1. Re: When copying a state, symbols get lost (latest CS6 Update)
atenyotkin Jul 15, 2013 11:35 PM (in response to heartsanddeath)Same issue here. I actually didn't realize that it was a symbol issue until I read your post. Had to share my layers across states but that's not really what I need. I doubt there's a fix coming from Adobe any time soon, but fingers crossed. Didn't have this issue with CS6 I had on another machine. For now I'll just use your workaround of grouping the symbol.
2. Re: When copying a state, symbols get lost (latest CS6 Update)
Aloof Jul 23, 2013 1:07 AM (in response to heartsanddeath)I have the same issue as well. Adobe not only didn't fix the memory bug, they introduced new ones!
3. Re: When copying a state, symbols get lost (latest CS6 Update)
rioo84 Aug 12, 2013 1:45 AM (in response to heartsanddeath)Me and my colleague got the same issue. Happened to us after the Fireworks latest update. Reinstalling Fireworks and not applying the latest update (which is kinda paradox) solved the problem for us. Hope this helps.
4. Re: When copying a state, symbols get lost (latest CS6 Update)
Marco_ALEX Sep 25, 2013 6:47 AM (in response to heartsanddeath)you have to convert the image to symbol and the select button ,after that you click twice on it and then select the state here http://prntscr.com/1tdms1
not here
5. Re: When copying a state, symbols get lost (latest CS6 Update)
heartsanddeath Sep 25, 2013 9:01 AM (in response to Marco_ALEX)Thanks for your answer, Marco. But it's not about using a button symbol, but a graphic symbol that gets lost when the state (document state, not button state) is copied.
6. Re: When copying a state, symbols get lost (latest CS6 Update)
BigQuiver Sep 25, 2013 6:18 PM (in response to heartsanddeath)I was experiencing this same issue. I found a work around by deleting and rebuilding the Fireworks preferences file using the knowledgebase article below. After restarting Fireworks I was able to duplicate states with all symbols being copied accross. I hope this works for you guys too!
http://helpx.adobe.com/fireworks/kb/restore-preferences-fireworks-cs5.html
Cheers,
Greg
7. Re: When copying a state, symbols get lost (latest CS6 Update)
BigQuiver Sep 25, 2013 7:21 PM (in response to BigQuiver)Check that... When I retested it I duplicated a page accidentally rather than a state. Duplicating states still does not work.
8. Re: When copying a state, symbols get lost (latest CS6 Update)
seafoam_green Jan 6, 2014 5:14 PM (in response to heartsanddeath)I'm experiencing the same problem. Has anyone found a workaround so that duplicating a state doesn't delete all symbols in the duplicated version? I spend my day duplicating symbols, so this has become a serious problem...
9. Re: When copying a state, symbols get lost (latest CS6 Update)
bomberstudios Jan 11, 2014 11:32 PM (in response to heartsanddeath)Hi all.
Yesterday, I received a request from Chad Thornton at Airbnb to create a command to fix this issue.
Luckily, the answer was easy to find and it works like a charm.
Download this command https://www.dropbox.com/s/z22ov4vom02w311/Duplicate%20State.jsf and put it somewhere in your 'Commands' folder.
Now, whenever you want to duplicate a state, use the command instead of the States panel menu, and all symbols will be there : )
Enjoy!
10. Re: When copying a state, symbols get lost (latest CS6 Update)
heartsanddeath Jan 13, 2014 12:41 AM (in response to bomberstudios)Wow, awesome that someone is actually trying to do something about this :-)
Unfortunately the Command isn't working for me, it duplicates the states, but loses the symbols (now it loses them when they are grouped as well).
But maybe I'm doing something wrong?
Have a great Monday anyway :-)
11. Re: When copying a state, symbols get lost (latest CS6 Update)
bomberstudios Jan 13, 2014 1:00 AM (in response to heartsanddeath)Honestly, I don't use states that much, so I haven't tested the command a lot and I'm sure there are more bugs lurking there.
I'm currently working on fixing it for the case where some elements are locked. Is this the case in your document?
If not, would you mind sharing a document where it doesn't work, so I can reproduce the bug on my side?
Thanks in advance! : )
12. Re: When copying a state, symbols get lost (latest CS6 Update)
heartsanddeath Jan 13, 2014 2:24 AM (in response to bomberstudios)Aaaaah, yes the symbol layer was locked, otherwise the command is working perfectly!
This is so great, you have no idea how tedious it felt these past months working in fireworks.
You're awesome! Thank you so so much for doing this :-D
13. Re: When copying a state, symbols get lost (latest CS6 Update)
bomberstudios Jan 13, 2014 2:32 AM (in response to heartsanddeath)Cool!
I hope to have a version that works with locked elements ready soon. I'll post it here when it's done.
Glad to be of help!
14. Re: When copying a state, symbols get lost (latest CS6 Update)
bomberstudios Jan 13, 2014 3:54 AM (in response to heartsanddeath)Ok, here it is: https://www.dropbox.com/s/z22ov4vom02w311/Duplicate%20State.jsf
It should work with locked elements. However, the locked status of elements is not carried over to the new state. I might try to fix that later on, but it looks quite hard and I honestly don't see the benefits to make it worth pursuing : )
Let me know how it works!
15. Re: When copying a state, symbols get lost (latest CS6 Update)
heartsanddeath Jan 13, 2014 8:09 AM (in response to bomberstudios)Awesome, it works!
Thank you so much for your work!
If you ever get to fix the thing with the locked-status it would be greatly appreciated, but of course, no pressure ;-)
16. Re: When copying a state, symbols get lost (latest CS6 Update)
we are slim May 9, 2014 1:17 AM (in response to heartsanddeath)I am running into the same problem (symbols get lost when duplicating a state).
Fortunately there is an easy workaround to address this newly introduced bug:
Instead of using the "duplicate frame" command, try clicking directly onto the state bar while holding down ALT-key.
Works for me perfectly.
17. Re: When copying a state, symbols get lost (latest CS6 Update)
christophleitner Sep 9, 2014 1:21 AM (in response to we are slim)Alt-clicking works for me as well, thanks we are slim!
