If you are not familiar with CSS, it is going to be a bit
tricky.
The OL tag controls the overall appearance of a numbered
list. OL stands for Ordered List.
The UL tag controls the overall appearance of a bulleted
list. UL stands for Unordered List.
LI controls the appearance of List Items and applies to both
types of list which can make getting the list you want a little
difficult at times. You may make a change that gets the bullets and
numbers aligned but then find the text in the two list types is no
longer aligned. That may or may not bother you. Also watch out in
numbered lists. Get it perfectly aligned to the left margin and the
first nine items will be OK, get to number 10 and the 1 might be
too far left. It's trial and error.
You need to visit the link I gave you where you will find out
how style sheets work. Then create a new project and use that to
learn with rather than messing with your main project.
