Hello; Does anybody know, if the
ColdFusion 10 mandatory update ist cumulative, includes the hotfixes before.
There are several hotfixes listed under http://helpx.adobe.com/security/products/coldfusion.html.
Are them includes in dthe amandatory update?
Or must these hotfixes installed add one.
frank
The mandatory update only allows the hotfix update mechanism to work properly. It does not include anything else.
The fixes for ColdFusion 10 issues are available only in the proper updates and they are all cumulative. The latest update for ColdFusion 10 is update 12.
I found;
Also a way to install the updates manually.
Thank's.
frank
Hello;.
O.K.!
Where? I use the link: http://helpx.adobe.com/security/products/coldfusion.html ..
What ist update 12? On Adobe the latest ist APSB13-27 APSB13-27
Security update: hotfix available for ColdFusion 11.12.2013 APSB13-19
Security update: hotfix available for ColdFusion 07.09.2013 APSB13-13
Security update: hotfix available for ColdFusion 5/14/2013 APSA13-03
Security advisory for ColdFusion 05.08.2013 APSB13-10
Security update: hotfix available for ColdFusion 04.09.2013 APSB13-03
Security update: hotfix available for ColdFusion 1/15/2013 APSA13-01
Security advisory for ColdFusion 01.04.2013 APSB12-26
Security update: hotfix available for ColdFusion 12.11.2012 APSB12-25
Security update: hotfix available for ColdFusion 11/19/2012 APSB12-21
Security update: hotfix available for ColdFusion 09.11.2012
frank
ColdFusion 10 has an inbuilt mechanism in the administrator for notification & installation of the updates as and when they are available. When you login to the ColdFusion administrator, you would see the notification for the updates that are available and you can install the update right from the administrator.
In case you want to download and install the updates manually, you can refer to the following article
http://blogs.coldfusion.com/post.cfm/how-to-download-and-install-coldfusion-10-hotfix-directly
