1. Re: Can another Muse user upload site to my BC account?
p_nath Jan 12, 2014 5:06 PM (in response to iveduboua)Hello,
The one publishing to the your site should have Muse installed in their system (to be able to publish from Muse to BC), and should also be added to your BC site as an admin (to be able to publish to your site). If they are not added to your site as an admin, they can't publish to your site.
Hope this helps.
Cheers
Parikshit
2. Re: Can another Muse user upload site to my BC account?
iveduboua Jan 12, 2014 5:53 PM (in response to p_nath)So what i understand is... i would create a new site in BC, then add my collegue as a admin then give him the access to the FTP so he could upload the site at the right place,
am i correct?
ive d.
3. Re: Can another Muse user upload site to my BC account?
p_nath Jan 12, 2014 5:58 PM (in response to iveduboua)If you're looking to host the site in Business Catalyst, you don't need FTP to upload the site contents. If the user (who is publishing the site from Muse to BC), has a valid Muse subscription (to be able to open your site in his/her copy of Muse for publishing purposes), and is added to your site as an admin user (which is required for him/her to gain the permissions needed to publish to your site), then they can publish to your site fine, by using the "Publish" button in Muse, and selecting your site to publish to.
"Upload to FTP host" and/or "Export As HTML" options are required when you're hosting your site elsewhere.
Hope this helps.
Cheers
Parikshit
4. Re: Can another Muse user upload site to my BC account?
iveduboua Jan 12, 2014 6:00 PM (in response to p_nath)Since you are there, could i ask you about another question... (concerning BC tags)?
i.
5. Re: Can another Muse user upload site to my BC account?
p_nath Jan 12, 2014 6:01 PM (in response to iveduboua)Yes please.
6. Re: Can another Muse user upload site to my BC account?
iveduboua Jan 12, 2014 6:12 PM (in response to p_nath)Since i am in Québec (Canada) and most of ours clients are francophones, the main language for the sites we work on is french...
I am currently working on a email template for campains... Thank god for Zurb responsive templates.
How do i (or where do i) change the: {tag-unsubscribe} so that it show "se désabonner" instead of "unsubscribe"
i allready ask that question earlier here: http://forums.adobe.com/message/6005722#6005722
i need to find a fix for that.
i.
7. Re: Can another Muse user upload site to my BC account?
p_nath Jan 12, 2014 6:58 PM (in response to iveduboua)I think this is what you're looking for: http://www.businesscatalyst.com/system-announcements-app/customize-newsletter-unsubscribe- tag-into-your-own-language
Hope this helps.
Cheers
Parikshit
8. Re: Can another Muse user upload site to my BC account?
iveduboua Jan 12, 2014 7:29 PM (in response to p_nath)It worked! ouf!, thanks.
the great Liam mentioned that to me earlier but i did the modification on an allready sent campain...
this time i've modified my template from within the partner portal email template section.
it worked!
thank you for your help my friend!
ps:
there is only one drag to it:
«Furthermore if the unsubscribe tag {tag_unsubscribe} is customized then the system will force its own unsubscribe link in English right at the bottom. This is in case the unsubscribe tag is changed to a word which no longer means unsubscribe. This is a condition in customizing this tag.»
why?
...it happened in my test campain ; (
9. Re: Can another Muse user upload site to my BC account?
p_nath Jan 12, 2014 7:42 PM (in response to iveduboua)This is how it was designed. I'm afraid this is not something that can be changed, and is hence, mentioned in the directions beforehand.
Parikshit
10. Re: Can another Muse user upload site to my BC account?
iveduboua Jan 12, 2014 7:45 PM (in response to p_nath)unless i put both... right?
that way, i could at least choose the size of the font?
i.
11. Re: Can another Muse user upload site to my BC account?
p_nath Jan 12, 2014 9:01 PM (in response to iveduboua)Yes, try that and let me know how that goes.
