3 Replies Latest reply: Jan 13, 2014 5:17 PM by JSS1138 RSS
    Export settings for mpeg2 for VOD content cable provider
    smartcel71 Community Member
      Does anyone know if it is possible to render to mpeg 2 with specific settings for VOD content cable provider in Premiere Pro?
      Is there a specific preset for it? Or do you really need an external plugin (like the very expensive QT plugin from PIXELtools?
      For a cable provider I need to make SD content.
      Encoded some MPG 2 TS test files and uploaded them to the test-environment of the Cable provider.
      The calbel provider said the files are almost approved, they need a little more tweaking.
      But the cable provider only gives me a list of errors in return. Errors they see in in the testing environment before publishing.
      1. Rendered MPG's have PCR errors (deviation in clock frequention)
      2. to get better quality encoded MPG's, they say to stretch the GOP.
      Since I'm not in to GOP's, M frames and I-pictures.
      They gave me a white paper with the following rules (must is obligatory and SHOULD is an advice)
      1.     The first byte of the video elementary stream MUST be the first byte of a sequence_start_code.
      2.     The video elementary stream MUST contain an integral number of access units.
      3.     A Sequence Header and a Sequence Extension MUST precede each I-Picture.
      4.     All B-Pictures in the video bit stream MUST use prediction based on pictures present in the bit stream. Specifically, the first GOP in the video elementary stream MUST NOT begin with a B-Picture predicted from a reference picture that does not exist in the stream. That is, the first GOP MUST be closed.
      5.     For MPEG2 encoding, the length of each GOP SHOULD be 12 frames.
      6.     For MPEG2 encoding, the number of consecutive B-Pictures between anchor pictures (I-Picture or P-Picture) MUST be two or less.
      Does anyone know how to set the above requested into the Premiere Pro exportsettings from below (my settings, to make an MPG
      Hope someone can help or has an export setting.
      Thx in advance
