I recently upgraded to Windows 8.1 and have had to make several adjustments. I was not able to download books into my Nook from Barnes & Noble because it needed to re-authorize my computer. I deleted my old authorization and tried to proceed from there, but it didn't like my name/password, or it said my name/password already existed, but it still won't authorize. I changed my name/password, but that still didn't help.
It could be that the upgrade confused the authorization; it often seems to happen. try ...
Sometimes ADE gets its registration/activation confused and in a semi-authorized state.
Uninstalling and reinstalling does not help, and indeed installation can even trigger this state.
Unfortunately, it often then gives misleading error messages about what is wrong.
A common incorrect message informs you that the ID is already in use on another computer and cannot be reused.
Another is "E_AUTH_NOT_READY"
This can often be resolved by completely removing any authorization using ctrl-shift-D to the Library screen on ADE (cmd-shift-D if on Mac).
Restart ADE, and then reauthorize with your (old) Adobe ID.
In extreme cases on the mac, the following extra step has helped some people. Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash. If you are using 10.7, see Access hidden user library files | Mac OS 10.7 Lion. http://forums.adobe.com/thread/1265248?tstart=0
When I do as suggested above, I get a message: Incorrect login or password for the selected eBook vendor.
I think B&N have their own Vendor ID:
possibly the email they have on record for you as name, and the credit card number as password.
If theat doesn't help, check with B&N.
No. I know what that name and password are. This is not an error on their part.
What if I go ahead and remove ADE and re-install it. Do you think that would work?
There are lots of bugs in ADE2.0 (and 2.0.1). Try replacing ADE2.0 with the older but more reliable v1.7.2.
(You can have them both installed at once if you like.)
Version 1.7.2, it is a little difficult to find, available on Adobe site for Windows and for Mac.
http://helpx.adobe.com/digital-editions/kb/cant-install-digital-editions.html
The forum software is sometimes corrupting the link above. There shouldn't be a blank in 'editio ns.html'. The following redirects to the same page: http://tinyurl.com/diged172
Some people have found ADE trying to upgrade automatically.
It appears (not 100% sure) that if you install ADE2.0 as a new install (not as an upgrade) that your 1.7.2 will continue to run.
Probably best to say no if 2.0.x installation asks if you want to migrate your library.
