1. Re: Premiere Pro running so slow when Lumetri look applied to clips
JSS1138 Jan 6, 2014 9:42 AM (in response to PeterCroker)I've seen issues using Lumetri and OpenCL acceleration. Try turning that off and using Software mode.
2. Re: Premiere Pro running so slow when Lumetri look applied to clips
petergaraway Jan 6, 2014 9:45 AM (in response to PeterCroker)Hi Peter,
I'm sorry for the trouble this is causing. We are aware of the performance issues that were introduced in version 7.2 with certain AMD GPU cards.
We're investigating the problem now.
I know this is not ideal but in the mean time here's a few workarounds:
- Revert back to 7.1
- Disable GPU acceleration when using those effects
Here's a list of effects that seem most problematic:
*Fast Color Corrector
*RGB Curves
*ProcAmp
*Edge Feather
*Lumetri Looks effects
These effects do not appear hinder the performance in my testing:
*All Blurs Effects
*Three Way Color
*Crop
*Garbage Mattes
*Levels
Again, I apologies the the inconvenience.
Best,
Peter Garaway
Adobe
Premiere Pro
3. Re: Premiere Pro running so slow when Lumetri look applied to clips
PeterCroker Jan 6, 2014 10:07 AM (in response to JSS1138)Hi Jim, thanks for the reply, that seems to of worked!
The clips ive added filters to now have red above them rather than yellow but still play, so what am I actually loosing by not using the GPU acceleration ?
Peter
4. Re: Premiere Pro running so slow when Lumetri look applied to clips
PeterCroker Jan 6, 2014 10:12 AM (in response to petergaraway)Hi Peter, thanks for the response, disabling the GPU seems to of done the trick for now.
Ive only been running Premiere CC since November so not sure if I would of gone straight onto 7.2?
If i need to how would i go about reverting to 7.1?Peter
5. Re: Premiere Pro running so slow when Lumetri look applied to clips
petergaraway Jan 6, 2014 10:30 AM (in response to PeterCroker)See this thread:
http://forums.adobe.com/message/5823746#5823746, Post 18
Peter Garaway
Adobe
Premiere Pro
6. Re: Premiere Pro running so slow when Lumetri look applied to clips
PeterCroker Jan 6, 2014 10:33 AM (in response to petergaraway)thanks, will that be a problem with projects that have been saved using 7.2?
