Form Page Data Validation?
Apr 26, 2007 Apr 26, 2007
I use ColdFusion's built-in server-side data validation alot:
input type="hidden" name="address_required" value="The Address field is required."
I love the fact that it goes on the page that contains the form fields, rather than the page that processes the form. That is, if page1.cfm has the form, and page2.cfm has a query that writes the Address to a database, I can put the validation on page1.cfm
Is there any way possible to write custom validation code that can go on the form page, rather than the processing page? By "custom validation", I mean something CF doesn't natively handle. Something like verifying that if the "Other" radio button is selected, they also filled in the "Specify" textbox.
Any thoughts?
Thanks.
Advanced techniques
932
you will have to write your own javascript functions. that is in fact
what cf does, too, behind the scenes...
i suggest you review your view on server-side validation, as it is a lot
more robust and will function even if your user has javascript disabled.
client-side form validation will be omitted if your users have js
disabled, and you may end up with all sorts of wrong data in your tables...
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
I'm not looking for client-side validation. I want server-side.
what you are actually employing with the name="something_required" form
fieldnames is only client-side. CF re-writes this code into javascript
whaen it processes the page request. it is NOT server-side at all.
check your page's source and you will see the javascript CF has put into it.
Azadi Saryev
Sabai-dee.com
Advocate ,
Azadi Saryev
Sabai-dee.com
With reference to the documentation (Line number 1)... It is actually a SERVER side validation routine which is not done in Client Side like you said...
The CFform tags generate Javascript. The use of the hidden input tag performs server-side validation.
Apr 30, 2007 Apr 30, 2007
Yes. The customary way to do it is to submit the form to its own page.
Apr 27, 2007 Apr 27, 2007
This is how I do it:
http://www.fordwebs.com/cfform.cfm
Ken Ford
Adobe Community Expert
Fordwebs, LLC
"Heavy_Doody" <webforumsuser@macromedia.com> wrote in message news:f0rmcb$me3$1@forums.macromedia.com...
> required."
> "Other" radio button is selected, they also filled in the "Specify" checkbox.
> Any thoughts?
> Thanks.
Okay, so there's another "no".
oops... you are right, as is Daverms. server-side of course. my bad.
the lack of sleep and the bout of flu must be affecting me more than i
thought...
Azadi Saryev
Sabai-dee.com
Vientiane, Laos
Advocate ,
Also leaving the value that you passed for the action attribute as blank will make the form to be submitted to its own page.
May 01, 2007 May 01, 2007
Unfortunately, that isn't an option in this particular case.
Do you mean submitting the form page to itself isn't an option?
Documentation
