Bjr,
Je recontre un problème pour autoriser mon ordinateur, puis ma liseuse, car au moment de m'identifier sur ADE, je reçois le message suivant:
" Erreur au niveau du serveur d'activation
Code: E_AUTH_NOT_READY"
Comment procéder? Merci d'avance.
Sometimes ADE gets its registration/activation confused and in a semi-authorized state.
Uninstalling and reinstalling does not help, and indeed installation can even trigger this state.
Unfortunately, it often then gives misleading error messages about what is wrong.
A common incorrect message informs you that the ID is already in use on another computer and cannot be reused.
Another is "E_AUTH_NOT_READY"
This can often be resolved by completely removing any authorization using ctrl-shift-D to the Library screen on ADE (cmd-shift-D if on Mac).
Restart ADE, and then reauthorize with your (old) Adobe ID.
In extreme cases on the mac, the following extra step has helped some people. Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash. If you are using 10.7, see Access hidden user library files | Mac OS 10.7 Lion. http://forums.adobe.com/thread/1265248?tstart=0
I have somewhat the same issue, I cannot seem to unauthorize my computer - when asked for my password to get the unauthorization done, no matter what password I use I am told it is incorrect. I have no idea what my password is, so I cannot use my e-reader. My computer also does not seem to recognize that my e-reader (KOBO) is connected to my computer.
MERCI BEAUCOUP
