I have applied the IE 10 fixes for displaying help, yet one topic displays the TOC and header, but the right hand panel is blank and flickers until I select a different topic (but the flicker returns when I select the original context sensitive topic in the TOC), or I select a program from the IE toolbar (for example: "About Internet Explorer" and then it is fine until I exit the browser and try again.
Here's the kicker. I am using IE9 and do not plan to upgrade to IE10 for precisely the reason RH 10 needs a patch.
I took the templates in FixForRH10Install and copied them to where they had to go, recompiled and there is no more flicker.
Well, that’s just great for you – but your help users may have something else in mind (if they have any browser choice at all) ;>)
I think maybe the issue is that the problem appeared in IE9 after applying the IE10 patch, and maybe a significant number of users will still be on IE9 .
Given the symptoms, maybe there's some rogue code in the problematic topic. Comparing the code of the good topic and the problem topic might reveal the issue.
For example, I once had a couple of topics that were missing the border between the topic content and the tri-pane bar (in chm output). Somehow the bad topics had topic level code that removed the border. No idea how.
HTH,
Amber
Amebr,
Sorry for the delay in replying - changed priorities interfered.
Thank you for the reply. Did you compare the good and bad "topic's" code or project files' code? What precisely did you compare?
Mark
For my particular situation I looked in the source code for a good and a bad topic, and specifically the first dozen or so lines that deal with setting up the html page (so, about to the bottom of the HEAD section-ish). I can't remember exactly what the problem was now, as it was quite a long time ago - possible a strange in-line or page-level stylesheet setting.
Thanks. I appreciate your patience.
Date: Tue, 7 Jan 2014 22:11:01 -0800
To: steelcasemark@hotmail.com
Subject: Right-Hand panel flickers for context-sensitive help
Re: Right-Hand panel flickers for context-sensitive help
created by Amebr in WebHelp - View the full discussion
Please note that the Adobe Forums do not accept email attachments. If you want to embed a screen image in your message please visit the thread in the forum to embed the image at http://forums.adobe.com/message/5991484#5991484
Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page:
To unsubscribe from this thread, please visit the message page at . In the Actions box on the right, click the Stop Email Notifications link.
Start a new discussion in WebHelp at Adobe Community
For more information about maintaining your forum email notifications please go to http://forums.adobe.com/thread/416458?tstart=0.
