1. Re: AirHelp formatting
Peter Grainge Jan 4, 2014 12:10 PM (in response to PBWT id)Discussion moved to AIRHelp category.
There is no need to create a duplicate project. Create a copy of your CSS file and rename it. MyStylesheetAIR.css for example.
In the body tag add a margin. In your AIR Help layout, select that CSS to override the usual topic css.
See AIR Help on my site.
2. Re: AirHelp formatting
PBWT id Jan 4, 2014 1:47 PM (in response to Peter Grainge)Very cool, I can't thank you enough. This worked out well.
3. Re: AirHelp formatting
Develop@11 Feb 11, 2014 1:53 PM (in response to Peter Grainge)I have run into another issue. In my Air.css, which is exactly like my default.css except for the margins in the body tag, my numbered headings are now indented about an inch to the right. I have checked the OL class and numerous other settings to no avail. I cannot even tell the CSS to indent the left margin of the OL class negatively. I'm not sure what could be causing this, the Web Help output looks good. Thanks in advance for any clues.
4. Re: AirHelp formatting
ermphd Feb 12, 2014 6:02 AM (in response to Develop@11)Hello,
I have read the dialog between you and Peter and his solution makes sense. The only Q I have is which version of the AIR run time are you using? If not current, update and see if it looks the same. I'd avoid fiddling with the classes and only do that as a last resort. Work on the CSS
Cheers
Ed Martino, PhD
Instructional Designer
5. Re: AirHelp formatting
PBWT id Feb 19, 2014 11:29 AM (in response to ermphd)Yes, the latest version is installed. The CSS was the answer.
