.
If you are able to access CF Admin, that means, CF engine is working on your server. Is there any specific code/file not working for you?
Regards
Anit Kumar
Hi Anit!
I am accustomed to setting up my applications through IIS ... and developing in Dreamweaver ... and it is quite easy to be up and viewing quickly.
In the past 30 min I have successfully viewed my test page (finally).
There seems to be a large learning curve re permissions and the like. I cannot just right click and add folders per Windows.
I guess what I am looking for is a guide pointing out the differences between use of CF in Windows compared to Ubuntu, and how to navigate these successfully.
Another "problem" will be getting MySQL up and going too of course!
I have scoured the internet and cannot see much for Ubuntu bunnies like me
Cheers, Wayne
Hi Wayne,
I am not sure about a document describing the difference between use in windows/ubuntu from Adobe. You can search on the web (I found one non-adobe article, you may refer to http://www.iknowkungfoo.com/blog/index.cfm/2007/5/24/Moving-Coldfusion-applications-from-Windows-to-... ). Happy searching.
You can use the commannd to create the connector between Apache (Ubuntu) and CF
/opt/coldfusion10/cfusion/runtime/bin/wsconfig -ws Apache -dir /etc/httpd/conf -v
Verify your Apache configuration
1. Verify that one of the following files was created
cf_root/config/wsconfig/number
2. To set the connectionpooltimeout and reuseconnectioncount click on Advanced Setting tab.
Configuring Apache:
a) uriworkermap.properties: Mapped extensions based on which the connector forwards requests to Tomcat.
b) mod_jk.conf: Contains paths to all files in the \config\wsconfig\1 directory.
Note: For virtual host configuration, add the following entry in each of the virtual blocks: JkMountFile "cfroot\config\wsconfig\1\uriworkermap.properties:".
You can also refer to http://help.adobe.com/en_US/ColdFusion/10.0/Installing/WSc3ff6d0ea77859461172e0811cdec18c28-7ffd.htm...for difference for webconnector between windows and linux.
Hope it helps.
Regards
Anit Kumar
Dear Anit
Thank you so much for all the help! The general guide on the differences immediately solved one problem once I changed the name of "application.cfm" to "Application.cfm"
I am far from a "power user", but am enjoying the learning process. Inevitably I find that most of my encountered problems are associatied with permissions.
For a few brief years I was a cf developer, but now work in the tennis field at a large club. I developed an application which saved me hours and hours of work, and this application has become a key element in the whole summer program. Unfortunately, after migrating to CF10 from CF9 I can no longer connect to smtp.gmail.com (after hours and hours of searching for a work-around). Luckily I still had the same application on an older laptop, which was using CF9 ... and so I was still able to work as I wanted.
I decided to partition my new laptop to see if CF10 would work as I needed on Ubuntu.... which explains my intial posting.
I am very happy to report that, with your help, I have had success. For the record this is what I did
If at first you don't succeed, try, try again!
Again Anit, thank you for your help!
If you don't really want the hassle of setitng up web servers and database servers etc, an alternative is www.cfmldeveloper.com, then the only thing you need to run locally is your IDE.
Hi Wayne,
I am glad, I was able to help you.
waynefdavies wrote:
Dear Anit
Please let us know, if there is something still not working in CF10. You can open a new thread, if it's a new issue and not discussed above.
Regards
Anit Kumar
