1. Re: Generate Edge Reflow link not in edit menu...
Chris Bank - ReflowDev Sep 12, 2013 9:21 PM (in response to monsterpinball)It should be under the file menu, and you need to have a PSD open in photoshop for the menu to enable. If you see the "File > Generate > Image Assets" menu but not "Edge Reflow Project" try installing or re-installing Reflow. The Reflow installer installs a plugin into Photoshop. You can also download a standalone mac plugin installer from http://adobe.com/go/reflowpsplugin_mac
You can also learn more about the plugin here http://html.adobe.com/edge/reflow/photoshop-plug-in.html
For refernence, here is what the menu should look like:
Thanks for trying the feature out. Hopefully this helps and let us know how we can improve it for you.
2. Re: Generate Edge Reflow link not in edit menu...
monsterpinball Sep 12, 2013 9:34 PM (in response to Chris Bank - ReflowDev)Actually it was due to the Photoshop CC program file being out or date at v14.0. I updated to 14.1 to resolve the issue. This was pointed out by a user and not Adobe. Bit clumsy given that your tutorials show it haha. Anyway all sorted
3. Re: Generate Edge Reflow link not in edit menu...
CoreyRLucier Sep 13, 2013 5:59 AM (in response to monsterpinball)Just to clarify which tutorials detail using v14.0?
4. Re: Generate Edge Reflow link not in edit menu...
John Minshall Jan 9, 2014 9:21 AM (in response to CoreyRLucier)I'm having the same problem with the generate to reflow option not visible in PS cc. When I check which version of RF I'm using it says v.0.32.13658. There is no way to update or re-install as it says that Im using the latest version? Is this the latest version or am I doing somthing wrong?
Thanks in advance.
5. Re: Generate Edge Reflow link not in edit menu...
Anirudh Sasikumar Jan 9, 2014 9:34 AM (in response to John Minshall)If you want to re-install, you can open Finder and drag Adobe Edge Reflow CC.app into Trash.
Quit creative cloud desktop and start it again to see the "install" prompt again.
Bit more help here: http://responsiveflow.tumblr.com/post/72109758579/troubleshooting-photoshop-reflow-connect ion
6. Re: Generate Edge Reflow link not in edit menu...
tazosmr Oct 20, 2014 12:01 PM (in response to monsterpinball)1) Reflow Should be installed after Photoshop (If already installed, then uninstall it and re-install).
2) Make sure, that Photoshop is close while you install the ReFlow.
3) After ReFlow installation, open Creative Cloud >Photoshop( open a PSD file), then open ReFlow.
4) Now, you should see the ReFlow menu under Photoshop>File>Generate.
